Staro 15.03.2010., 20:07   #1
Makaveli2
Makaveli2's Avatar
Postovi: 100
(riješeno) Microsoft Office ne može se reinstalirati ni pokrenuti
Znaci ovako microsoft office mi se jednostavno nezeli deinstalirat s kompa, probao sam ga deinstalirat u add/remove programs, sa office originalnim cd-om sa TuneUp utilitis i uvjek se pojavljuje ova greska
jel zna neko u cemu je problem?
hvala
Makaveli2 je offline   Reply With Quote
Staro 15.03.2010., 20:10   #2
nino
nino's Avatar
Postovi: 12,600
Pa jesi otvorio file na kraju poruke?
Staro 15.03.2010., 20:27   #3
Makaveli2
Makaveli2's Avatar
Postovi: 100
da ali tamo je nakraju office12/1033/stslisti.dll
umjesto office10/1033/pss10r.chm
Staro 15.03.2010., 22:17   #4
Makaveli2
Makaveli2's Avatar
Postovi: 100
da pojasnim ja sam si bio nesto cistio po registryu ali ako sam nesto krivo i izbrisao nije mi jasno zasto sve drugo radi ok samo se on neda ni pokrenut ni deinstalirat ni reinstalirat,
na kompu imam AVG9, superantispy i malwerbites i nijedan nis ne pronalazi tako da nije ni neki virus... nezzz
Staro 16.03.2010., 02:06   #5
Joke
N00B
Joke's Avatar
Postovi: 3,886
Uninstall Programs Manually
Just because Windows XP has the Add/Remove Programs feature it doesn't mean your application will appear in the list. Furthermore, even if it does appear, it's no guarantee that the uninstall feature will work. When you run across one of these situations the items listed below will help in getting rid of the application. Be aware that these steps may not remove everything associated with the application and can impact other applications on the computer. Have a backup or restore point and use caution.
Find the directory for the application and delete all the files in the directory. Delete the directory.
Open regedit and navigate to HKEY_LOCAL_MACHINE\SOFTWARE and find the folder for the application. Delete the folder.
Open regedit and navigate to HKEY_CURRENT_USER\SOFTWARE and find the folder for the application. Delete the folder.
To remove the application entry from Add/Remove Programs (if present) open regedit and navigate to HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall and find the folder for the application. Delete the folder.
Some applications have Services attached to them. If this is the case, navigate to HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services, locate and delete the service.
In Windows Explorer, navigate to the individual user settings and delete program references. Common places to check would be:
C:\Documents and Settings\All Users\Start Menu\Programs and delete relevant entries.
C:\Documents and Settings\All Users\Start Menu\Programs\Startup and delete relevant entries.
C:\Documents and Settings\%YourUserID%\Start Menu\Programs and delete relevant entries.
[Do this for each User ID listed]
C:\Documents and Settings\%YourUserID%\Start Menu\Programs\Startup and delete relevant entries.
If no entries were found in the previous step and the application launches automatically, navigate to
HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\Windows
and delete the entry.
Sa nekim od unistallera?
Revo unistaller ili manualno (check spoiler).
IE6
Linux is Not Windows
Staro 16.03.2010., 14:16   #6
Makaveli2
Makaveli2's Avatar
Postovi: 100
Revo unistaller ga je izbrisao, hvala
