Izumitelj
Postovi: 80
Kako "odrezati" rubove videa ?
Znate onu funkciju crop ? Ono kad odrezemo rubove slike i ostavimo si sredinu. Kako da to napravim sa video fileom ? ![]() Ili neki zoom, nesto... Trebao bih odrezati rubove koj cm. ![]() |
Postovi: 1,908
Gordian Knot ima tu opciju, al ne znam dal ces to moci uciniti bez prekodiravanja... |
Izumitelj
Postovi: 80
Opa...
Evo nasao sam. Thing you need: >>> Virtual Dub ![]() ![]() Press Add... (marked with a red "A" in image below) ![]() A list of all the filters that can be applied to a video file will pop up. Choose Null Transform. ![]() Press OK and we're back to this box. Press Cropping... (marked with a red "B" in image below) ![]() The cropping box below will pop up. Use the slider bar and frame movement buttons to find a good part in the video where you can see clearly where you need to crop. Then change the numbers in any of the four number boxes (X1, X2, Y1 or Y2). Each box represents one of the four sides of the box. Increase or decrease the amount needed and you will see it cropping. ![]() When you are done press OK. That's it! When you resave the video in VirtualDub the newly saved video will be cropped. Don't forget you need to recompress again when you save it or it won't work. Cropping is especially useful for getting rid of any hum-bars from the edges of the screen that appear with TV Tuner captures. ...e super ! ![]() |
Izumitelj
Postovi: 80
ehh...
Dzaba mi sve to, kad ne mogu otvoriti file (snimljen sa Win movie makerom). :mad: ![]() |
#7 | |
Izumitelj
Postovi: 80
Mislim da je problem jer su fileovi snimljeni sa windows movie makerom, a on i virtual dub se nesto ne vole bas izgleda. Anyway... Kako se otvara sa dubmodom ? ![]() |
#8 | |
Into my head it goes
Datum registracije: Feb 2004
Lokacija: space de luxe
Postovi: 779
i pokusas otvoriti taj file ![]() ![]()
...help me understand the best I can... |
Izumitelj
Postovi: 80
A sta taj program isto moze odrezati rubove ? Jel to neki dodatak za virtual dub ili je to program za sebe ? Kako se u tom slucaju rezu rubovi sa tim programom ? ![]() |
Postovi: 779
hebemu misa!jesi li uopce probao skinuti program!?sucelje mu je skoro pa identicno onome u virtualdubu,jedino sto mu fali opcija audio.pod video-filters-null transform-i dobijes ono sta zelis ![]() ![]()
Izumitelj
Postovi: 80
A sta mislis da skidam i instaliravam odmah svaki link koj vidim po forumima ? ![]() Pa valjda mi treba koja informacija prije. Evo probati cu. Ali glavni problem je u tome sto su moji video fileovi snimani sa W movie makerom a Virtual Dub ih ne zeli ni vidjeti. ...a Virtual Dub je jedan od najboljih programa za obradu videa i trebat ce mi jos sigurno. Ali ako je ovaj prakticno isti... ![]() ![]() Thanx |
