Staro 01.09.2009., 00:18   #1
Dottore
Dottore's Avatar
Postovi: 7,706
Preporuka za 2.1 zvučnike
U potrazi sam za dobrim zvučnikom. Po mogućnost sa žičani daljinski i crne boje.
Max do 400kn.
HP 845 G9
CPU: AMD Ryzen 7 PRO 6850U
RAM: 64GB Samsung DDR5 4800
Graphic: AMD Radeon 680M
LCD: 14" IPS @ 1920 x 1200
OS: Windows 11 Pro 25H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 5
CPU: AMD Ryzen 7 PRO 8840u
RAM: 64GB DDR5
SSD: Kioxia XG8 1 TB NVMe M.2
Graphic: AMD Radeon 780M
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
RAM: 16GB soldered LPDDR4
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
Staro 01.09.2009., 01:04   #2
antrax
antrax's Avatar
Lokacija: Vz - Zg
Postovi: 2,930
ucini si uslugu i dodaj jos 100kn i uzmi z3e (kriva slika), a mozes i pitat protis za kolko ih oni mogu nabavit posto uzimaju od linksa
ostatak ponude u nizem cjenovnom rangu nije bas nesto, a i "daljinac" je vecinom nepostojeci ako zvucnici nesto i vrijede.
Ako hoces stedit, uzmi creative a300, sasvim ok zvucnici za tih 300kn kolko kostaju (ako mora bit 2.1, ako ne razmisli o ovim geniusima, slabiji model je bio ludnica za te novce! imas i temu o njima tu negdje)
Msi x79a GD65
Intel i7 3930k @ 4.7 1.4V
4x 4GB Kingston 1866 9-11-9
Gigabyte gtx 460 1gb
Samsung 830 128GB
640GB WD AAKS
WD green 1.5TB
LG drzac za kavu
Seasonic S12 500W
Coolermaster Stacker 831
HP LP2065 / LG IPS231P
Windows 7 Enterprise
Trenutno nepostojeci
Staro 01.09.2009., 01:27   #3
Dottore
Dottore's Avatar
Postovi: 7,706
što kažeš na Logitech X-210?
HP 845 G9
RAM: 64GB DDR5
Graphic: AMD Radeon
RAM: 64GB DDR5
Staro 01.09.2009., 16:09   #4
kresimir.15
kresimir.15's Avatar
Datum registracije: Jul 2009
Postovi: 17
logitech x530 (5.1) njih možeš preko oglasnika nabavit nove nekorištene za nekih 350, 400 kn. Inače vrijede preko 500 kn ali su bili u t-comovoj ponudi za 1kn pa su tako jeftini po oglasniku.. inače, zvučnici su predobri
kresimir.15 je offline   Reply With Quote
Staro 02.09.2009., 19:02   #5
Dottore
Dottore's Avatar
Postovi: 7,706
čini se da je teže nabaviti x-210
HP 845 G9
RAM: 64GB DDR5
Graphic: AMD Radeon
RAM: 64GB DDR5
Staro 02.09.2009., 19:11   #6
thedream
thedream's Avatar
Lokacija: Zagreb ( Šibenik )
Postovi: 5,458
Z3e - 501kn.
http://www.nhdoo.hr/kompjuteri/produ...oducts_id=7588
Od slabijih modela imaš X seriju kako si i sam primjetio,ja sam davno imao X220 Logitech,sad vidim već i X240,sve u svemu nije to toliko ni loše,i vjerojatno će te zadovoljiti,samo računaj da ćeš za 150kn imati ipak mnogo mnogo bolji zvuk u vidu Z3e seta zvučnika.
Ovi su pak unutar 400kn,zadovoljavaju sve navedeno..
http://www.konikom.hr/p3823/zvucnici...duct_info.html
Ukoliko si budget user,ja sam bratiću uzeo Philipsove za 239kn i mali je prezadovoljan,Realtekica se istakla hehe. Lijepo izgledaju i vrlo solidno sviraju,uz dobru cijenu.
Daljinski prisutan.
http://www.autronic.hr/cms/Detaljno....Kategorija=312
Njihov stariji brat :
Zadnje izmijenjeno od: thedream. 02.09.2009. u 19:29.
Staro 06.09.2009., 01:55   #7
Dottore
Dottore's Avatar
Postovi: 7,706
ok, imam dva tjedna poslije godišnjeg da odlučim
HP 845 G9
RAM: 64GB DDR5
Graphic: AMD Radeon
RAM: 64GB DDR5
Staro 06.09.2009., 02:26   #8
Codiac
bycod
Codiac's Avatar
Lokacija: Zagreb / Dubrava
Postovi: 6,699
moja preporuka su z3 .
.i.
Razer Blade 15
Staro 06.09.2009., 06:52   #9
Emissary
ČLAN FKTa
Emissary's Avatar
Datum registracije: Jul 2004
Postovi: 2,264
Preporučam Logitech X-230.
Pročitaj mišljenja kupaca, ko god ima ove zvučnike na forumu potvrdit će ti isto: http://www.links.hr/index.php?option...kl=100.503.038
Za te pare nema boljih.
