Staro 26.05.2010., 20:20   #1
Sa_Stilom
Sa_Stilom's Avatar
Postovi: 2,717
(riješeno) Boot Disk Failure!
Vot da fak?!
OS mi je na 2x32 RAID0 SSD
Do sada sam imao još:
1.5TB disk - 2 particije
1TB disk - 1 particija
Dodao sam još nekoliko diskova sve dela super.
Kada izvadim ovaj WD Green - 1.5 TB OS se neće bootat.
U čemu je štos?
MC
Staro 26.05.2010., 20:41   #2
Joke
N00B
Joke's Avatar
Postovi: 3,886
Bootrec.exe options
The Bootrec.exe tool supports the following options. Use the option that is appropriate for your situation.
Note If rebuilding the BCD does not resolve the startup issue, you can export and delete the BCD, and then run this option again. By doing this, you make sure that the BCD is completely rebuilt. To do this, type the following commands at the Windows RE command prompt:
* bcdedit /export C:\BCD_Backup
* c:
* cd boot
* attrib bcd -s -h -r
* ren c:\boot\bcd bcd.old
* bootrec /RebuildBcd
/FixMbr
The /FixMbr option writes a Windows 7 or Windows Vista-compatible MBR to the system partition. This option does not overwrite the existing partition table. Use this option when you must resolve MBR corruption issues, or when you have to remove non-standard code from the MBR.
/FixBoot
The /FixBoot option writes a new boot sector to the system partition by using a boot sector that is compatible with Windows Vista or Windows 7. Use this option if one of the following conditions is true:
* The boot sector has been replaced with a non-standard Windows Vista or Windows 7 boot sector.
* The boot sector is damaged.
* An earlier Windows operating system has been installed after Windows Vista or Windows 7 was installed. In this scenario, the computer starts by using Windows NT Loader (NTLDR) instead of Windows Boot Manager (Bootmgr.exe).
/ScanOs
The /ScanOs option scans all disks for installations that are compatible with Windows Vista or Windows 7. Additionally, this option displays the entries that are currently not in the BCD store. Use this option when there are Windows Vista or Windows 7 installations that the Boot Manager menu does not list.
/RebuildBcd
The /RebuildBcd option scans all disks for installations that are compatible with Windows Vista or Windows 7. Additionally, this option lets you select the installations that you want to add to the BCD store. Use this option when you must completely rebuild the BCD.
EDIT: Nedavno "ista" tema (isti problem).
Ubaci win7 DVD u komp pa se poigraj sa "Bootrec.exe" (odnosno popravi mbr)..
Bootrec.exe options
* c:
* cd boot
/FixMbr
/FixBoot
/ScanOs
/RebuildBcd
IE6
Linux is Not Windows
Staro 26.05.2010., 20:56   #3
Sa_Stilom
Sa_Stilom's Avatar
Postovi: 2,717
Hahahha, šta si se odmah javio, kad se radi o tvom budućem disku
Aj probam ^^
sad javlja:bootmgr is missing,kaj sad?
EDIT:
Evo, riješeno!
Joke je pomogao telefonski, pošto mi mozak ne radi trenutno
Predlažem da se ova cijela tema zbriše.
Fala
MC
Zadnje izmijenjeno od: domy_os. 27.05.2010. u 08:58. Razlog: spajanje postova
Staro 26.05.2010., 22:40   #4
MadBoY
MadModerator
MadBoY's Avatar
Datum registracije: Sep 2002
Lokacija: N/A
Postovi: 5,195
Pa mogao si napisati rjesenje.
Staro 26.05.2010., 23:05   #5
Sa_Stilom
Sa_Stilom's Avatar
Postovi: 2,717
Sve piše u ovoj drugoj temi
MC
