Staro 13.04.2010., 14:48   #1
Doink the Clown
Jack of all, master of none
Doink the Clown's Avatar
Lokacija: Matulji - Rijeka
Postovi: 6,214
Nvidia ForceWare 197.41 WHQL driveri (GTX4x0 only)
Evo nam vani i službenih drivera koji nude podršku za Fermi čip, ima li tko već koju GTX470/480 da isproba?
This is a WHQL-certified driver update for GeForce GTX 480 and GeForce GTX 470.
Bundled Components:
  • Installs PhysX system software version 9.10.0129.
  • Installs HD Audio driver version 1.0.9.1.
Technology and API Support:*Note: 3-way SLI technology and SLI multi-monitor support are only supported on Windows Vista and Windows 7.
http://www.nvidia.co.uk/Download/index.aspx?lang=en-uk
C L O W N I N G A R O U N D
Staro 13.04.2010., 20:31   #2
alengrosevic
alengrosevic's Avatar
Postovi: 3,779
pa driveri su dosta dobri, nisam naisao na neke posebne probleme, GTX480 radi s njima cisto ok
nakon 5-6 revizija drivera cemo vidjeti njen puni potencijal, dok ih jos malo ispeglaju...
Staro 18.04.2010., 15:42   #3
ThePornstar
ThePornstar's Avatar
Postovi: 4,403
Na mojoj starici se popravio gpu usage sa navedenim driverima, u BC2. Naravno s time i desetak fpsa više.
Edit: točno dečki, pomiješao sam. My bad
CPU: Intel i5 8250u
RAM: 16 GB
VGA: Intel UHD 620
OS: Win 10 Pro x64
Battery: 57 Wh internal
ROM: Android 9
Zadnje izmijenjeno od: ThePornstar. 18.04.2010. u 16:22.
Staro 18.04.2010., 16:08   #4
fran123456
Premija
fran123456's Avatar
Datum registracije: Mar 2009
Postovi: 1,634
Zar nije ovo driver samo za GTX480/GTX470?
fran123456 je offline   Reply With Quote
Staro 18.04.2010., 16:10   #5
Razer
Razer's Avatar
Postovi: 11,642
Čini se da je on malo pomiješao ove i 197.45 drivere
