Staro 28.07.2010., 15:40   #1
Skorn
Skorn's Avatar
Postovi: 604
novi 30" +30- bit monstrum od HP-a
http://nexus404.com/Blog/2010/07/28/...tion-for-1300/
http://www.engadget.com/2010/06/02/h...on-colors-and/
http://h10010.www1.hp.com/wwpc/us/en...1-4194577.html
ukratko:
HP ZR30W
Display size (diagonal)
30"
Resolution
2560 x 1600
Display pixel
0.2505 mm
Brightness (typical)
370 cd/m²
Contrast ratio (typical)
1000:1
Viewing angle
178° horizontal; 178° vertical
Response rate (typical)
7 ms
Input signal
DisplayPort; DVI-D
Bezel color
Black
Tilt and Swivel angle
Tilt: -5° to + 35°; Swivel: -45º to + 45º
Interface and performance features
Anti-glare
Anti-static
Plug and Play
I/O Ports
5 USB 2.0
Physical security
Security Lock-Ready
Dimensions and weight Weight
28.6 lb (13 kg)
Dimensions (W x D x H)
27.3 x 3.4 x 17.9 in (69.4 x 8.7 x 45.4 cm)
Dimensions with stand (W x D x H)
27.3 x 10.9 x 23.3 (69.4 x 27.6 x 58.9 cm)
Power and operating requirements Power supply
Input power: 100 to 240 VAC
Power consumption
185 W maximum; 130 W typical
Power consumption (standby)
<2 W
Operating temperature range
41 to 95º F (5 to 35º C)
Operating humidity range
10 to 80 %
What's included Warranty
Three years parts, labor, and on-site service. 24-hour, 90-day, toll-free technical support. Certain restrictions and exclusions apply. For details, contact HP Customer Support.
cijena ista kao i prethodnom modelu, korišten aluminij u izradi bezela (kod HP LP 3065 modela je plastika), još uvijek nema HDMI
~ Reductio ad Absurdum ~
igre za PS ONE / PS2 koje me zanimaju
Skorn je offline   Reply With Quote
Staro 30.04.2012., 11:02   #2
Gilbert5
Agent 0
Gilbert5's Avatar
Lokacija: Kutina - ZG
Postovi: 4,312
Ima li tko ovaj monitor? Mogu ga nabaviti za nešto manje love, pa me zanima isplati li se imati ovakvu grdosiju na stolu? Imam neki subjektivan dojam da je 30" preveliko. Nisam nikada ni vidio 2560x1600 rezoluciju iskreno.
S time da ne radim ništa pametno na kompu, grafička bi bila neka od novijih nvidia.
Staro 30.04.2012., 18:24   #3
Rista
Rista's Avatar
Lokacija: Ri
Postovi: 1,923
30" 16:10 za nesto manje love, uff Jedini problem koji vidim za te potrebe je wide gamut bez sRGB emulacije i potpuni nedostatak OSD-a na ovom HP-u.
Staro 30.04.2012., 18:30   #4
zwer
crnjo
zwer's Avatar
Postovi: 1,907
Autor Gilbert5 Pregled postova
Isplati. 30" nije preveliko, nego je sve ostalo premalo kad se naviknes. Stvar je perspektive, vlasnik iPhonea ce rec da je njegov 3.5" ekran taman, a 4.7" preveliko, a vlasnik 4.7" mrcine ce rec da se ni mrtav ne bi vratio na taj gameboy
Kupuj. Ako mene pitas, to mi je bila najbolja kupovina hardvera u zadnjih 4.5 godine.
9900K-32GB-5TB-3060TI
zwer je offline   Reply With Quote
Staro 30.04.2012., 19:06   #5
Fleks
JDM
Fleks's Avatar
Datum registracije: Sep 2004
Postovi: 6,137
Ja bi uvijek rađe 2x22" ili 2x24" nego ovo.
E sad ako ne radiš ništa pametno i komp ti sluzi između ostalog za filmove, onda mozda i ovo nije loša ideja.
Makar i ovo što zwer kaže nije daleko od istine (osim onih cudaka koji stavljaju tablete po faci po javnim površinima - tabletizmičari )
Koliko je to malo para za sto ga mozes dobiti?
