Staro 13.12.2004., 12:10   #1
Paske
Ekspert iz sjene ...
Paske's Avatar
Lokacija: New Eden
Postovi: 3,801
19" Lcd ???
Obzirom da moja voljena iiyama krepava, vrijeme je da se pogleda što se nudi na LCD tržištu.
Zahtijevi su relativno jednostavni:
Dijagonala: 19"
Response time: min 16 ms, poželjno 12 ms ili manje
Realna crna boja
Rezolucija: native 1280*1024
Cijena: 5000 Kn - 7000 Kn
Heh sad .... u toj cijeloj prići sam zamijetio jedino:
SONY LCD 19" SDM-HS94P S/B, 5:4, 0.294 mm,1280x1024, C700:1, 250 cd/m2, rise/fall 4:8, H 170o/ V 170o, DVI-D i HD15, Novo ! , X-Black LCD, Srebrni / Crni
12 ms response time
Cijena za cash: 6.000 Kn
Zanima me što vi gospodo mislite o potonjem. Isto tako - recite nekog svog favorita.
BTW. Tko kod nas drži Eizo LCD monitore ?
Staro 13.12.2004., 12:11   #2
Paske
Paske's Avatar
Lokacija: New Eden
Postovi: 3,801
Evo još malko tech detalja o Sony-u:
Technical data
* Compatibility: PC and Macintosh
* Panel type: LCD Flat Panel
* Display size: 19"
* Diagonal viewable screen size: 19"
* Dot pitch: Information not available
* Contrast ratio: 500:1
* Glass surface: Anti-glare, anti-static
* Horizontal viewing angle: 160 degrees
* Vertical viewing angle: 160 degrees
* Colors: 16.9 million
* Response time: 12 ms
* Brightness: 400 cd/m2
* Input signals: Analog RGB, digital
* Input connector/cable: 15-pin analog, DVI-D digital
* Maximum non-interlaced resolution: 1280 x 1024
* Horizontal scan rate: 2880 kHz
* Vertical scan rate: 4875 Hz
* Power source: Internal
* Swivel range: 90 degrees
* Color: Silver
* Width: 18.9"
* Height: 17.3"
* Depth: 10.2"
* Weight: 15.2 pounds
* Warranty, parts: 3 years
* Warranty, labor: 3 years
* In the box : Display, AC power cord, cord strap, PC/Mac Utility CD-ROM, analog monitor cable, digital monitor cable & User manual
Staro 13.12.2004., 12:48   #3
RAK
Feldwebel
RAK's Avatar
Datum registracije: Feb 2002
Lokacija: bolnica
Postovi: 3,739
I na kraju si uzmi CRT pošto se samo igraš na njemu i s ni jednim LCD ne bi bio zadovoljan. A snažniju trećinu steraj k vragu i neka se ne miješa u tvoj komp.
Tih kao mačka
Brz kao gepard
Jak kao lav
Elegantan kao leopard
Nisam to ja, to je moj komp.
Staro 13.12.2004., 13:05   #4
Paske
Paske's Avatar
Lokacija: New Eden
Postovi: 3,801
To se i ja bojim
Ponajviše zbog response time i loše definicije crne boje
Možda piknem ponovo iiyamu, tko zna.
Frka je u tome da više baš i nema dobrih CRT-a za normalnu cijenu.
Vidjet čemo .... ipak mi se sviđa ideja LCD-a u kombinaciji s LAN party-om
Negdje u 1. mjesecu će se kupovati novi, tada ćemo vidjeti što i kako. Samo bih sada htio vidjeti ... što se nudi, za koliko i dali se uopće isplati.
Što se tiće moje muskulativnije polovice - hah, čak je i njoj jasno da mi treba monitor da bih na njemu radio . Nekaj tipa LG baš i nebih uzimao. Po onoj staroj - nisam dovoljno bogat da kupujem jeftino.
iiyama je izdržala više od 5 godina teške torture ( radi često i dugo, vozila se na mnogobrojne LAN party-e ). Nisam nezadovoljan, samo žalostan
Staro 13.12.2004., 17:38   #5
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,964
Kao prvo pogledaj moj slučaj tamo gdeji si postao problem za svoj monitor.
Kao drugo iz pouzdanog izvora znam da Sony LCD i nisu baš neka sreče, pogotovo za game bez obzira na specifikacije. Ne možda svaki model ali isporbano na par...
Staro 14.12.2004., 10:38   #6
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,007
http://www.gamepc.com/labs/view_cont...=vp201b&page=1
Mislim da je ovo najbolje što se nudi, ima ga rođak u USA (zagriženi gamer) i super je zadovoljan. Još da je jeftiniji i da ga ima negdje u HR
Staro 14.12.2004., 11:47   #7
Paske
Paske's Avatar
Lokacija: New Eden
Postovi: 3,801
Yup .... žestok ekran.
