Povratak   PC Ekspert Forum > PC Ekspert > Novosti
Staro 17.05.2005., 18:45   #1
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,963
Rat konzola-PS3
Za nestrpljive, evo malo detaljnijih specifikacija:
CPU
Cell Processor
PowerPC-base Core @3.2GHz
1 VMX vector unit per core
512KB L2 cache
7 x SPE @3.2GHz
7 x 128b 128 SIMD GPRs
7 x 256KB SRAM for SPE
* 1 of 8 SPEs reserved for redundancy
total floating point performance: 218 GFLOPS
GPU
RSX @550MHz
1.8 TFLOPS floating point performance
Full HD (up to 1080p) x 2 channels
Multi-way programmable parallel floating point shader pipelines
Sound
Dolby 5.1ch, DTS, LPCM, etc. (Cell- base processing)
Memory
256MB XDR Main RAM @3.2GHz 256MB GDDR3 VRAM @700MHz
System Bandwidth
Main RAM 25.6GB/s
VRAM 22.4GB/s
RSX 20GB/s (write) + 15GB/s (read)
SB< 2.5GB/s (write) + 2.5GB/s (read)
System Floating Point Performance
2 TFLOPS
Storage
Detachable 2.5" HDD slot x 1
I/O
USB Front x 4, Rear x 2 (USB2.0)
Memory Stick standard/Duo, PRO x 1
SD standard/mini x 1
CompactFlash (Type I, II) x 1
Communication
Ethernet (10BASE-T, 100BASE-TX, 1000BASE-T) x 3 (input x 1 + output x 2)
Wi-Fi IEEE 802.11 b/g
Bluetooth 2.0 (EDR)
Controller
Bluetooth (up to 7)
USB 2.0 (wired)
Wi-Fi (PSP)
Network (over IP)
AV Output
Screen size: 480i, 480p, 720p, 1080i, 1080p
HDMI: HDMI out x 2
Analog: AV MULTI OUT x 1
Digital audio: DIGITAL OUT (OPTICAL) x 1
Disc Media
CD PlayStation CD-ROM, PlayStation 2 CD-ROM, CD-DA, CD-DA (ROM), CD-R, CD-RW, SACD, SACD Hybrid (CD layer), SACD HD, DualDisc, DualDisc (audio side), DualDisc (DVD side)
DVD: PlayStation 2 DVD-ROM, PlayStation 3 DVD-ROM, DVD-Video, DVD-ROM, DVD-R, DVD-RW, DVD+R, DVD+RW
Blu-ray Disc: PlayStation 3 BD-ROM, BD-Video, BD-ROM, BD-R, BD-RE
Staro 17.05.2005., 18:46   #2
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,963
I još malo slikica ovdje.
Staro 17.05.2005., 19:45   #3
Darth Revan
Darth Revan's Avatar
Lokacija: Ireland
Postovi: 1,565
jesi vidio slike iz igara, nevjerojatno covjece!!!!!
Darth Revan je offline   Reply With Quote
Staro 17.05.2005., 20:05   #4
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,963
Jap , izgleda prejebeno. Već vidim kako pronalazi mjesto negdje u stanu
Staro 18.05.2005., 14:56   #5
syss
syss's Avatar
Postovi: 10,805
pa xbox propao prije izlaska
Staro 18.05.2005., 19:01   #6
Stipe
Head Of The Radio
Stipe's Avatar
Datum registracije: May 2003
Postovi: 672
Ne bih se složio ja još uvijek mislim da je X360 jači jer ATi GPU je neš amblivbl ipak je tu 48 pipelina i 10Mb eDRAM(a pravi eksperti znaju što ovaj eDRAM znači ).nVidija samo 24pipeline i bez eDRAMA brijem da će GPU biti taj koji će odigrati najveću ulogu kod nove generacije konzola.Svaka čast Soniju ali mi je dizajn preodvratan
P.S Tak i tak budem sve kupil ali X360 prvo.A jedna stvar kod tih svih novih konzola mi je najzanimljivija Revolution(NINTENDO) će koristiti(napokon) standardni medij a to znači napokon i nitendo kod gusara.(Zelda za 20kn ,tor ne briši ovo ipak je ovo dobro namjerno )
Stipe je offline   Reply With Quote
Staro 18.05.2005., 19:03   #7
Stipe
Head Of The Radio
Stipe's Avatar
Postovi: 672
Đojstiki su faking banana i po izgledu i u prenesenom značenju A sama konzola izgleda kao neki moderniji kombajn
Staro 18.05.2005., 23:04   #8
syss
syss's Avatar
Postovi: 10,805
samo što će na ps3 igra bit na 40-50gb plavoj zraci, a na xboxu na dl medijima ak se ne varam... možda će i malo detaljnije igre bit na ps3?
