Staro 23.11.2010., 16:25   #1
pci_e3x
Premium spammer
pci_e3x's Avatar
Datum registracije: Aug 2010
Lokacija: D.Zagora
Postovi: 776
Nvidia ForceWare 263.09 WHQL driveri
What’s New in Version 263.09
-Added support for the GeForce GTX 580 and the GeForce GTX 460 SE.
-This driver package installs NVIDIA PhysX System Software v9.10.0514.
NVIDIA PhysX acceleration is available on all GeForce 8‐series, 9‐series, 100‐series,
200‐series, and 400‐series GPUs with a minimum of 256MB dedicated graphics
memory and a minimum of 32 processor cores.
-This driver package installs the HD audio driver, version 1.1.9.0.
Limitations in This Release
The following are features that are not currently supported or have limited support in
this driver release:
- Surround Gaming with 3‐way SLI
Surround gaming is not supported on a 3‐way SLI system using GeForce GTX 200
series GPUs.
- NVIDIA Control Panel Display Category
The Graph tab on the Adjust Desktop Color Settings page is not available.
- Hybrid Power
Support for Hybrid Power, a Hybrid SLI technology, is discontinued and not available
with this driver.
win7/vista 32bit:
Code:
http://www.nvidia.com/object/win7-winvista-32bit-263.09-whql-driver.html
a ostale:
Code:
http://www.nvidia.com/Download/index.aspx?lang=en-us
Staro 19.12.2010., 18:34   #2
doky
doky's Avatar
Datum registracije: Nov 2010
Postovi: 1,942
Kad odem na službene stranice i odaberem model i os izbaci mi 260.99, su ovi driveri povućeni ili šta?
Na ostalim stranicama tipa Guru3D i FileHippo ipak stoje kao posljednji 263.09.
doky je offline   Reply With Quote
Staro 21.12.2010., 04:22   #3
pci_e3x
Premium spammer
pci_e3x's Avatar
Lokacija: D.Zagora
Postovi: 776
Autor Anphonic Pregled postova
sada su WHQL12 (??)
Code:
http://www.nvidia.com/object/win7-winvista-32bit-263.09-whql2-driver.html
Staro 21.12.2010., 08:26   #4
Autor pci_e3x Pregled postova
sada su WHQL12 (??)
Code:
Skinuo i probao instalirat i izbacilo mi Bad Checksum a na official sajtu mi kao i kolegi iznad izbaci svaki puta one prijašnje od pred 2 mjeseca.
Staro 21.12.2010., 10:18   #5
geronimo_2
geronimo_2's Avatar
Lokacija: Rijeka / Grobnik
Postovi: 4,291
jel se meni cini il je u nVidia-i totalni kaos .
Staro 21.12.2010., 12:11   #6
Verbum
Postovi: 682
Piše lijepo ispod: "This is a WHQL-certified driver for GeForce GTX 570 and GeForce GTX 580."
Supported products:
GeForce 500 series:
GTX 580, GTX 570
Zadnje izmijenjeno od: Verbum. 22.12.2010. u 19:59.
Verbum je offline   Reply With Quote
Staro 21.12.2010., 12:22   #7
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Staro 21.12.2010., 21:19   #8
FitzTN
FitzTN's Avatar
Lokacija: Samobor, HR
Postovi: 1,615
Windows Update kaže da ima nova verzija, a nvidia da nema
Ludo sve
Staro 21.12.2010., 22:24   #9
pci_e3x
Premium spammer
pci_e3x's Avatar
Lokacija: D.Zagora
Postovi: 776
modificirani inf file s guru3da:
Code:
INF modified for Windows7 64bits
geforce 6 > GTX5XX
http://www.megaupload.com/?d=OCZ6R4E7
Staro 21.12.2010., 22:27   #10
MAGARAC
MAGARAC's Avatar
Postovi: 5,991
Ak netko ima zelju instalirat te drivere treba ih otpakirat u neki folder, isto to napravit sa nekim starijim driverom npr. 260.99 pa u njemu pronaci NV_DISP.INF koji se nalazi u Display.Driver folderu i koprat ga u Display.Driver folder u otpakiranom 263.09. Onda se normalno pokrene i normalno prode instalacija. Jos jednostavnije je pronaci taj .inf fajl u Nvida folderu kojeg driveri naprave na HDDu i kopirat ga u raspakirani 263.09.
Staro 21.12.2010., 23:34   #11
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
Ne kužim koji bog toliko žuriti s instalacijom novih drajvera...
Staro 21.12.2010., 23:37   #12
Romano.Cule
Outer Space
Romano.Cule's Avatar
Lokacija: Vinkovci
Postovi: 833
Mozda misli da ce dobiti 50 fps-a u BF BC2 ili Crysisu
Staro 21.12.2010., 23:56   #13
Venomgamer
Venomgamer's Avatar
Datum registracije: Sep 2010
Lokacija: Peljesac
Postovi: 293
Autor Dizel Pregled postova
Iz dosade,instalirao sam ih i ne primjecujem nista,ni dobro ni lose,sve mi radi isto............
Venomgamer je offline   Reply With Quote
Staro 26.12.2010., 11:54   #14
Ossir
Lokacija: Sveta Nedelja
Postovi: 21
Autor Venomgamer Pregled postova
Rijetko kad se nešto drastično promijeni...
Ossir je offline   Reply With Quote
