Staro 04.09.2010., 15:45   #1
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
How To Fix The PCI Express x1 Bug Rev. 3.2
Zapelo mi za oko kak se par nesretnika na forumu žale na ovaj problem pa nek probaju
User of ASUS and Gigabyte motherboards (maybe others as well) may be affected by a PCI Express x1 bug which causes a tremendous drop in performance. ChampionLLY takes a look at the motherboards and graphics cards affected by this problem and what solutions work, and what doesn’t.
In the second part, he takes a look at the effect that PCI Express x1 bug has on the performance of your system. The results will shock you.
Here are the latest updates in Revision 3.2 :-
- Added three new motherboards and four new graphics cards to the list of affected hardware.
- Added two new methods on how to fix the PCI Express x1 bug.
http://www.techarp.com/showarticle.aspx?artno=522
