Staro 18.02.2005., 20:56   #1
Sherif
Heros Arise
Sherif's Avatar
Datum registracije: Dec 2003
Postovi: 41
Warcraft 3 TFT
Ovako.
Samo odjednom kad pokrenem bnet(battlenet) na Warcraft-u pojavi mi se error:
This application has encountered a critical error:
FATAL ERROR!
Program: f:\games\warcraft iii\war3.exe
Exception: 0xC0000005 (ACCESS_VIOLATION) at 001B:009D806B
The instruction at '0x009D806B' referenced memory at '0x10003024'.
The memory could not be 'written'.
reinstaliro sam je dva puta i isto na kraju.
Neznam sta mu je prije sve super islo i sad odjednom ovo.
PLZ HELP
Hope Is The First Step On the Road Of Disappointmen!!
Sherif je offline   Reply With Quote
Staro 19.02.2005., 01:11   #2
Codiac
bycod
Codiac's Avatar
Lokacija: Zagreb / Dubrava
Postovi: 6,699
probaj defrag harda, ja sma imao slican error ali se sve rijesilo reinstalacijom promjeni ramima utore....
pa javi jeli ista pomoglo
.i.
Razer Blade 15
Staro 19.02.2005., 10:38   #3
LordNitro
LordNitro's Avatar
Postovi: 1,610
Provijeri PM!
Kirk: "Spock, you want to know something? Everybody's Human."
Spock: "I find that remark... insulting."
LordNitro je offline   Reply With Quote
Staro 20.02.2005., 15:48   #4
Sherif
Heros Arise
Sherif's Avatar
Postovi: 41
oprosti ali sto znaci PM:confused:
Staro 20.02.2005., 18:31   #5
Dragon Killer
Kompjuterov frend
Dragon Killer's Avatar
Postovi: 326
PM ti je Private Message(Privatna Poruka)
Bolje je šutjeti i pustiti da te smatraju budalom, nego progovoriti i otkloniti svaku sumnju.
A. Lincoln
Dragon Killer je offline   Reply With Quote
Staro 22.02.2005., 00:50   #6
LuX.23
LuX.23's Avatar
Lokacija: ZaGReB
Postovi: 406
format c: pomaže zihre
Intel P4 1.8 Mhz
ASUS P4S533-E SiS 645DX
2 x 256MB DDR333 Samsung
HERCULES ATI Radeon 9800SE AIW 128 MB
HDD Seagate Barracuda 60 & 80 GB
NEC DVD RW+/-ND-2500
PSU Aopen 300W
Monitor EIZO 19" Flexscan
Microsoft IntelliMouse Optical
CoolerMaster Aerogate II
CoolerMaster Cool Drive 3
CoolerMaster 2 x 80mm vent LED Blue
Papst 120mm vent
SkyStar 2
Case InWin X710 Black
LuX.23 je offline   Reply With Quote
Staro 22.02.2005., 11:03   #7
LordNitro
LordNitro's Avatar
Postovi: 1,610
Ne pomaže!
Maknite sve thirdy part programe, ili ako imate neke codec packove, to isto sve maknite.Za daljnje upute i riješenje koje stvarno radi, recite mi pa ću vam poslati na PM.
Staro 22.02.2005., 11:16   #8
Sherif
Heros Arise
Sherif's Avatar
Postovi: 41
THx na PM
Staro 15.11.2005., 14:50   #9
P.M.S.
Lokacija: dubrovnik
Postovi: 12
poz svima
imam problem, kada god na bnetu hocu kreirat drugi igraci mi se uopce ne mogu joinat (imam siemens gigaset SE515 dsl, na blizzovom supportu kazu ovo: Others are not able to join the Warcraft III custom Battle.net games you create
We are aware of a couple issues customers are experiencing in regards to people not being able to join custom Battle.net games you create.
Routers
Normal reason: The router is not forwarding the data to the correct computer.
The solution:
Set your router to forward data on 6112 to one of the computers on your network and 6113 to the next computer and so on.
Then start Warcraft III on each computer, click the Options button, and click the Gameplay button.
Towards the bottom of this screen you will see a text box titled Game port. Make sure the number in this box is the same as the port your router is trying to send the data to (the first computer being 6112, the second being 6113, and so on).
al meni nije jasno sto da radim...help
P.M.S. je offline   Reply With Quote
Staro 15.11.2005., 22:22   #10
destroyer
Lokacija: okolica Varaždina
Postovi: 166
Isključi firewall!!!
btw. kolko mapa imaš? Ili kak da se izrazim?? Karti?
Ja imam 192 na 77,5 MB i rijetko kaj dobroga. Koje mape igraš?
destroyer je offline   Reply With Quote
Staro 16.11.2005., 00:11   #11
P.M.S.
