Postovi: 2
Mišljenja, molim!
Periferne jedinice: Miš Logitech B58, optički, crni - 92,09 KN, 86,21 KN Tipkovnica Logitech UltraX Flat Desktop - 200,63 KN, 187,83 KN Monitor 19" Samsung 959NF, 110 kHz, 0.25mm, NaturalFlat - 2.140,77 KN, 2.004,13 KN Komponente: DVD±RW PIONEER DVR-109, 16x, black, Dual layer ± recording, bulk - 489,19 KN, 457,97 KN Napajanje TAGAN 420W, Super Silent, TG420-U01, aut.reg.brzine, S-ATA power cable - 665,13 KN, 622,68 KN VGA PCI-E LEADTEK PX6600GT Extreme, GeForce PCX 6600GT, 128MB, DVI, TV - 1.907,92 KN, 1.786,14 KN Kućište THERMALROCK Dragon, MIDI, black, Metal, bez PS - 754,09 KN, 705,95 KN RAM PC-3200, 1024MB, DDR, Corsair C2, KIT, TwinX, DDR 400 MHz, 2 x 512MB - 1.450,61 KN, 1.358,02 KN MBO DFI LAN PARTY UT nF4 Ultra-D, DDR, zvuk, S-ATA, FW, 2xG-LAN, PCI-E, s. 939 - 1.311,62 KN, 1.227,90 KN CPU AMD Athlon64 3200+ BOX, socket 939, Winchester,2000MHz, 512kb c., FSB 800MHz - 1.554,26 KN, 1.455,05 KN HDD 80.0 GB SEAGATE, NCQ, 8MB cache, Serial ATA Plus - 470,39 KN, 440,36 KN Ukupno: 11.036,70 KN, 10.332,23 KN ...Sve iz Linksa!... ![]() |
Eddie
Postovi: 5,507
Čemu će služiti taj komp. Mislim da bi se mogli iskombinirati drugi hard i memorija... Možda LG monitor...I DVD-Rom za On The Fly...
Postovi: 621
periferiju nisam gledao..ali bi mogao drugi hard i mozda malo jaca graficka..nravno ako ima dosta love u budgetu |
Datum registracije: May 2005
Lokacija: Vinkovci
Postovi: 11
asa
Uzmi barem 160 GB HD jer manje nije fora znam iz iskustva . i napajanje od oko 600W . TO bi ti bilo super :::
AMD Athlon XP-A 2600+, 1913 MHz - max. 3000 MHz(11.5*166), 1.6V ASUS A7N8X-E Deluxe ACPI BIOS Rev 1012 AMD ASUS A7N8X-E DELUXE Socket A,nVidia nForce2 Ultra400+MCP- T, DDRAM, AGP8X, APU Audio/Dolby, Marvel Gb+NVIDIA 10/100LAN, Post Reporter, IEEE1394, S/PDIF Out interface, Serial ATA , WI-FI Slot, WinDWD, CPU AMD 2600 ATHLON, COOLER FOR CPU, RAM DDR 256MBx2 PC3200 400, VGA AGP ATI RADEON 9600, WDC WD1200JB 120GB 7200 8MB (IDE), CASE MIDI TOWER ATX PRO, OPT DVD ROM, OPT CD-RW 52X, WinXP SP2 CRO Stana.blog.hr |
#7 | |
JDM
Datum registracije: Sep 2004
Postovi: 6,137
Re: asa
SPAMERU ![]() |
#8 | |
Džabe si krečio!
Postovi: 5,190
Re: asa
Koj je tebi vrag? Aj se vrati spamat na blogove, tamo moš kolko oš'. Tagan 420 W je idealno napajanje za ovu konfu. ![]() |
Postovi: 2,458
Uzmi jos jedan DVD citac za 170-200Kn, vjeruj mi kad pocnes snimati cd/dvd bit ce ti puno komotnije od samo jednog optickog uredaja... Ovako mi djeluje kao konfiguracija za oc cija je najslabija karika graficka kartica i u tom pogledu mislim da nije dovoljno izbalansirana konfiguracija... Takva snaga ti ocito treba za sto ugodnije igranje (inace bi trazio drugacije rjesenje) i onda stedis na najvaznijem elementu GPU-u... U ovako poslozenoj konfiguraciji ces nakon oc-a imati nekih 10% bolje perfomanse od slicne (nakon oc iste naravno) slozene za kakvih 6500Kn... Jednostavno smatram (IMO) da konfiguraciju od >10k Kn mora pogoniti napredniji graficki sustav (6800GT)... |
#11 | |
Postovi: 9,067
Re: asa
uzmi 160 jer manje nije fora...kakav je to razlog za kupiti disk? jer nije fora... a i jebalo te iskustvo i hdd od 160gb. i jedna mala centrala za pogoniti 9 grafickih u sli modu i 4 procesora? 600w? cak i da se zajebevash, nisi nimalo humoristican.
___________ Just atha x |
#12 | |
Dark side Moderator
Postovi: 1,633
Re: Re: asa
Sto jest jest mali je uporan al uci, stavio je link za blog u sig, sad jos samo da NESPEMA S GLUPIM ATTACHIMA bilo bi ok! ![]()
Jak ko rakija! |
#13 | |
Postovi: 2,458
Re: Re: Re: asa
Steta sto nije napisao i boju pojedinih komponenti, sto sve misli kupiti u buducnosti, citate iz svog bloga, kratak zivotopis.... Sorry zbog OT no morao sam! |
#16 | |
the luda ribetna
Postovi: 3,952
tip mi je polako(ali sigurno) isao na zivac koji nije bas najjaci ![]() |
#17 | |
Dark side Moderator
Postovi: 1,633
Jak ko rakija! |
