Staro 24.11.2009., 19:09   #1
hellboy152
hellboy152's Avatar
Lokacija: Pakrac
Postovi: 179
(riješeno) Audio driver za Windows 7
instalirao sam win 7 i sve radi osim zvuka, update-ao jesam, probao sam instalirat drivere za vistu ali neće, jel ima netko nekakvu pametnu ideju?
p.s.
ploča je Abit IL8
hellboy152 je offline   Reply With Quote
Staro 24.11.2009., 20:16   #2
naram-sin
The Last Akkadian
naram-sin's Avatar
Datum registracije: Apr 2008
Postovi: 194
Za prvi korak, probaj ovdje:
http://downloads.guru3d.com/Realtek-...load-2435.html
Ako je do drivera...
EDIT: budes javio je li pomoglo?
Zadnje izmijenjeno od: naram-sin. 25.11.2009. u 10:18. Razlog: rijeseno?
naram-sin je offline   Reply With Quote
Staro 25.11.2009., 11:00   #3
hellboy152
hellboy152's Avatar
Lokacija: Pakrac
Postovi: 179
Autor naram-sin Pregled postova
Naravno da budem. . .
Nisam do sad stigao probat. Instalirao i sve radi. Puno hvala!
Staro 25.11.2009., 13:41   #4
naram-sin
The Last Akkadian
naram-sin's Avatar
Postovi: 194
Eto! Thnx.
Staro 02.01.2010., 18:19   #5
bozidarbelavic
Datum registracije: Jan 2010
Postovi: 2
Pozdrav!
I really need a help!
I also upgrade from widows xp sp2 to windows 7 ultimate 7600, and now having a sound problem!
i try many audio drivers but they didin.t help me!
The device manager said: This device cannot start. (Code 10)
my configuration is:[LIST=1][*]Procesor AMD Athlon XP, 1800 MHz (13.5 x 133) 2200+[*]Matsonic MS8147C/C+/CR (5 PCI, 1 AGP, 1 CNR, 3 DIMM, Audio, LAN)[*]VIA VT8377 Apollo KT400[*]C-Media CMI9738 @ VIA AC'97 Enhanced Audio Controller
Please help me!
bozidarbelavic je offline   Reply With Quote
Staro 02.01.2010., 21:56   #6
domy_os
domy_os's Avatar
Postovi: 18,918
Welcome to PC Ekspert Forum, we wish you happy New Year!
Did you try Windows Update or install driver for Windows Vista or XP maybe? I have only this driver for Windows XP I guess...
Sorry but your PC is too old for new Windows 7, suggest you downgrade to Windows XP.
http://rapidshare.com/files/32938041...ia_CMI9738.rar
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 03.01.2010., 04:21   #7
bozidarbelavic
Postovi: 2
Autor domy_os Pregled postova
Hvala Majstore!!! gdje si bio do sada?
ovo je pomoglo, napokon zvuk!!!
Svaka ti čast, proveo sam dva dana tražeći drivere i nista ne pomaže a onda se pojaviš ti i skoro me ubiješ kad si reko da moram downgradati, ali spas u zadnji čas sa ovim linkom!!!
Puno hvala!!!!
Također Sretna Nova godina i puno srece, zdravlja i uspjesnih linkova!!!
Staro 23.02.2011., 03:40   #8
Allen
Datum registracije: Feb 2011
Lokacija: Drniš
Postovi: 2
Sound driver
Ljudi pomagajte...imam win7... update sam ga i sve instalirao i nema zvuka...probao puno drivera i nemoze opet...kako???????
ploca je Asrock P4fsb1333-650
Allen je offline   Reply With Quote
Staro 23.02.2011., 10:44   #9
Postovi: 23,583
U specidikacijama stoji: HD Audio (ALC888 Audio Codec), na support stranici ima za Vistu al pretpostavljam da ti ne rade.
Jesi probao sa stranica proizvođača zvučnog sustava (Realtek) ovdje ?
Ako link ne bude radio, Realtek HOME > Downloads > Computer Peripheral ICs > PC Audio Codecs > High Definition Audio Codecs > Software.
Trebaš ovo: (Desc:Vista, Windows7 Driver (32/64bits) Driver only (Executable file), Ver:R2.57, Date:2011/1/28).
Staro 23.02.2011., 17:29   #10
Allen
Lokacija: Drniš
Postovi: 2
nece opet..install sam ga i nece..opet pise "no speakers or headphones are pluged in"
nije mi jasno...neko drugo rijesenje??
Staro 23.02.2011., 17:50   #11
Postovi: 23,583
Probao ištekat - sačekat malo - uštekat zvučnike kako bi ih drajver prepoznao ?
Obično tada pita šta si uštekao a ti mu odabereš.
Sada kad winsi znaju kakvu zvučnu imaš, probaj potegnit update od Mirkosheeta.