Lokacija: dubrovnik
Postovi: 12
ma nije do firewalla nego do routera, pokusavo sma za iskljucenim fw i ista stvar
uglavom prcko sma danas ok port-forwardinga i stuff i naiso sam na http://www.portforward.com de je cijela stvar ako lijepo objasnjena, kazu da prvo treba namjestit static ip (ja mislim da sam to uradio kako treba) i onda prkat po routeru, al problem je kretenske prirode, (pogledaj sliku) kad klinem na apply NE DOGODI SE NISTA, vrati me ko sto je bilo kad je kvacica bila na "Select predefined services from the list"....ubit cu se
sto se tice mapa igram dotu i jedino dotu
slika
Staro 16.11.2005., 11:08   #12
destroyer
Postovi: 166
waaaaaaaaaaa...
Zakaj svi igraju tu j..... dotu??? Nije da je loša nego mi je glupo kaj stalno izlaze nove verzije i nikak da imaš neku verziju i igraš kak treba!!! Imam 56k i neda mi se stalno skidati novu verziju jer mi uzima previše vremena.
Staro 16.11.2005., 14:41   #13
P.M.S.
Lokacija: dubrovnik
Postovi: 12
ma igra rula
koliko vas ode igra na "onim serverima", ja sam na eurobattle.net-u, nick cro_pms
Staro 16.11.2005., 16:52   #14
destroyer
Postovi: 166
Misliš na PvPGN???
Ja igram. "[CRO]_Destroyer" bez navodnika igra ko x hero siege ili runn kitty ili kakve dobre td-ove?
Staro 16.11.2005., 20:02   #15
P.M.S.
Lokacija: dubrovnik
Postovi: 12
naravno pvpgn
napiso sam guide kako se igrat tu, koga zanima klik
Staro 17.11.2005., 19:44   #16
destroyer
Postovi: 166
Zakaj piše da treba imati adsl??? Ja igram na 56k i radi ko ludo. Čak mogu i kreirati igre i nitko se još nije žalil.
Staro 17.11.2005., 23:25   #17
P.M.S.
Lokacija: dubrovnik
Postovi: 12
zato sto kad ides kreirat dotu sa modemom tako te ispickaraju da ti to vise nikad ne padne na pamet:PP
lag lag....
Staro 18.11.2005., 13:50   #18
destroyer
Postovi: 166
Zato ja ne igram dotu
Staro 02.12.2005., 21:38   #19
Unknown20
Lokacija: Osijek,Croatia
Postovi: 9
War 3 error + SE515
Igram vec duze vrijeme na battlenetu, Sherife, sto se tice errora to ti je tzv. ban, vjerovatno si ga dobio prilikom izlaska iz neke igre....
P.M.S. sto se tice SE515 Siemensa,imam ga doma i jedino sto moras otici tamo mislim u Advanced Options mislim NAT i moras ukljuciti virtualne servere,tj. moras tamo izabrati Blizzard BAttle.Net i spoj IP,Apply i Logout... i mora raditi... mozda nece odmah igraci dolaziti ali budi strpljiv...
Unknown20 je offline   Reply With Quote
Staro 02.12.2005., 21:45   #20
Pikavac
junior
Pikavac's Avatar
Postovi: 56
Ja također igram na eurobattle.net nadimak je wild1.
Pikavac je offline   Reply With Quote
Staro 30.10.2017., 11:33   #21
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,529
au jebote vadim temu ko biblija, ak je problem deletajte post
zanima me samo di da kupim najjeftiniji key za wc3 + tft, nalazim za 19 dolara najjeftinije
Staro 30.10.2017., 11:48   #22
Postovi: 17,143
G2play i kinguin, 14 EUR.
Staro 30.10.2017., 11:52   #23
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,529
daj linkove tu na poslu da ne guglam jer sam našo za 19 bundle ali dolara, to je valjda 14 eura onda
Staro 30.10.2017., 11:57   #24
Postovi: 17,143
Staro 30.10.2017., 11:58   #25
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,529
i onda kad se kupi ukuca se u battle net?
jel se to jos moze igrat prek battle neta? s frendom planiram malo
Staro 30.10.2017., 12:04   #26
Postovi: 17,143
Nemam pojma kako to funkcionira s tim starim igrama, ja sam wow, overwatch, diablo, sve kupovao preko takvih stranica, i aktiviraš na battlenetu i to je to.
Staro 30.10.2017., 12:07   #27
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,529
ma ja imam sve to vec na betlnetu, al frend nema pa da njemu složim
Staro 30.10.2017., 13:05   #28
Postovi: 17,143
Nemoj me držati za riječ, ali ne bi smjelo biti problema s aktivacijom na bnetu.
Ako ne želi riskirati, 20$ je original preko battleneta.
Staro 30.10.2017., 13:11   #29
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,529
tenks
baš asm se i ja zapalio na ovo, još uvijek patchaju tu igru nakon 15 godina
Staro 30.10.2017., 13:16   #30
Postovi: 8,236
Samo dodaš u bnet račun te kijeve, i oni ti poslje praktički više ni ne trebaju. Sve ostane gore.
