Staro 25.10.2010., 12:56   #1
Core2Duo22
Mucki provokator
Core2Duo22's Avatar
Postovi: 299
Nvidia ForceWare 260.99 WHQL driveri
x64 Win7/Vista XP
x32 WIn7/Vista XP
This is the second WHQL release from the Release 260 family of drivers. You can read about the major new features and performance improvements in the Release 260 family of drivers here. This driver package supports GeForce 6, 7, 8, 9, 100, 200, 300, and 400-series desktop GPUs as well as ION desktop GPUs.
New in Release 260.99
  • Increases performance vs. v260.89 drivers in the following PC games: Civilization V (SLI), Fallout 3, Final Fantasy XIV and F1 2010 (DX11).
  • Adds SLI profiles for the following PC games:
    • Need for Speed: Hot Pursuit
    • Star Wars: The Force Unleashed II
    • Fallout: New Vegas
  • Improves compatibility for Fallout 3: New Vegas with antialiasing enabled.
  • Improves Alt-Tab compatibility for several PC games.
Additional Information
  • Installs HD Audio driver to version 1.1.9.0.
  • Includes PhysX System Software to version 9.10.0514.
  • Supports the new GPU-accelerated features in Adobe CS5.
  • Supports GPU-acceleration for smoother online HD videos with Adobe Flash 10.1. Learn more here.
  • Supports the new version of MotionDSP's video enhancement software, vReveal, which adds support for HD output. NVIDIA customers can download a free version of vReveal that supports up to SD output here.
  • Supports OpenCL 1.0 (Open Computing Language) for all GeForce 8-series and later GPUs.
  • Supports OpenGL 3.3 for GeForce 8-series and later GPUs.
  • Supports OpenGL 4.1 for GeForce 400 series GPUs.
  • Supports single GPU and NVIDIA SLI technology* on DirectX 9 and OpenGL.
  • Supports GPU overclocking and temperature monitoring by installing NVIDIA System Tools software.
  • Users without US English operating systems can select their language and download the International driver here.
*Note: The following SLI features are only supported on Windows Vista and Windows 7: Quad SLI technology using GeForce 9800 GX2 or GeForce GTX 295, 3-way SLI technology, Hybrid SLI, and SLI multi-monitor support.
Novih nije bilo 3 mj, i onda u 10 dana dvije verzije
Core2Duo22 je offline   Reply With Quote
Staro 25.10.2010., 16:26   #2
geronimo_2
geronimo_2's Avatar
Lokacija: Rijeka / Grobnik
Postovi: 4,450
pisu da vegas nesto bolje ide snjima.
neke stvari jos stekaju pa bacite oko na guru i nvidia forum.
poz.
geronimo_2 je online   Reply With Quote
Staro 27.10.2010., 01:38   #3
T0mB1ll
420
T0mB1ll's Avatar
Lokacija: Le Molve
Postovi: 1,577
hmm.. kad uštekam usb stik, i kad se čuje zvuk, slika flasha, tj, onako kao dok se instaliraju driveri.. znači, zacrni se i odmah upali..
ista stvar sa bilo kojim usbom.. odspojim miš, ukopčam, opet slika flasha..
do instalacije ovog drivera toga nije bilo..
T0mB1ll je offline   Reply With Quote
Staro 27.10.2010., 02:04   #4
MAGARAC
MAGARAC's Avatar
Postovi: 5,995
Cesto i kod atija i kod nvidije.
Staro 27.10.2010., 19:41   #5
T0mB1ll
420
T0mB1ll's Avatar
Lokacija: Le Molve
Postovi: 1,577
danas se to ne događa, win update mi skinuo novi driver za bluetooth i sad više nema flashanja.. čudno.
Staro 13.12.2010., 15:21   #6
Gigi1
Postovi: 2,138
Prekjucer sam stavio ove drivere i komp mi se poceo rusiti, svakih 2-3 sata se pojavi BSOD, windbg kaže sljedece:
BugCheck 7F, {8, 80050031, 6f8, fffff8000309dec8}
Probably caused by : ntkrnlmp.exe ( nt!KiDoubleFaultAbort+b2 )
Do sada je sve bilo ok, no nakon instalacije navedenih drivera minimalno 5 bsod-a tokom dana...
Ima li još netko sa slicnim problemom, i dali znate neki trik kak da to riješim(osim stavljanja drugih drivera).
Staro 17.12.2010., 15:39   #7
Romano.Cule
Outer Space
Romano.Cule's Avatar
Lokacija: Vinkovci
Postovi: 836
Da,na nvidinom forumu imas temu o tim drajverima.Puno problema i malo dobroga,stavi si najnoviju betu
Tema
Driveri
Staro 17.12.2010., 15:51   #8
alengrosevic
alengrosevic's Avatar
Postovi: 3,791
ili probajte 261.00 betu...
LINK
Staro 19.12.2010., 16:09   #9
kripton
Cars & Tunning
kripton's Avatar
Lokacija: Vukovar - Rijeka
Postovi: 536
Pitanjce. Svaki driver poslije 258.96 mi iskljuci 'wide' opciju tijekom igranja.
Radi se o jednoj staroj igri (Birth of Federation iz 1999) koja je radila bez problema sa 258 driverom u wide-u. Zanima me sad moze li se to ikako rijesiti tj. namjestiti u nvidijinom control panelu?
Ili cu jednostavno morati koristiti 258.
NovA Squadron
kripton je offline   Reply With Quote
Staro 19.12.2010., 17:30   #10
Ati freak
aka Striko
Ati freak's Avatar
Lokacija: Krapina - Zagreb
Postovi: 1,756
Autor kripton Pregled postova
Ko da ces s novijim driverima nešto dobiti u igri staroj 10 godina ? lol, na 8800GT......
Još može samo gore biti na novim driverima
Staro 19.12.2010., 20:58   #11
kripton
Cars & Tunning
kripton's Avatar
Postovi: 536
Nisam stavio drajvere zbog dobivanja frejmova-a, vec redovito stavljam nove drivere.
NovA Squadron
Staro 20.12.2010., 15:11   #12
Romano.Cule
Outer Space
Lokacija: Vinkovci
Postovi: 836
Ja sam skuzio da novi driveri redovito donose masu problema umjesto da je obrnuto.Uvijek nesto ne radi kako treba.Ako im je problem sloziti unificirane drajvere za sve graficke neka izdaju drajvere za svaku seriju posebno.Ovako sjebu sve ostale samo vlasnici serije 5 imaju poboljsanja,a svi ostali puše i imaju masu problema.
Staro 20.12.2010., 16:13   #13
fran123456
Premija
fran123456's Avatar
Datum registracije: Mar 2009
Postovi: 1,634
Nikakvih problema sa GTX460 i GTX480.
fran123456 je offline   Reply With Quote