Još da ga ima u RH - mrak
Ali ... 1.200 $ ipak nemam
Kaj ja znam .... mislim da ću ipak ( pametno ) kupiti neki CRT
Malo koji LCD je dobar za igranje, a oni koji jesu su obićno 17"
Staro 14.12.2004., 11:55   #8
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,007
To je vjerojatno list price, on je svoj platio 799$, što je bijednih 4500kn, paskemater, da ima ovdje uzeo bi odma 2
Staro 14.12.2004., 12:06   #9
Paske
Paske's Avatar
Lokacija: New Eden
Postovi: 3,801
839$ kod njih
20" MRAK LCD
Fakat - da ih ima kod nas - ma zamlatim ženu da ne kenja i idem kupiti
Staro 14.12.2004., 12:39   #10
Trek
Trek's Avatar
Postovi: 1,313
carine na informaticku robu ak se dobro sjecam nema, pa kod nas bi sa uvozom trebo biti oko 7000 kn samo ko ce ga poslat u hr....
Biti lud ima prednosti koje razumiju samo ludjaci
FKT meber jednog dana high priest...
Trek je offline   Reply With Quote
Staro 14.12.2004., 12:43   #11
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,007
ja ću zagnjavit rođu ako bude dolazio slijedeće ljeto, samo ko će to dočekat, a i ko zna što će sve izaći na tržište do tada
btw, ima ga na pricewatchu za 723$ !!!
Ili evo direktan link:
http://www.pcnation.com/web/showcase...rand=viewsonic
ma kupujem sigurno, do ljeta će bit ispod 500$
I još na kraju:
http://www.viewsonic.com/multipanelsetup/step3.htm
Bolesno :clap:
I za kraj:
http://www.hardforum.com/showthread.php?t=780004
Zadnje izmijenjeno od: segregator. 14.12.2004. u 16:51.
Staro 05.01.2005., 10:12   #12
Paske
Paske's Avatar
Lokacija: New Eden
Postovi: 3,801
Kao Feniks iz pepela - thread se diže
Anyway ... sutra se putuje Deutschland - ako tamo ne nađem ViewSonic ili nekaj slično .... kaj mislite o LCD 18" DELL 1801FP, crni
Cijena 4.500 u HG Spotu.
Nisam naša nikakove konkretne infomacije o njemu. Navodno je dobar, s 16 ms response time - po navodima s foruma u US. Neki realni review nisam našao, samo ona sranja koja imaju dućani
Staro 05.01.2005., 11:21   #13
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,007
20" model im je malo jeftiniji od viewsonica, a ima skoro jednako dobre ocjene...
Mislim da se radi o ovom modelu
http://accessories.euro.dell.com/sna...ctlisting.aspx
Što se tiče 18", izgleda da NIJEDAN monitor te veličine nije bio OK
Zadnje izmijenjeno od: segregator. 05.01.2005. u 11:40.
Staro 05.01.2005., 13:17   #14
Paske
Paske's Avatar
Lokacija: New Eden
Postovi: 3,801
Pa ... cijena se čini relativno O.K. - 5.500 nije pretjerano ...
Kaj se tiće 18" modela - 1000 Kn jeftiniji
Sad .... kakav je - to je vrlo dobro pitanje
Staro 07.01.2005., 18:00   #15
Nuclear Winter
Datum registracije: Sep 2004
Postovi: 9
19" 12ms? Samim tim zahtjevom si ogranicen na TN + Film panel kojeg ima i HS94P kojeg si spomenuo. Najveca mu je mana los vidljivi kut bez obzira na specificiranih 160/160 stupnjeva jer ga Sony mjeri drukcije (pad kontrasta na 5:1 a ne uobicajenih 10:1).Takodjer, velika vecina korisnika ima problema sa pozadinskim osvjetljenjem (http://www.hardforum.com/showthread.php?t=840885). U svijetu LCD-a Sony nije ni priblizno onome sto je bio u svijetu CRT-a tako da ime i velika cijena i nisu garancija kvalitete. Inace, sto fali LG-u? Pa LG Philips je jedan od navjecih proizvodjaca panela na svijetu i vecina velikih imena koristi bas njihov panel. Vec spomenuti Dell 2001FP takodjer koristi IPS panel od LG-a. Gotovo svi 23" LCD-i od raznih proizvodjaca (Sony, Viewsonic, HP, Apple) takodjer koriste panel od LG-a.
Za rad, preporuka su MVA/PVA i IPS paneli zbog dobre reprodukcije boja i sirokog kuta gledanja. Nazalost, takvi paneli imaju vece nazivno vrijeme odziva pa nisu idealni za hardcore gamere. Neki najbolji kompromis izmedju svega je LG1930B koji je jedan od rijetkih 19" LCD-a koji koristi IPS panel. Siroki kut gledanja, vrlo dobre boje i vrijeme odziva (25ms, ali puno brze nego i nazivno brzi MVA/PVA jer tranzicije u druge boje ne traju toliko dugo). Kad igre nebi bile problem, onda je preporuka Samsung 193P. Taj monitor ima sve osim brze matrice a izgleda jednostavno fenomenalno.
