Staro 05.02.2005., 20:26   #1
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Novi Radeon Omega Drivers 2.6.05 (Cat 5.1)
Kaže on ovako:
Sorry for the delay...
The Omega Drivers based on the official Catalyst 5.1 are ready, go ahead to the ATI Radeon section for the download and make sure you see the readme for the new changes and fixes.
Enjoy!
For those of you interested:
I am currently playing World of Warcraft, if you wish to join me in my adventures, I am located in the Lightbringer server, I'm the guild leader of "Sacred Legion" and my character goes by the name of "Omegadrive".
Neš ti ovisnika o WoW-u
What's New in Omega Drivers?
v2.6.05
* Based on the Catalyst 5.1 Official drivers.
* Added support for a few new PCI-X video cards.
* Separated the 9700 and 9800 soft mods, some people with 9500 cards where reporting problems using the unified mode I tried in previous sets, now it should be ok.
* Updated Multires to version 1.49.
* Updated Driver Cleaner Omega Edition to latest version. (thanks Ruud)
What's new for RadLinker?
v2.030
* Fixed bug where the RadClock service is not removed during an uninstall.
* Added ability to select from the unified tabs (3D and Options) or separate DirectX and OpenGL tabs.
http://www.omegadrivers.net/
Staro 05.02.2005., 23:47   #2
Jelc
Super Moderators
Postovi: 17,485
Izgleda da je dosta ljudi imalo problema, za sada je skidanje nove verzije obustavljeno dok se problemi ne rješe.
DOWNLOAD OF OMEGA DRIVERS BASED ON CAT 5.1 HAS BEEN PUT ON HOLD, THERE IS A PROBLEM WITH CURRENT BUILD THAT PREVENTS A PROPER VIDEO INITIALIZATION UPON STARTING WINDOWS, AS SOON AS THIS IS FIXED I WILL PUT THE UPDATED LINKS, IN THE MEANTIME, PLEASE KEEP USING YOUR CURRENT VERSION OF THE OMEGA DRIVERS. SORRY FOR THE INCONVENIENCE.
Ja kao i obično nisam skinuo ovu zadnju verziju, uvijek malo pričekam da vidim na kaj se sve žale nesretni korisnici
Staro 05.02.2005., 23:52   #3
Bl@de
Bl@de's Avatar
Lokacija: Ispred kompa
Postovi: 2,004
e jelc na sljedecem meetingu bus dobil pokolon paket od mene .
bas sam skinul drivere i naravno mucim se pol vure da ih osposobim ali bez efekta! dakle problem je onaj gore spomenuti.
Intel i5 4670k
ASrock Z87 Extreme 3
2x8 Gb Kingston blu
MSI Rx 580x 4 GB
OCZ SSD Vertex 4 - 128 GB
Samsung T166 500 GB 7200 okr/min 16 MB HD501LJ
Samsung F1 1 TB 7200 okr/min 32 MB HD103UJ
Dell S2522HG
Chieftec DX-01BD-V, Corsair 520W CMPSU-520HXEU
Bl@de je offline   Reply With Quote
Staro 06.02.2005., 00:10   #4
Jelc
Super Moderators
Postovi: 17,485
Ko te tjero odmah skidat
Ja sam samo skinuo i instalirao novi RadLinker.
Osim toga-rekao si da nebuš više čačkal po kompu nego da budeš spremao ispit...sad te bog kaznio
Staro 06.02.2005., 00:15   #5
Bl@de
Bl@de's Avatar
Postovi: 2,004
e vrag jedan, jos me sad ides kubat na tu foru. sad je gotova stvar jedana pollitrena bu sve rjesila.