Staro 18.05.2005., 23:09   #9
stef
stef's Avatar
Lokacija: Zabok
Postovi: 3,419
Zapravo je riječ o 24 pajpa, ali se priča o 2 ALU jedinice po pajpu.
PS3 ne koristi eDRAM za grafiku ali zato koristi XDRAM za sistem koji bi trebao biti veće propusnosti nego DDR3 700Mhz kod Xboxa. Također je broj jezgri procesora duplo veći i ostvaruje se duplo više FLOPS-a.
Gigabit ethernet, Fi-Wi, Bluetooth, 6 xUSB ... možeš uštekat što hoćeš. BlueRay optikaner se također spominje.
Što se tiče grafike ne vjerujem da će biti lošija od Atija s obzirom da su na tome radili Nvidia, Sony i Toshiba (proizvodnja). Kažu da bi trebala biti jača od 2x6800Ultra u SLi modu pa ćemo vidjeti dal je to tako.
Ja prednost dajem Sony-u.
Staro 19.05.2005., 03:44   #10
SlavoS
Postovi: 1,116
u prednosti ce biti :
na zapadu, ko se pojavi u pravom trenutku (pred bozic)
na istoku, za koga budu dobavljive igre po popularnoj tarifi
olakotna okolnost za oba slucaja kompatibilnost u rikverc
sto se tice snage, obije je imaju u ovom trenutku vise nego dovoljno (ako je istina to sto pise....)
SS
SlavoS je offline   Reply With Quote
Staro 19.05.2005., 09:43   #11
Bran
nemam kaj napisati
Bran's Avatar
Lokacija: Međimurje
Postovi: 1,303
Ak se ne varam PS3 bi druge godine trebao doći u Hrvatsku. Kolika cijena bi se mogla očekivati?
Staro 19.05.2005., 10:30   #12
Mailman
Mailman's Avatar
Postovi: 1,606
500$...kod nas, dakle, 5000kn
http://www.gamespot.com/news/2005/05...s_6125423.html
Mailman je offline   Reply With Quote
Staro 19.05.2005., 15:47   #13
syss
syss's Avatar
Postovi: 10,805
mlohava kuna, mlohava kuna... :ćuna:
Staro 19.05.2005., 16:48   #14
Stipe
Head Of The Radio
Stipe's Avatar
Postovi: 672
Cell je ustvari jedna jezgra s 7 SPE-a a X360 ti je 3 jezgre s po 2 threada.
PS2 ti je imao dva pomoćna vektorska procesora samo u Cell inačici su oni puuuuno prošireni x4 + 3 Gigaherca.
A ovo s propusnosti XDRAMA ti vrijedi samo za Celll ali ne i za Grafikčku a kod atija ti tih 'sitnih' 10Mb ostvarduje brandwith od 256 Gb a sama XDR memorija 25.36 Gb.
A što se tiče flopsa ja neznam zašto su svi zapeli za flopse pa proc u PS2 ima 6.4GFLOPS-a što ti je jednako P4 na 2.9GHz a Xbox1 ti je imao 380MFLOPSA što je otprilike jednako Duronu na 600MHz tak da manimo mi te flopse jer to se nikako ne može izmjerit već sony i Ms daju marketing podatke kak im se hoće...
Da budem iskren nekako mi se Nitendo sada čini u najboljoj poziciji...
