Staro 21.06.2010., 19:13   #1
Vendetta
Vendetta's Avatar
Postovi: 919
Exclamation (riješeno) Outlook-Exchange, problem primanja mailova
Evo i ja imam problem s Outlookom 07' i Exchangeom 2003.
Naime imao sam slican problem kao kolega Guls u ovoj temi ali meni je outlook prilikom pokretanja javljao ovaj error: "Cannot Open your Default e-mail Folders, You must connect to microsoft exchange with the current user profile before you can synchronize your folders with your offline folder file"
To sam rjesija na slj. nacin:
  1. Click Start, click Run, type regedit in the Open box, and then click OK.
  2. Locate and then click the following subkey: HKEY_CURRENT_USER\Software\Microsoft\Office\12.0\Outlook\RPC
  3. On the Edit menu, point to New, and then click DWORD Value.
  4. Type DefConnectOpts, and then press ENTER.
  5. Right-click DefConnectOpts, and then click Modify.
  6. In the Value data box, type 0, and then click OK.
  7. Exit Registry Editor
Sada taj user moze uredno slati mailove, ali primati mailove moze samo od ljudi unutar mreze (oni takodjer imaju mailove preko exchangea), dakle kada posaljem mail recimo sa Gmaila dobijem odmah natrag mail:
Delivery to the following recipient failed permanently.
Technical details of permanent failure:
Google tried to deliver your message, but it was rejected by the recipient domain. We recommend contacting the other email provider for further information about the cause of this error. The error that the other server returned was: 550 550 No such user (xxx.xxx) -ERR xxx.xxx@xxx-xxx.hr not found (state 14).
Dok ja googlam, zna li netko moguce rjesenje ?
Zadnje izmijenjeno od: Vendetta. 22.06.2010. u 15:31.
Vendetta je offline   Reply With Quote
Oglas Oglasni prostor
