#1 | |
Lokacija: Rijeka / Grobnik
Postovi: 4,390
Nvidia ForceWare 260.63 beta driveri
Nvidia ForceWare 260.63 beta driveri Changelog: Citiraj:
Download: Forceware 260.63 Win Vista | 7 (64-bit) Forceware 260.63 Win Vista | 7 (64-bit) Forceware 260.63 Windows XP (32-bit) pozdrav. izasli 260.63. na guru-u dosta problema spominju. najvise me brine: "HDMI it looked washed out as if the gamma was too high". jel probao netko? ![]() edit: hm, ovo zvuci jos gore: "i Had many bsod using my 46'' HD TV thru HDMI" edit2: hvala razer ![]() Zadnje izmijenjeno od: geronimo_2. 14.09.2010. u 11:14. |
Postovi: 4,390
hm, "I have 2 Palit GTX 460 2GB in SLI, one of the cards has no problems with the 260.63 drivers on its own, but the other card will lock-up windows and show severe artefacts on the windows welcome screen, it will also lock up windows if i use the working fine card as primary and switch on SLI. These cards are identical (brought at the same time), so it might not even be an issue with all Palit GTX 460s but a only a few. I spoke to my supplier and they said that if the issue is still present once these drivers go WHQL (or whatever the next driver version is that goes WHQL) then return it as a faulty card for replacement. I have a suspicion that this could be an obscure hardware fault showing up in certain palit/gainward GTX 460 cards that the drivers have exposed. Both cards had zero problems with the 258 official drivers. I forgot to add that the working card works fine with both pci-e x16 slots, yet the other doesn't work in either with the 260.63s, so i don't think its a compatibility issue with the motherboard and graphics card on this driver. I have also contacted Palit and Gainward support emails on this matter for more information, hopefully they'll figure out the problem. " I smell trouble ![]() moguce lose vijesti za Palitaše i Gainwardaše :-(. |
