Staro 14.05.2010., 17:08   #1
spanja
Lokacija: kz
Postovi: 4
nestala opcija "show hidden files and folders"
imam win xp sp3. kad otvorim bilo koji folder u alatnoj traci pod dijelom tools trebalo bi se nalaziti folder options. kad sam instalirao win postojala je, ali nakon nekog vremena primijetio sam da je nestala i vise ne mogu skrivene fajlove vidjeti jer nemam gdje ukljucit opciju "show hidden files and folders".
help
spanja je offline   Reply With Quote
Staro 14.05.2010., 17:11   #2
E-mil
Oppa Gangbang Style
E-mil's Avatar
Postovi: 1,763
ukucaj u google: missing folder options
i voila
(vidi vraga)
E-mil je offline   Reply With Quote
Staro 23.06.2010., 13:58   #3
marmarko
Datum registracije: Dec 2009
Postovi: 80
citiram sa drugog foruma:
Go to the following registry key:
HKLM\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced\Folder\Hid den\SHOWALL
Delete the value CheckedValue. (Its type should be REG_SZ and data should be 2.)
Create a new DWORD value called CheckedValue (same as above, except that the type is REG_DWORD). Modify the value data to 1 (0x00000001).
This should let you change the "Hidden Files and Folders" option.
ili skini ovu visual basic skriptu i pokreni...
http://www.4shared.com/file/37485331...ddenfiles.html
pozz
marmarko je offline   Reply With Quote
