Staro 20.01.2011., 18:07   #1
elina08
Seven
elina08's Avatar
Datum registracije: Jul 2009
Postovi: 97
AMD Catalyst 11.1a Hotfix (BETA 8.82.2) Win7 x86/x64
AMD Radeon HD 6900 and AMD Radeon HD 6800 Series:
  • 3DMark Vantage improves ~7%
  • 3DMark06 improves ~3%
  • Call of Duty Black Ops improves ~20% at 4xMSAA and up to 35% at 8xMSAA
  • Riddick Assault on Dark Athena SSAO performance improves ~20%
  • Unigine Heaven OpenGL performance improves ~10% at moderate, 30% at normal and 100% at extreme tessellation levels
  • Aliens vs. Predators improves ~9% at 2xMSAA and up to 20% at 4xMSAA
  • Batman Arkham Asylum improves ~4%
  • Crysis Warhead improves ~2-4%
  • Metro 2033 improves ~28% at 4xMSAA
AMD Radeon HD 6900 Series:
  • Battleforge DirectX 11 performance improves as much as 6%
New Tessellation Controls:
  • The Catalyst Control Center includes an early prototype of some new tessellation controls. Our goal is to give users full control over the tessellation levels used in applications. The default selection “AMD Optimized” setting allows AMD, on a per application basis, to set the best level of tessellation. The intention is to help users get the maximum visual benefit of Tessellation, while minimizing the impact on performance. Currently no applications have been profiled, so the “AMD Optimized” setting will be non-operational until further notice.
  • “Use Application Settings” option gives applications full control over the Tessellation level. Users can also manually set the maximum tessellation level used by applications with the slider control
  • The long term goal for the “AMD Optimized” setting is to use the Catalyst Application Profile mechanism to control the AMD recommended level of tessellation on a per application basis. AMD’s intention is to set the tessellation level such that we will not be reducing image quality in any way that would negatively impact the gaming experience.
http://downloads.guru3d.com/AMD-Cata...load-2666.html
elina08 je offline   Reply With Quote
Staro 20.01.2011., 19:43   #2
HCS
Premijum
HCS's Avatar
Postovi: 1,360
Eeem Ovo su znaci update 10.12a hotfix drivera? Ali jos uvijek beta, koliko sam skuzio? Se ocekuju kakva promjene u offical releasu? Jel ko stavio na 68XX/69XX seriju?
Staro 20.01.2011., 20:09   #3
dzura
bla bla...
dzura's Avatar
Postovi: 244
evo ja sam probal, malo sam razocarani.....nakon ovog obecanja od 20 posto u black ops meni nula...sve isto....u čmarcima bjedinih 5 bodova.....
black ops 10.12:
black ops 11.1:
postavke:
i evo reza od 3dmark11(prvo je 10.12 a drugo 11.1):
http://3dmark.com/3dm11/469690
http://3dmark.com/3dm11/469812
dzura je offline   Reply With Quote
Staro 20.01.2011., 20:32   #4
elina08
Seven
elina08's Avatar
Postovi: 97
Autor HCS Pregled postova
Stavio sam ga na svoju 6870 prije dva dana najviše zato što sam imao problema s 10.12,nisam baš igrao ali sam odvrtio 3dmark vantage i score mi je bolji za oko 1000
11.1a
10.12
Zadnje izmijenjeno od: elina08. 20.01.2011. u 21:10.
Staro 20.01.2011., 22:43   #5
Starsailor
Starsailor's Avatar
Datum registracije: Jan 2011
Lokacija: CRO
Postovi: 219
Kakvih si problema imao sa 10.12 i 6870?
Ja ih imam podosta.
Starsailor je offline   Reply With Quote
Staro 21.01.2011., 05:52   #6
elina08
Seven
elina08's Avatar
Postovi: 97
Autor Starsailor Pregled postova
Ja ih imam podosta.