Intel i5 4670k
2x8 Gb Kingston blu
MSI Rx 580x 4 GB
Dell S2522HG
Staro 06.02.2005., 13:39   #6
Mailman
Mailman's Avatar
Postovi: 1,606
Re: Novi Radeon Omega Drivers 2.6.05 (Cat 5.1)
odlično :clap:
Mailman je offline   Reply With Quote
Staro 06.02.2005., 14:59   #7
Jelc
Super Moderators
Postovi: 17,485
Re: Re: Novi Radeon Omega Drivers 2.6.05 (Cat 5.1)
Originally posted by Mailman
odlično :clap:
Novi 2030 RadLinker sam ja skinuo još dan-dva prije Omege
Nakeljio ga na stare drivere i sve dela fino
Staro 06.02.2005., 22:40   #8
Hido
Hido's Avatar
Lokacija: Velika Gorica
Postovi: 624
jel ima neke razlike od onih prijašnjih ?
Hido je offline   Reply With Quote
Staro 07.02.2005., 15:04   #9
pinsla
Caught Somewhere In Time
pinsla's Avatar
Datum registracije: Oct 2002
Lokacija: zg-vrbani, vž u srcu
Postovi: 1,860
ma nikad ne treba žurit s novim drajverima
čuo sam par ljudi koji su imali probelma sa 5.1 tak da uvijke treba biti oprezan
pinsla je offline   Reply With Quote
Staro 07.02.2005., 15:19   #10
CatKiller
al se nekad dobro jelo...
CatKiller's Avatar
Postovi: 3,312
I ja sam imao problema sa 5.1, uopće nisam mogao inicijalizirati OpenGL, smeće od drivera... - tipično za ATi
Staro 07.02.2005., 15:19   #11
Jelc
Super Moderators
Postovi: 17,485
Da par ljudi...ima ih hrpa.
Ja ih nisam nikom preporučio, ovi "stari" Omega delaju bez problema, pogotovo sa najnovijim RadLinkerom.
Staro 07.02.2005., 15:36   #12
pinsla
pinsla's Avatar
Postovi: 1,860
ma daj ne zezaj kome još treba open gl
Staro 07.02.2005., 15:38   #13
pinsla
pinsla's Avatar
Postovi: 1,860
ovi omega bazirani na 4.12 mi zgledaju dobro kaj ne?
jedino si moram onda skinut novi meni uvijek "dragi" radlinker
iako moram priznat da sam promjenio mišljenje kaj se njega tiče i da mi se sve više sviđa
Staro 07.02.2005., 16:17   #14
terminator
Spermich Termich
terminator's Avatar
Lokacija: Zaprešić
Postovi: 885
nemojte mislit da je dobro dak se ne uhoda ...
you will see , don't say i didn't worn ya...
terminator je offline   Reply With Quote
Staro 07.02.2005., 16:19   #15
Jelc
Super Moderators
Postovi: 17,485
Pa u ovom novom ima par novosti, puno ljudi je jambralo da se odvoje DX i GL postavke-sad su odvojene
Staro 07.02.2005., 16:50   #16
Jelc
Super Moderators
Postovi: 17,485
Problem riješen
Nova verzija je v2.6.05a
Samo je jedna novost.
Installation bugfix-riješeno.
Staro 07.02.2005., 20:20   #17
Bl@de
Bl@de's Avatar
Postovi: 2,004
ma nek oni idu u k...c. bas kad sam otisao sa faksa ovi panjevi stavili nazad omegu!
a sa modemom to ne mislim vise skidat!
Intel i5 4670k
2x8 Gb Kingston blu
MSI Rx 580x 4 GB
Dell S2522HG
Staro 07.02.2005., 23:52   #18
Isus
Headbangig Grunf!
Isus's Avatar
Datum registracije: Aug 2003
Lokacija: headbanger's ball
Postovi: 4,373
odi ponovo na fax, možda i nekaj naučiš
Grunf je moj idol!
Moji Grunf type modovi
Alfisti site, Alfisti forum
Staro 08.02.2005., 00:57   #19
pinsla
pinsla's Avatar
Postovi: 1,860
falim te bože
skinul sam i instaliral
konza
Staro 08.02.2005., 00:57   #20
Bl@de
Bl@de's Avatar
Postovi: 2,004
ma danas sam odjavil ispit jel nebum sve stigel nauciti ali zato za dva tjedna se nadam da bum naucil dva kom.
