Povratak   PC Ekspert Forum > Računala > Software > Web dizajn, programiranje i ostalo
Staro 24.07.2010., 14:04   #1
malixx
Postovi: 76
Batch - pomoć
Pozdrav svima,
trebao bi pomoću batch skripte napravit da mi se brišu svi fileovi *.tgt u svim mapama, za sada mi se brišu samo u jednoj mapi.
Znači želim da mi "pročešlja sve mape" koje su u tom folderu i izbriše ovo iz njih što je zadano..
Zaboravio sam kako ide, al mislim da se samo doda jedno slovo iz "del"..
evo ovako izgleda to kod mene:
Code:
@ echo off
del "C:\Program Files\Steam\SteamApps\common\railworks\Assets\RsDany\DanyObjekti\RailNetwork\Signals\Shuntsignal\*.tgt"
malixx je offline   Reply With Quote
Staro 24.07.2010., 16:16   #2
domy_os
domy_os's Avatar
Postovi: 18,929
C:\Users\Domy>del /?
Deletes one or more files.
DEL [/P] [/F] [/S] [/Q] [/A[[:]attributes]] names
ERASE [/P] [/F] [/S] [/Q] [/A[[:]attributes]] names
names Specifies a list of one or more files or directories.
Wildcards may be used to delete multiple files. If a
directory is specified, all files within the directory
will be deleted.
/P Prompts for confirmation before deleting each file.
/F Force deleting of read-only files.
/S Delete specified files from all subdirectories.
/Q Quiet mode, do not ask if ok to delete on global wildcard
/A Selects files to delete based on attributes
attributes R Read-only files S System files
H Hidden files A Files ready for archiving
I Not content indexed Files L Reparse Points
- Prefix meaning not
If Command Extensions are enabled DEL and ERASE change as follows:
The display semantics of the /S switch are reversed in that it shows
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 24.07.2010., 16:34   #3
malixx
Postovi: 76
Hvala