Dobro si to rekao podosta,nije baš da pretjerano igram zadnje vrijeme ali ono što igram zapinje zbog drivera.
Največi problem kod 10.12 je BSOD koji sam imao nekoliko puta dok je komp mirovao,kad nije to onda mi zaledi na minut,min. FPS na BBC2 je užasno loš s AA itd.
Staro 21.01.2011., 10:30   #7
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 6,997
Autor elina08 Pregled postova
Ja nikakvih problema na Sapphire 6850 Toxic, igram Warhammer Online, LOTRO, Dragons Age, Runes of magic i još par manje poznatih i starijih igara
Staro 21.01.2011., 12:55   #8
2 die 4
2 die 4's Avatar
Postovi: 2,240
Dali mi se isplati ići na ove drivere sa 5870?
RedGreenBlue
Staro 21.01.2011., 13:06   #9
PointDexter
PointDexter's Avatar
Lokacija: Éire
Postovi: 1,808
Autor 2 die 4 Pregled postova
Ako sam dobro shvatio to je hotfix koji koristi samo sa HD6800 karticama, tako da neću staviti ove drivere za sada
alien-smilies-0046.gif von smiliesuche.de
PointDexter je offline   Reply With Quote
Staro 21.01.2011., 14:16   #10
Starsailor
Starsailor's Avatar
Lokacija: CRO
Postovi: 219
Kad se ovo instalira, dal treba pobrisat stare ili je ok preko njih staviti?
Staro 21.01.2011., 21:30   #11
dzura
bla bla...
dzura's Avatar
Postovi: 244
ja sam prek starih stavil.....uvjek tak radim osim kad mjenjam karticu onda sve izbrisem dobro....
Staro 21.01.2011., 21:52   #12
23 Joke
Talični Tom
23 Joke's Avatar
Datum registracije: Dec 2010
Postovi: 87
@dzura normalno da imas isti fps 91 kad je to max po defaultu fps
upisi u consolu com_maxFps 250 pa ce ti biti lock onda na 250 npr.
23 Joke je offline   Reply With Quote
Staro 22.01.2011., 02:45   #13
dzura
bla bla...
dzura's Avatar
Postovi: 244
gle stvarno, nisam to znal......zakaj opce stavljaju taj cap? imam ja opce koristi od vecek fps obzirom da mi je monitor na 50hz?
Staro 22.01.2011., 12:33   #14
elina08
Seven
elina08's Avatar
Postovi: 97
Otkrio sam da kod ovog drivera se mogu postići bolji rezultati u dx11 testovima tako da se napravi ovo
3dmark 11 mi je na def. postavkama oko 43xx , s ovim 47xx, stock
heaven xtreme na def. 6xx s ovim 8xx, stock
Staro 22.01.2011., 13:01   #15
HCS
Premijum
HCS's Avatar
Postovi: 1,360
Bome pomaze gro, kak ti se ponasa s tim postavkama u DX9/10? To sad koristis za 24/7?
Ovo je vec ozbiljan rez
EDIT: Na istim frekvencijama prije ovog sam dobivao 5400, sad je evo 6000
Zadnje izmijenjeno od: HCS. 22.01.2011. u 13:17.
Staro 22.01.2011., 13:13   #16
d4rk_ch1ld
d4rk_ch1ld's Avatar
Lokacija: Krapinske Toplice
Postovi: 695
Baš me zanimaju prve analize ovih optimizacija, bit će rata sve mi se čini.
d4rk_ch1ld je offline   Reply With Quote
Staro 22.01.2011., 13:18   #17
elina08
Seven
elina08's Avatar
Postovi: 97
Ma bilo mi čudno ovo:Unigine Heaven OpenGL performance improves ~10% at moderate, 30% at normal and 100% at extreme tessellation levels
a nisam vidio baš neku razliku pa sam isprobavao i eto sad ćemo mi s AMD karticama biti bar malo više konkurentni u dx11 testovima.
