Staro 28.07.2009., 16:11   #1
Matko_STR
Matko_STR's Avatar
Postovi: 86
Max dužina DVI kabela
Kolika je max dužina DVI kabela kojom mogu povezati 22' LCD monitor s grafičkom HD 4670 pri rezoluciji 1680x1050 px.
Da li mogu koristiti kabel od 5m ili je to previše i kakve smetnje mogu očekivati?
Matko_STR je offline   Reply With Quote
Staro 28.07.2009., 16:16   #2
Wolverine
Wolverine's Avatar
Postovi: 12,425
nemaš određenu max duljinu kabla, no preporuka je da budu što kraći
5m nije previše i sam imam spojen TV sa kompom preko 5m DVI-HDMI kabla
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
256GB LiteOn LMH-256V2M mSATA
NEC USB 3.0 ExpressCard
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
CoolerMaster Cavalier
ViewSonic VX922
Win7 x64 SP1
Staro 28.07.2009., 16:16   #3
Sultan
Six Blade Knife
Sultan's Avatar
Postovi: 292
http://en.wikipedia.org/wiki/Digital_Visual_Interface
The maximum length of DVI cables is not included in the specification since it is dependent on bandwidth requirements (the resolution of the image being transmitted). In general, cable lengths up to 4.5 m (15 ft) will work for displays at resolutions of 1920 x 1200. Cable lengths up to 15 m (50 ft) can be used with displays at resolutions up to 1280 x 1024. For longer distances, the use of a DVI booster is recommended to mitigate signal degradation. DVI boosters may or may not use an external power supply.
Sultan je offline   Reply With Quote