Intel i5 4670k
2x8 Gb Kingston blu
MSI Rx 580x 4 GB
Dell S2522HG
Staro 08.02.2005., 00:58   #21
pinsla
pinsla's Avatar
Postovi: 1,860
ti zgleda na faks hodaš sam skidat drajvere
i to valjda sam onda kad se sjetiš kak zgleda zgrada
Staro 08.02.2005., 14:00   #22
Jelc
Super Moderators
Postovi: 17,485
falim te bože
konza
Meni predzadnja Omega i novi RadLinker delaju čist fino
Izgleda da su malo usrali službene 5.1 da ih ni Omega nije mogao dotjerati u red...
Staro 08.02.2005., 15:27   #23
pinsla
pinsla's Avatar
Postovi: 1,860
ma jebga desi se ponekad
ali kolko sam videl i omega je malo preveč igral WOW pa je usral nekaj kod instalacije
Staro 09.02.2005., 11:25   #24
ZiViky
ZiViky's Avatar
Lokacija: Ljubljana-Rijeka-Cres
Postovi: 154
probao sam instalirati Omega Drivers 2.6.05a na Sapphire 9600XT. Instalacija prodje ok za razliku od zadnje 2 verzije. Samo kad se WinXP restartaju nemam grafike. Ima tko kakvu ideju?
Kod instalacije 2.5.97 i 2.5.97a bi mi win srali u stilu da su drajveri instalirani i da je doslo do nekakve pogreske. Kad bi restarto pc grafika je bila ok samo sam izgubio Overdrive funkciju i s time dodatni boost kod grafe.
Zbog gore navedenih razloga sam jos na 2.5.90 verziji. Cak mi je sa njima bolji skor u 3DMark05 za 50 bodova.
HP NX9420
Core Duo T2400 1,83GHz
2GB RAM
Seagate 100GB SATA
ATI X1600PRO 256MB ram
17" LCD
ZiViky je offline   Reply With Quote
Staro 09.02.2005., 15:17   #25
Jelc
Super Moderators
Postovi: 17,485
Nekima novi delaju fino, nekima je kuku-lele, ja sam još uvijek na 2.5.97a+ novi RadLinker
Najvjerovatnije neću ni stavljati ove najnovije.
Staro 09.02.2005., 15:52   #26
Mailman
Mailman's Avatar
Postovi: 1,606
kod mene rade OK na R9000....
Staro 09.02.2005., 18:53   #27
Sanjanin
Datum registracije: Apr 2004
Lokacija: Balkan
Postovi: 146
posto nemam vremena da procitam ove postove, interesuje me da li moram izbrisati prijasnju verziju omege da bi mogao najnoviju instalirati?
Sanjanin je offline   Reply With Quote
Staro 09.02.2005., 23:52   #28
Hido
Hido's Avatar
Postovi: 624
nova ver.. ti pregazi staru , ali ipak ti to sve obrisi sam tak da se nebi događale svojekakve gluposti , npr pocnu se klat , znalo je i tog bit , ali rijetko
Staro 26.02.2005., 20:14   #29
Tomica 110
Postovi: 1
Question
Nisam neki ekspert za komp pa se stoga obraćam ljudima koji to kontaju. Naime nedavno am si pribavio Radeona 9500 Pro (256 bit, 128 MB, u izvedbi Hercules-a), pa me zanima koji bi Omega driveri bili prikladni za naj optimalniji rad takove grafičke kartice
Tommicaaaaa
Tomica 110 je offline   Reply With Quote
Staro 27.02.2005., 00:13   #30
eXecutioner28
eXe
eXecutioner28's Avatar
Lokacija: Međimurje
Postovi: 377
ok mozda cu se totalno osramotiti - ali sto je to RADlinker? sto radi?
eXecutioner28 je offline   Reply With Quote
