Staro 26.10.2010., 19:09   #1
Doink the Clown
Jack of all, master of none
Doink the Clown's Avatar
Lokacija: Matulji - Rijeka
Postovi: 6,214
Enermax LuxuRay
Novo kućište iz Enermaxa, lijepo i cijenom pristupačno. Tko zna hoće li uopće stići kod nas a ako i bude dobavljivo cijena će biti prenapuhana to je sigurno.
Enermax Intros LuxuRay ATX Mid-Tower Case to the Market
Enermax released the LuxuRay ATX mid-tower chassis to the market. Its styling includes a piano-black front, all-black interiors, with use of SECC steel and plastic, mainly. An Apollish Vegas multi-color fan decks up the front, with a variety of color settings. The drive bays are tool-free, and expansion slot covers replaceable. There are holes on the motherboard tray for cable and CPU cooler management. The case measures 470 x 200 x 445 mm. Ventilation includes one 120 mm front intake, and slots for one 120 mm rear, two 120 mm side and one 120 mm top fans. The utility panel on the front includes USB 2.0, audio and eSATA ports. The LuxuRay is priced at US $69.
http://www.techpowerup.com/img/10-10-26/134a.jpg
http://www.techpowerup.com/img/10-10-26/134b.jpg
http://www.techpowerup.com/img/10-10-26/134c.jpg
http://www.techpowerup.com/img/10-10-26/134d.jpg
izvor:
http://www.techpowerup.com/133390/En...he-Market.html
C L O W N I N G A R O U N D
Zadnje izmijenjeno od: Doink the Clown. 26.10.2010. u 19:41.
Staro 26.10.2010., 20:11   #2
Postovi: 8,194
Al će se packe lijepit, al sviđa mi se. Da bude po toj cijeni, definitvno best buy. Crna unutrašnjost je svakako plus, napajanje je dolje... Da ne spominjem da se vent prodaje po 28$ xD
Staro 26.10.2010., 22:42   #3
SetH
SetH's Avatar
Lokacija: ZG/Borongaj
Postovi: 3,324
iskreno meni ružno a i TT ima takvih sličnih v3,jel
SetH je offline   Reply With Quote
Staro 28.10.2010., 22:47   #4
čigra
zappa
čigra's Avatar
Datum registracije: Oct 2010
Postovi: 48
uf, sviđa mi se, ako dođe u nas moga bi ga i uzet
čigra je offline   Reply With Quote
Staro 28.10.2010., 23:35   #5
ThePornstar
ThePornstar's Avatar
Postovi: 4,399
Ma to volim. Minimalizam uz dozu elegancije =)
Znači kod nas bi očekivana cijena bila oko 500 kuna.
CPU: Intel i5 8250u
RAM: 16 GB
VGA: Intel UHD 620
OS: Win 10 Pro x64
Battery: 57 Wh internal
ROM: Android 9
