Zaključane teme
Staro 13.11.2010., 11:01   #1
zuiko
Postovi: 456
Oblivion ili The Witcher?
Koja je manje zahtjevna prema procesoru?
Imam A 64 X2 4200+, a to su jedine igre koje planiram igrati u idućih godinu dana pa...
Možda promijenim proc nakon što odigram prvu.
Fala!
zuiko je offline
Staro 13.11.2010., 11:41   #2
S3arch1ng
Lokacija: Međimurje
Postovi: 175
Po ovome ispada da je The Witcher zahtjevniji...Čini mi se da je i u stvarnosti tako, tj. koliko se sjećam imao sam oko 20-ak fps više na Oblivionu nego na Witcheru na otprilike istim postavkama. Uzmi u obzir da to ovisi od scene do scene i jasno o samim postavkama...
THE WITCHER
Minimum requirements:
Microsoft® Windows® XP Service Pack 2, Vista (Operating System must be up to date with the latest fixes)
Intel Pentium 4 2.4GHz or AMD Athlon 64 +2800
1 GB RAM for Microsoft® Windows® XP / 1536 MB for Microsoft® Windows® Vista
128 MB Video RAM or greater with DirectX9 Vertex Shader/ Pixel Shader 2.0 support (NVIDIA GeForce 6600 or ATI Radeon 9800 or better)
8.5 GB available hard drive space
DirectX 9.0c compliant soundcard, plus speakers or headphones
DVD-Rom
Recommended requirements:
Microsoft Windows XP Service Pack 2, Vista (Operating System must be up to date with the latest fixes)
Intel Core 2 Duo 2.13 GHz or AMD X2 5600+
2 GB RAM
NVIDIA GeForce 7900 GTX or ATI Radeon X1950 PRO
DVD-Rom
OBLIVION
Minimum System Requirements
Windows XP 64-bit, Windows XP, Windows Vista, Windows 7
2 GHz Intel Pentium 4 or equivalent processor
512 MB System RAM
4.6 GB free hard disk space
128 MB Direct3D compatible video card and DirectX 9.0 compatible driver;
8x DVD-ROM drive
DirectX 9.0c (included)
DirectX 8.1 compatible sound card
Keyboard, Mouse
Recommended
3 GHz Intel Pentium 4 or equivalent processor
1 GB System RAM
ATI X800 series, NVIDIA GeForce 6800 series, or higher video card
S3arch1ng je offline
Staro 13.11.2010., 11:59   #3
ddoxy
Lokacija: home
Postovi: 236
Oboje će ti ići sasvim u redu!
ddoxy je offline
Staro 13.11.2010., 12:16   #4
zhecky
Semper iratus
zhecky's Avatar
Lokacija: Solin
Postovi: 483
witcher je zahtjevniji od obliviona, al obje igre ce ti ici skroz u redu
zhecky je offline
Staro 13.11.2010., 14:29   #5
zuiko
Postovi: 456
Fala
al trza malo witcher i povremeno se pojavljuju linije kao da puca slika na uvodnom filmu na 1680x1050.
Al preživjet ću
zuiko je offline
Staro 13.11.2010., 14:48   #6
microsoft66
microsoft66's Avatar
Datum registracije: Apr 2008
Lokacija: VK
Postovi: 1,268
ma oblivion je igra iz 2006.i nemoze se mjeriti sa wičerom.sjecam se da je na mom a64 3200+ radila na najvisim detaljima
microsoft66 je offline
Staro 13.11.2010., 15:26   #7
De5tr0yer
Avocado
De5tr0yer's Avatar
Postovi: 7,856
Autor zuiko Pregled postova
Fala
Al preživjet ću
Uključi V-sync ili framelock.
Koliko je to moguće na početku, tj. na samom fimiću, ovisi o driverima. U njima imaš opciju forsanja vsynca.
Spoiler alert!
De5tr0yer je offline
Staro 13.11.2010., 19:15   #8
chare
Happy hippo
chare's Avatar
Lokacija: Cakovec
Postovi: 562
IMO oblivion je svakako bolja igra . S tim ofc necu reci da je witcher losa. al ako oblivion radi bez problema ( a trebao bi ) neka odigra prvo to. Dosta je duga igra ako ne igras na najlaksem.
chare je offline
Staro 13.11.2010., 19:39   #9
Tarjan
Tarjan's Avatar
Datum registracije: Jun 2004
Postovi: 94
Autor chare Pregled postova
Ne dijelim tvoje misljenje, witcher mi je kud i kamo zanimljiviji bio. Oblivion mi je postao strasno naporan nakon nekog vremena, izgubio sam volju istrazivati po bezbrojnim i jednolikom vratima. Sto se performansi tice, obje su mi podjednako dobro isle sa time sto sam pozabavio sa ini fajlom obliviona.
Sa oblivionom sam se malo zeznuo posto nisam odmah krenuo sa glavnim questom nego sam istrazivao pa dok sam dosao do glavnog questa svi neprijatelji koji se pojavljuju su bili jednaki zbog (po meni) blesavog sistema leveliranja po kojemu nema nemoguce ili prelake borbe. Morrowind mi je po tome pitanju bio puno bolji. Bilo me strah proviriti u neka mjesta jer bi mogao pasti mrtav u sekundi.
baaaa baaaa ba ba
Tarjan je offline
Staro 14.11.2010., 09:36   #10
zuiko
Postovi: 456
Fala svima
zuiko je offline
Staro 14.11.2010., 10:17   #11
zuiko
Postovi: 456
Uključio sam. Bolje je
Fala
zuiko je offline
Staro 14.11.2010., 11:32   #12
zuiko
Postovi: 456
Ako ne tražim previše, može li mi netko reći koja je potpuna verzija Obliviona, sa svim dodacima, ako postoji?
Fala
zuiko je offline
Staro 14.11.2010., 12:21   #13
Ordem
Datum registracije: Sep 2010
Lokacija: Vk
Postovi: 572
Fala
goty release :?
btw ja bih izmedju te 2 igre izabrao oblivion
cisto zbog expanzija i pun k modova koji su izasli u medjuvremenu
mozes i instalirati ultra texture pa ce i grafika biti bolja
Ordem je offline
Staro 14.11.2010., 13:56   #14
zuiko
Postovi: 456
Fala!
Pokušat ću nabavit. The Witchera već imam.
LP
zuiko je offline
Staro 20.11.2010., 09:51   #15
zuiko
Postovi: 456
Može li mi netko posuditi upute za igru. Nabavio sam Oblivion GOTY ali nema uputa pa...
zuiko je offline
Staro 03.12.2010., 00:21   #16
piydek
piydek's Avatar
Postovi: 375
Autor microsoft66 Pregled postova
Ako je Oblivion nalik na Morrowind u pogledu enginea (znam da je isti, ali možda je optimiziran?), onda je to jebada za CPU. Morrowindu je čak i X2 4600+ bottleneck jer jednostavno se oslanja u većini stvari na CPU, a GPU ga ne yebe.
Inače, The Witcher je beskonačno bolja igra. Al kome se da zezati sa Bethesdinim infantilnim narativima i dijalozima te prelošim dizajnom questova i svijeta, samo naprijed.
piydek je offline
Staro 05.12.2010., 18:09   #17
burmuz
burmuz's Avatar
Lokacija: Bjelovar
Postovi: 464
Osobno Oblivion. Ako želim priču, čitam knjigu. Ako se igram, želim akciju i lootanje. No, to je osobni stav
burmuz je offline
Zaključane teme
