Staro 11.06.2009., 01:21   #1
domy_os
domy_os's Avatar
Postovi: 18,809
Sharkoon Flexi-Drive S2S - SDHC to SATA adapter aka "modularni" SSD
Simply insert the desired number of SDHC cards (max. 6) into the Flexi-Drive's slots. The card's individual memory capacities merge into one and are available as a single drive then.
Benefit from this flexible, convenient memory solution that can be used as a normal 2.5" SATA HDD providing the advantages of a SSD: no noise emission, low power consumption and shock resistance.
Features:
• Fast modular SSD storage solution
• Memory size flexibly adaptable via SDHC memory cards (SLC/MLC)
• SATA interface (SATA I and II)
• 2.5" format
• Zero noise emission, low power consumption, shock resistance
• No drivers or software required
Specifications:
• Use up to 6 SDHC cards as RAID0
• 6 slots for SDHC cards (4-32 GB)
• Supports SDHC cards only
• Flexible memory capacity
• Dimensions: 70 mm x 100 mm x 9 mm (W x L x H)
Package content:
• Flexi-Drive S2S
Je li netko slučajno probao ovu stvarčicu? Čini mi se dosta zgodna, ali je upitna isplativost...
http://www.sharkoon.com/html/produkt.../index_en.html
http://www.links.hr/index.php?naziv=...kl=051.400.007
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 11.06.2009., 01:27   #2
danij3l
danij3l's Avatar
Lokacija: NA
Postovi: 2,620
koncept zanimljiv, ali stvar je preeeeeskupa.
danij3l je offline   Reply With Quote
Staro 11.06.2009., 21:13   #3
thopok
Lokacija: Splity
Postovi: 3,003
To je i meni privuklo pažnju , ali .
Staro 11.06.2009., 22:01   #4
ALiEN17
ALiEN17's Avatar
Lokacija: Histria
Postovi: 1,239
Ako sam skužio, to je nekakva tiskana ploćica koja ima 6 utora za SD kartice (6x16gb=96gb? s time da se kartice opet kupuju posebno a svakih 16gb dodanih 200 kuna) u aluminijskom kućištu od 2.5'' i cijenom od 700 kuna. Znači ako hoću disk od 96gb moram potrošiti oko 2000 kuna? I to za jedan 2.5'' (zašto 2.5''?) NEprenosivi sata disk? Kul. Osim šta se za te pare može kupiti 4 tera prostora.
Staro 11.06.2009., 22:14   #5
mymoon
nautic expert
mymoon's Avatar
Lokacija: Rijeka-Opatija, negdje između
Postovi: 1,386
a ssd disk od 128 Gb košta (sitno ispod) 2k kuna.
neisplativo, ali interesantna koncepcija.
a što se događa sa podacima ako se izvadi jedna od kartica?
mymoon je offline   Reply With Quote
Staro 11.06.2009., 22:22   #6
Rain Man
Lokacija: x
Postovi: 1,447
Koje su brzine citanja, pisanja?
Rain Man je offline   Reply With Quote
