Staro 22.02.2005., 22:33   #1
hilander
Lokacija: hr
Postovi: 34
SATA II diskovi
Hitachi već ima u ponudi SATA II modele. Ako ne budu bitno skuplji od SATA I modela mislim da bi to mogao biti jako dobar izbor. Evo i zašto:
New SATA drives are being designed to be available 24/7, with longer mean time between failure rates. They are not designed to be as durable as enterprise class SCSI or Fibre Channel drives. Enterprise drives must be available and running all the time in high input/output (I/O) environments. SATA drives must be available all the time, but won't get as much traffic in low I/O environments. Because the drives will experience less wear and tear, they don't need to be as robust as enterprise drives, and therefore can be significantly cheaper. SATA drives are priced comparably to parallel ATA drives, and are not nearly as costly as higher end disk drives.
link:http://searchstorage.techtarget.com/...992442,00.html
Zna li tko kad stižu kod nas.
hilander je offline   Reply With Quote
