Staro 27.03.2005., 15:16   #1
Problem
Pijem samo KAJ
Problem's Avatar
Lokacija: Vž
Postovi: 2,692
Asus 6600td
ASUSTek , GeForce 6600, AGP8x, 256MB DDR3 128-bit DDR, DVI, TV-out, engine clock 500MHz, memory clock 900MHz, RAMDAC 400MHz, max resolution 2048x1536, 15-pin D-sub, 2nd VGA output, Adaptor/Cable bundled: DVI-to-2nd VGA adaptor
Jel se splati? Meni izgleda dosta jeftino. Šta je to RAMDAC uopšte?
Staro 27.03.2005., 16:07   #2
Crash009
Crash009's Avatar
Lokacija: Orahovica
Postovi: 7,363
Da samo nisi napisao cijenu..
RAMDAC " Short for Random Access Memory Digital-to-Analog Converter, a single chip on video adapter cards. The RAMDAC's role is to convert digitally encoded images into analog signals that can be displayed by a monitor. A RAMDAC actually consists of four different components - SRAM to store the color map and three digital-to-analog converters (DACs), one for each of the monitor's red, green, and blue electron guns."
google...
Staro 27.03.2005., 19:19   #3
Problem
Pijem samo KAJ
Problem's Avatar
Lokacija: Vž
Postovi: 2,692
1380 kn
Staro 28.03.2005., 00:07   #4
JC Denton
dr. sc. tech. dipl. ing.
JC Denton's Avatar
Lokacija: Rijeka-Opatija
Postovi: 3,165
Originally posted by Problem
1380 kn
Cekaj..ako sam dobro shvatio...to je 6600GT AGP (GPU 500 / MEM 900) sa 256MB DDR-a za 1380kn? Meni se to cini ko dobra kupnja ako kupujes grafu za tu lovu.
Samo stalno se pitam..what's the catch?
Staro 28.03.2005., 00:43   #5
.: Tyrael :.
Archangel Of Light
.: Tyrael :.'s Avatar
Lokacija: Kraljevica
Postovi: 326
Mora da je nek greška, ASUS 6600TD radi na GPU:300,MEM.500MHZ.. nikako na 500,900MHZ (to su frekve od GT)...
Provjeri malo to, TD i GT nije niti slicno..
TD kartice su inače od 1100-1300kn... tako da su vjerovanto neš pomiješali...
"Old programers never die. They GOSUB and never RETURN."
.: Tyrael :. je offline   Reply With Quote
Staro 28.03.2005., 16:57   #6
JC Denton
JC Denton's Avatar
Postovi: 3,165
Pa da, brijem da je neki zajeb u logici... to bi bila neka od skupljih obicnih 6600 sa 256MB RAM-a. A frekva meme sigurno nije 900 Iako.. bilo bi cool da je to neka 6600 na 300 / 900.. bas me zanima kako bi se to ponasalo