Mislim da to ne utječe na dx10/9 mada još nisam probao , to sam tek danas isprobavao pa ne
znam za 24/7
Staro 22.01.2011., 14:05   #18
AlphaDog
AlphaDog's Avatar
Lokacija: Ri
Postovi: 37
Je, bit ćemo konkurentni s nižom razinom prikaza
AlphaDog je offline   Reply With Quote
Staro 22.01.2011., 14:31   #19
Antiša
Postovi: 147
Al ga seru. Poboljšanja u praksi su razmjera 3-4 FPS i 100-ak bodova više u 3DMarkovima.
Antiša je offline   Reply With Quote
Staro 22.01.2011., 15:27   #20
elina08
Seven
elina08's Avatar
Postovi: 97
Autor Antiša Pregled postova
Pa i nebi baš reko 100 bodova
3dmark 11
4853 | HD 6870 1020/1200MHz | i7 950@4.4GHz 10.12
5244 | HD 6870 1015/1200MHz | i7 950@4.0GHz 11.1a
i to s nižim taktvima grafe i proca
3dmark vantage
19693 | HD 6870 @ 1020/1200 | i7 950@4416MHz 10.12
20536 | HD 6870 @ 1015/1200 | i7 950@4.0GHz 11.1a
a znamo koliko 3dmark profitira od frekvencije proc.
Kad napravim rez. na istoj frekv. stavit ću tu.
Staro 22.01.2011., 17:21   #21
jopis
gadget freak
jopis's Avatar
Lokacija: Jasenovac
Postovi: 2,224
@HCS - s čim si dizao taktove? Ja u afterburneru uopće nemam u cfg fileu opciju za unofficial overclocking....
Btw meni je 3dm11 score veći za 300 bodova sa ovim driverima, sve stock.
4823score
http://3dmark.com/3dm11/485140
Zadnje izmijenjeno od: jopis. 22.01.2011. u 17:54.
Staro 22.01.2011., 18:02   #22
HCS
Premijum
HCS's Avatar
Postovi: 1,360
Autor jopis Pregled postova
4823score
Sa Asus Smart Doctorom samo za promjenu napona, a Afterburner za regulaciju frekvi i venta, imas u SDu onaj overclocking range enhancment, time ti se povecavaju granice na 1055/1625 u ABu, samo mislim da moras imati Asusov bios za to.
Staro 22.01.2011., 19:39   #23
Starsailor
Starsailor's Avatar
Lokacija: CRO
Postovi: 219
Baš mi sad frend govori da su njemu ovi novi driveri riješili sve probleme sa grafom (također 6870), ponajviše da je dobio na stabilnosti fps-a u svim igrama.
Staro 22.01.2011., 21:40   #24
cccp
cccp's Avatar
Datum registracije: Feb 2004
Postovi: 1,030
"Unigine Heaven OpenGL performance improves ~10% at moderate, 30% at normal and 100% at extreme tessellation levels"
Zadnje izmijenjeno od: cccp. 22.01.2011. u 21:46. Razlog: krivo skužio jedan post
cccp je offline   Reply With Quote
Staro 23.01.2011., 12:36   #25
2 die 4
2 die 4's Avatar
Postovi: 2,240
najs, šteta što ne naprave nešto slično i za ostale grafe a ne samo za 6xxx seriju!
RedGreenBlue
Staro 23.01.2011., 14:55   #26
Antiša
Postovi: 147
Serious Sam HD i dalje trza ko lud kad se uključi Anti-Alliasing (GPU Load - 6-7%, CPU Intel C2D 3Ghz), F1 2010 i dalje ima čudnih ponašanja i padova FPS-a, DiRT 2 i dalje radi lošije nego sa starijim driverima (mislim na 10.5 i starije), a bugova i dalje ima i HDMI na nekim karticama iz 5xxx serije neradi jednostavno.
