Staro 16.09.2009., 14:22   #1
dinkoh
dinkoh's Avatar
Postovi: 97
HITNO:di naci konektor RJ45 za cat6 ??
znaci trebao bi obican mrezni konektor, znaci RJ45, ALI za CAT6 23AWG kabel...
znaci kabel , tj. zice su deblje nego normalne i nejdu u onaj normalni konektor rj45
nemogu naci nigdje u ZGu
jel netko zna ?
ovako nesto
dinkoh je offline   Reply With Quote
Staro 16.09.2009., 16:13   #2
Postovi: 23,632
Zovi pa vidi jel ovi imaju:
http://shop.network.hr/kategorije.20..._5e_cat_6.aspx
Inaće ti deblji kabeli su predviđeni da staviš zidnu utičnicu (je, znam da su skupe) pa onda patch kabelom spojiš klijenta.
Staro 17.09.2009., 14:32   #3
mann
mann's Avatar
Postovi: 2,233
Hm... ima li to sve uopce smisla? Sta ovi jackovi uzemljuju foliju? Ak je to FTP onda se gubi smisao ili se ja varam? Jos ces dobiti efekt antene pa imas vise loseg nego koristi...
P.s. Zainteresiralo me pa isao pogledati...
http://www.siemon.com/us/white_papers/02-03-22-emi.asp
When designing and installing shielded cabling systems, the grounding/earthing and bonding have to be very carefully considered. Proper grounding and bonding are mandatory to assure the effectiveness of shielded systems. For example, to maintain high frequency shield effectiveness while avoiding ground loop difficulties associated with shield grounding at multiple locations, horizontal ScTP cabling should have only one DC ground connection at the telecommunications room.
Staro 17.09.2009., 14:35   #4
dinkoh
dinkoh's Avatar
Postovi: 97
evo nasao sam
evo reklame malo : www.elmaz.hr