Staro 30.04.2012., 19:12   #6
Gilbert5
Agent 0
Gilbert5's Avatar
Postovi: 4,312
A ne znam ni sam, tj znam da mi ne treba. Moj l220X mi je i prevelik. Iako ono, zašto ne. Vjerujem da bi se brzo naviknuo.
Ne znam još cijenu, ima više faktora što utjecu. Ali bila bi negdje oko 5-5500 kn.
Staro 30.04.2012., 19:17   #7
Fleks
JDM
Fleks's Avatar
Postovi: 6,137
Za taj novac mozes prodati taj monitor koji imas kupiti klasu bolji i ostane ti para za dobar TV. Onda imas dobar monitor + velki tv za serije/filmove.
ili
potrošiti pare na kurve, drogu i alkohol
Staro 30.04.2012., 19:39   #8
zwer
crnjo
zwer's Avatar
Postovi: 1,907
Ja za te pare ne bi ni razmisljo. Ali opet, ja sam svoj isplatio jedno 7-8 puta minimalno od kad ga imam, pa mi je perspektiva drugacija. Ali znaj jedno, na 2x24" nemres igrat igre preko oba (ok mozes, ali rijetke). Na 1x30" si kralj na tronu gaminga
Staro 30.04.2012., 21:04   #9
listerstorm
listerstorm's Avatar
Datum registracije: Apr 2011
Postovi: 1,430
Negdje pročitah da bi viewing distance trebao biti ne manji od 1,3 dijagonale monitora.
Ja sam na nekih 55-60 cm od 24` displaya što ispada preblizu.
Staro 30.04.2012., 22:00   #10
sodom
sodom's Avatar
Postovi: 593
@Gilbert5 ako ne znaš za što bi točno upotrijebio takav monitor moja preporuka bi bila da sačuvaš novce
@zwer
gameo sam više puta na 30" (između ostalog i na ovom iz naslova) i definitivno me to nije osvojilo, za manje love složi se 3x monitor setup koji daje puno bolje igrače iskustvo, osječaj okruženja, veću rezoluciju, veći field of view... 30" po meni samo za profi uporabu
sodom je offline   Reply With Quote
Staro 30.04.2012., 22:13   #11
Doink the Clown
Jack of all, master of none
Doink the Clown's Avatar
Lokacija: Matulji - Rijeka
Postovi: 6,214
Autor Fleks Pregled postova
Od svega navedenog, ovo je još najbolji prijedlog.
C L O W N I N G A R O U N D
Staro 30.04.2012., 22:28   #12
B-Link
B-Link's Avatar
Lokacija: Popovača
Postovi: 481
Ja imam 40" tv kao monitor, a udaljen sam normalno oko 50cm od ekrana, znaci klasicna udaljenost...i nije mi preveliko, vec mi je taman, tako da ovaj monitor sigurno nije prevelik...
B-Link je offline   Reply With Quote
Staro 30.04.2012., 22:55   #13
nathan
IT Consultant
nathan's Avatar
Lokacija: Geneva, Petit-Lancy / Zagreb , Dubrava
Postovi: 323
Ja radim na 27", 90% na njemu radim za posao, ponekad bacim fifu12 i mogu ti reci da je zwer u pravu, imao sam nekada 20", pa 24" pa sada 27" i ne zalim ni lipe kolko sam ga platio, a ne bih se sada vracao natrag na manji nema sanse...
nathan je offline   Reply With Quote
Staro 01.05.2012., 01:08   #14
Rista
Rista's Avatar
Lokacija: Ri
Postovi: 1,923
2560x1600 jest dozivljaj za sebe, ali kad malo razmislim za 5500kn moze se dobiti 3 nova U2412M. Za razliku od 16:9 monitora nisu presiroki u landscape a preuski u portrait modu u 3x setupu. I jos su sRGB. No istina to se cini kao totalni overkill, kao i ZR30w uostalom za te potrebe
Staro 01.05.2012., 01:56   #15
listerstorm
Postovi: 1,430
ili
A tko zna, s obzirom da je recesija, možda bi se dalo u taj budget utrpati i bolji monitor, TV i dio od zadnjeg.
