Zaključane teme
Staro 18.02.2010., 00:19   #1
Neo-ST
Neo-ST's Avatar
Postovi: 8,487
Winxp traži aktivaciju iako je već aktiviran
Imam problem s jednim laptopom, iz čista mira se pojavila poruka (prilikom boota Windowsa XP Home) da aktiviram Windowse u roku od 7 dana, no kada kliknem da aktivira onda izbaci poruku da su Windowsi već aktivirani i mogu samo kliknuti OK. To se događa pri svakom bootu.
Probao sam slijedeće metode, no nijedna ne funkcionira:
metoda 1: ovdje je problem što nemam ovaj fajl wpa.bak, samo wpa.dbl. Svejedno sam renameao wpa.dbl, no nema efekta
Try the following:
1. Reboot your computer into "Safe Mode".
A description of the Safe Mode Boot options in Windows XP
http://support.microsoft.com/kb/315222/en-us
2. Go to Start > Run and type: %systemroot%\system32 then press the Enter key.
3. Locate these two files: wpa.dbl and wpa.bak
4. Rename the wpa.dbl file to wpaold.dbl and wpa.bak to wpaold.bak
5. Reboot your computer into Normal Mode. This will force activation on the following boot. Sometimes if those files get corrupted, they can cause this type of problem.
metoda 2: nema efekta
Go to start/run, and type
regsvr32.exe regwizc.dll
OK, then,
regsvr32.exe licdll.dll
metoda 3: s ovom metodom sam dobio ponovo aktivacijski ekran, i odaberem "activate windows over internet", međutim kaže mi da je aktivacija sa ovim serialom pokušana već nekoliko puta i da ne mogu nastaviti s njim nego s nekim drugim, ali drugi nemam, Windowsi su originalni, ništa mi nije jasno
Go to Start > Run, and type:
chkdsk /r
Answer "Y" to the questions and let the scan finish on reboot.
If that doesn't do it, deactivate your machine and then reactivate it.
%systemroot%\system32\oobe\msoobe.exe /a
If that doesn't work, then run regedit, navigate to:
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\wpaevents
and change any single number in OOBEtimer in the right pane. Close regedit and try the command in the Run box again.
Ima netko savjet? Hvala
Neo-ST je offline
Staro 18.02.2010., 00:37   #2
nino
nino's Avatar
Postovi: 12,613
Autor Neo-ST Pregled postova
Da, zovi Microsoft.hr.
nino je offline
Staro 18.02.2010., 00:45   #3
^SuperUnknown^
Prečupavi mod
^SuperUnknown^'s Avatar
Postovi: 9,127
0800 300 300
Primary macine:
Apple Mac Pro 5,1
64 GB ECC DDR3 800 MHz
Geforce GTX 980 4 GB
Kingston 120GB SSD
30 TB HDDs
Sharkoon QuickPort@USB
Optiarc DVD RW AD-7170A
Mac OS X 10.12.3
Secondary machine:
Apple Mac Pro 2,1
22 GB DDR2 FB-DIMM 667 MHz
Geforce GTX 970 4 GB
Seagate 500GB 7200.10
Hitachi 1000GB 7K1000.B
Seagate 1000GB 7200.11
Hitachi 7K3000 3000GB
Mac OS X 10.10.3
Work rig:
Apple Mac Pro 1,1@2,1
13 GB DDR2 FB-DIMM 667 MHz
Geforce GTX 660 2GB
Seagate 500GB 7200.12
2xWD Black 1000GB
2xSharkoon QuickPort@eSATA
Mac OS X 10.10.3
Sony KDL-26U2000 26"@HDMI
Apple Alu Keyboard
Logitech MX518
LAP:
Apple Macbook Pro 3,1
Intel Core 2 Duo 2.53 GHz
4 GB DDR2
Kingson 180 GB SSD
Seagate 320 GB HDD
* Looking in:
* Listening to:
Technics SA-EX320
iPhone 6S 64GB black
iPad 16GB WiFi 4.3.2
* Connected via:
90/90 Mbps Iskon Trio
* "Powered" by:
UPS APC Smart-UPS1500VA
* Playing:
Tama Arstar II
Yamaha DTXPRESS IV Special
^SuperUnknown^ je offline
Staro 18.02.2010., 01:22   #4
Neo-ST
Neo-ST's Avatar
Postovi: 8,487
To je zadnje šta bi mi palo na pamet
Neo-ST je offline
Zaključane teme