Nuclear Winter je offline   Reply With Quote
Staro 07.01.2005., 18:48   #16
Isus
Headbangig Grunf!
Isus's Avatar
Datum registracije: Aug 2003
Lokacija: headbanger's ball
Postovi: 4,373
Pske daj si zemi Mitsubishi/Nec 930 i dzenja 19" CRT koji je GENIJALAN!
http://www.nec-mitsubishi.com/coreme...62104,type=CRT
ja sma si ga mislio zet al pizd enaju koplet crnog, tj, na trzistu ne postoji nis komplet crno!!!!!
Grunf je moj idol!
Moji Grunf type modovi
Alfisti site, Alfisti forum
Staro 07.01.2005., 21:23   #17
Dragutin
Dragutin's Avatar
Postovi: 528
Kako sam lani bio dobar dečkac, onaj bradati debeli prdonja mi je donio Sonya od 19 cola pod moju ekološku smreku.
Istrošio se ko žuti ali baš me briga kad sam si baš to zaželio.
Hm, pao sam na reklamu, prvo su ga nahvalili u "bubi" a onda ga je i "gle" poklanjao u nekoj nakaradnoj nagradnoj igri za šišmiše.
BTW, ne vjerujem lažovima baš previše, ali kada sam ga ugledao, prije božića, u Mediamarktu u Grazu kako sjaji među stotinama televizorića znao sam mora biti moj, ali si tada nisam mogao priuštiti jer je moja bolja haračila po HM, Meksu i Spiritu; pa po onoj nisam ni ja nećeš ni ti...
Nu, sad stoji na mom stolu, prispojen DVI-Dom na asusovu Ti 4400 i hvalim se njime.
Kako mi pusti brojevi ne znaće mnogo, mogu reći da sam relativno zadovoljan njime. Jako smeta odbljesak od prozora danju i lampe po mraku jer mu je ekran poput crnog ogledala,
a osjeti se i svjetlina uz donji i gornji rub, a to nervira kod tamnog prikaza, osobito kod wide aspecta.
Ja ga imam dok ne nađem boljeg
Dragutin je offline   Reply With Quote
Staro 07.01.2005., 21:25   #18
Dragutin
Dragutin's Avatar
Postovi: 528
Slika
Staro 08.01.2005., 18:43   #19
E.T.
E.T.'s Avatar
Postovi: 2,458
Slazem se sa Rakom kod LCD-a ima previse kompromisa no tko voli (kao ja naprimjer) nek izvoli...
Dobro je rezonirao i Nuclear Winter Samsung i LG su vodeci proizvodaci LCD-a.
@ Dragutin
to sta spominjes ta"svjetlina uz gornji i donji kut" to ti je tako kod svih LCD-a vise ili manje izrazeno pozadinsko osvjetljenje...
A sto se tice "odbljeska svjetla" tu ti nije kriv monitor vec tvoje postavljanje istog. Naime svijetlo bi moralo dolaziti tako da ti zatvaras pravi kut preko monitora sa izvorom svjetlosti odnosno monitor bi trebao biti postavljen da svijetlost "udara" u njegovu bocnu stranicu(nevazno ljevu ili desnu) direktno, a ne nikako da udara direktno u njegov zaslon...
www.rabbits-clan.com
E.T. je offline   Reply With Quote
Staro 08.01.2005., 21:43   #20
Nuclear Winter
Postovi: 9
To je tocno ali u ovom slucaju problem je Sony-eva X-Black tehnologija. Na povrsinu ekrana dodano je staklo koje bi kao trebalo unaprijediti boje a u biti cini ekran vise refleksivnim nego bilo koji CRT. Jos jedan minus za Sony.
Staro 08.01.2005., 22:26   #21
Dragutin
Dragutin's Avatar
Postovi: 528
E to, razliku mogu odma vidjet jer mi je do devetnaestice i običan HSM 15" , mlađi brat koji nema x-BRITE "tehnologiju" pa je ugodnije raditi s njim bez navlačenja roletni i stalnog zakretanja od sunca jer obično sam pred konfjuterom danju a noću se ili opijam ili spavam
Sony me razočarao u prikazu sa tom svojom svjetlinom na rubu jer sam mislio ponekad pogledati filimić na njemu.
PS Nemojte moje komentare uzimat baš totalno jer sam svojedobno našao mene u prikazu 979NF pa sam ga prvom prilikom utopio.
Kaže mi moje milo da imam narav Viktora Meldrowa, i sam u stanju probušit gume invalidu u kolicima ...
