Staro 24.01.2005., 21:02   #1
BlueNeon
Lokacija: V.B.K. Osijek
Postovi: 37
Ne želi ući u Add/Remove
kada probam u kontrolnoj ploči ući u Add/Remove programs on mi izbaci poruku...
Parser Message
Value Creation Failed '' at line 472
to mi se dogodilo prvi put nakon što sam instalirao style XP...
Može pomoć, savjeti,...bilo šta
BlueNeon je offline   Reply With Quote
Staro 24.01.2005., 21:56   #2
BlueNeon
Postovi: 37
rješeno...system restore...
Staro 30.01.2005., 11:35   #3
SPLiFF
SPLiFF's Avatar
Postovi: 2,074
sam ti koristi system restore, kad ti se uvuce viruscina dobro ces se namucit da ga izvuces. Ja sam morao iz DOS-a brisati folder system restore (windowsi ne daju).
Staro 01.02.2005., 22:01   #4
BlueNeon
Postovi: 37
Normalno...usput sam formatirao HDD...stavio novi XP + SP1 i nakon Stayla XP on me ponovo utješi sa fakavom porukom.....al nađem mu ja i lijek...evo koga zanima detaljno objašnjeno i radi...
Value creation failed " at line 472" ERROR
Fixing the dreaded "Parser Message: Value creation failed " at line 472" error.
This is a problem with the file shellstyle.dll, which is included in most visual styles.
Use the following steps to fix the problem:
1 : Go to your /WINDOWS/Resources/Themes directory, or wherever you may have your themes located.
2 : Go into the directory of the theme your currently using.
Example: Using 'Semplice' by KoL? Navigate to /WINDOWS/Resources/Themes/Semplice
3 : Go into the folder called 'Shell" within the previous directory.
4 : Inside you'll find a folder with a file called 'shellstyle.dll' inside. Now remember the name of the theme your using?
(Example: Semplice). You need to rename this folder from Shell to the name of the theme your currently using.
If you don't know the exact name, go to Display Properties, and try to Display/Show the theme, the name you see in Display
Properties is the name you need to change the 'Shell' folder to.
Example : Using Semplice as an example, the Shell folder for that theme is called 'Shell', in this situation you'll need to
rename the folder to 'Semplice'.
Easy enough, right ?
Note that for multi-part themes, aka themes with more than one variation or color, you'll need to rename each corresponding
'Shell' folder to what is displayed in Display Properties when you try to apply the theme.
5 : Now that you've changed the 'Shell' folder name to correspond with the visual styles name, reapply the theme.
6 : Go to Add/Remove Programs, and there you go.
