Staro 22.04.2010., 11:58   #1
Astra
Lokacija: Earth
Postovi: 539
Testirajte brzinu restarta vašeg računala
Evo jedna zanimljiva stvar na koju sam naletio,
koliko je potrebno vašem računalu da se restarta.
Skinite sljedeću skriptu:
http://forum.pcekspert.com/attachmen...1&d=1271926594
Ili možete ručno sljedeći tekst:
Code:
Option Explicit
On Error Resume Next
Dim Wsh, Time1, Time2, Result, PathFile, MsgResult, MsgA, AppName, KeyA, KeyB, TimeDiff
MsgA = "Please close all running applications and click on OK."
KeyA = "HKEY_CURRENT_USER\Software\RestartTime\"
KeyB = "HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run\RestartTime"
AppName = "Restart-Time"
Set Wsh = CreateObject("WScript.Shell")
PathFile = """" & WScript.ScriptFullName & """"
Result = wsh.RegRead(KeyA & "Times")
if Result = "" then
MsgResult = Msgbox (MsgA, vbOKCancel, AppName)
If MsgResult = vbcancel then WScript.Quit
Wsh.RegWrite KeyA & "Times", left(Time,8), "REG_SZ"
Wsh.RegWrite KeyB, PathFile, "REG_SZ"
Wsh.Run "cmd /c Shutdown -r -t 00", false, 0
else
Wsh.RegDelete KeyA & "Times"
Wsh.RegDelete KeyA
Wsh.RegDelete KeyB
TimeDiff = DateDiff("s",Result,left(Time,8))
MsgBox "Your computer restarts in " & TimeDiff & " seconds", VbInformation, AppName
end if
wscript.Quit
spremite kao restart.vbs i to je to.
a evo moj score:
http://img85.imageshack.us/img85/7622/52606939.jpg
Athlon 2350 BE
2 Gb RAM
Svi procesi uključeni.
File Type: rar restart.rar‎ (608 byte, 490 views)
Astra je offline   Reply With Quote
Staro 22.04.2010., 12:07   #2
ThaBigJc
ThaBigJc's Avatar
Lokacija: U kući
Postovi: 53
re
Evo cisti winsi
Any sufficiently advanced technology is indistinguishable from magic.
ThaBigJc je offline   Reply With Quote
Staro 22.04.2010., 12:24   #3
Rino
[ZA DOM]Rino
Rino's Avatar
Lokacija: Kutina
Postovi: 762
Ne vidim svrhu ovoga...ujutro ga upalim...navečer ga ugasim...(isto kao što ne vidim svrhu 3DMarka,SuperPi-a itd.)
Rino je offline   Reply With Quote
Staro 22.04.2010., 13:20   #4
Jerry Drake
Postovi: 359
Zgodno, ali uglavnom beskorisno.
AKo je spor start up neće se otkriti u čemu je problem. Bolje onda koristiti bootvis.
let my people go!
Jerry Drake je offline   Reply With Quote
Staro 22.04.2010., 15:25   #5
Hrvoje xyz
lepi
Postovi: 923
Autor Rino Pregled postova
ja jos rjede otkako sam otkrio sleep na visti
samo zalupim lap i ode u sleep...ponekad prodje dva tjedna da ne restartam komp.onda updejtam windowse pa moram.
windowsi vista sp2 stari godinu i pol - oko dvije minute treba za potpuni restart.
iskljucio sam sto sam mogao, ne bunim se. 3gb rama , 2ghz core duo.s tim da upisujem pass kod logiranja usera.
Hrvoje xyz je offline   Reply With Quote
Staro 22.04.2010., 18:04   #6
khm
Lokacija: Slavonija
Postovi: 1,200
Nisam ugasio PC ima sigurno godinu dana, tu i tamo neki reset... a i inace ne vidim svrhu ovakvih 'natjecanja', nit je korisno nit ista...
khm je offline   Reply With Quote
