Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Evo, u ovoj verziji drivera je konačno fiksirano forsanje ANISO filtriranja, Pinsla će se veseliti * Based on the Catalyst 4.12 Beta drivers. * New Radlinker installation method, now it should install correctly every time. * Fixed gamma issues with color control panel. * WMV acceleration is now off by default, you can turn it on in the Options panel. * New quick shortcut for Radlinker, just right click your desktop and go directly to all the Advanced 3D settings. * Fixed Standby/Suspend/Hibernation bug. * Added a lot of new resolutions for wide screen monitor/dfp users. * Fixed the Forced Anisotropic settings, now they should not reset to Performance mode. * Removed the special Counter Strike OpenGL from the package, now that CS:S is available, this is no longer necessary. * Fixed some uninstall issues, now the drivers should completely be removed if you select to do so. Well, at last, the fix for the dreaded overlay video on some laptops bug has been found. The cause IS NOT the ATI drivers or any of my settings, the cause is a hardware bug, more specifically a BIOS bug. In the testing, many people already updated their Sager notebooks with a new BIOS provided by Sager and the video problem is GONE! So I encourage you to go to your manufacturer's web page and see if a new bios update has been issued for your laptop, and if not, e-mail the manufacturer so they can rush out a fix for this. 2. CCC will work with the Omega Drivers, but is NOT recommended that you install it, all the functions found in CCC are already included with RadLinker Omega Edition or will be included in a near future as this new CP project develops. |
Caught Somewhere In Time
Datum registracije: Oct 2002
Lokacija: zg-vrbani, vž u srcu
Postovi: 1,860
konačno se je vrag prestal igrat World of Warcrafta te izbacio te drivere ajd idem to skinut pa da vidimo dal HL2 može preko 100FPS na 1600x1200 6xaa 16xaf ![]() |
#4 | |
prof.dr. gospodar svemira
Postovi: 431
If you are not paranoid you don't have enough information |
#5 | |
od LemilicE
Lokacija: Veli Lošinj
Postovi: 4,712
Da li prethodno snimite svoj demo ili već ima neki, pa da i ja sa svojom malom ATIcom probam
Postovi: 431
Za trenutne FPS-ove napises u konzolu cl_showfps 1, a za benchmark ima onaj neki ugradjeni demo. Znam da sam ga jednom pokrenuo, ali se ne mogu sjetiti gdje sam ga u opcijama nasao... ![]()
Lokacija: VINKOVCI
Postovi: 185
dali mi se isplati skidati ove drivere posto su radjeni na catalystu 4.12 beta? trenuto perem sa 4.11.
bla----- |
pUtNiK
Datum registracije: Feb 2004
Lokacija: na forumu
Postovi: 342
omega izašla a baš sam skinuo beta 4,12 CATsam sam htio pitat s kojim programom mogu mjerit temp grafe. (9800XT) |
#9 | |
Postovi: 431
U ATiToolu mozes staviti da ti temperature zapisuje u log, pa onda nakon nekog mrcvarenja (igra) mozes pregledati log da vidis kako se kretala temperatura graficke.
#10 | |
Ronon Dex
Lokacija: DS9
Postovi: 1,625
http://www.fraps.com/ |
#11 | |
pUtNiK
Lokacija: na forumu
Postovi: 342
imam ati tool 0.0.22.-možda ta verzija nema to u Everestu nigdje nevidim??? jel to možda jer nepiše proizvođač grafičke već ju sam prpozna ko 9800XT |
#12 | |
Postovi: 431
U Everestu se vidi pod Racunalo -> Senzor Koliko ja znam 9800XT bi morala imati temperaturni senzor
Lokacija: Ljubljana-Rijeka-Cres
Postovi: 154
Mislim da nema svaka 9800XT i 9600XT senzor. Ja i brati imamo iste Sapphire 9600XT (made in China), on ima ovverdrive i senzor, ja nemam. |
od LemilicE
Postovi: 4,712
Dobro došao ZiViky!!! Vidim da si me poslušao ![]() Uživaj u najbpljem forumu u Hrvata ![]()
Postovi: 154
tnx, pokusat cu ![]() I ne mozes mjeriti temp graficne ako nema senzor. S cime mislis mjeriti? |
#16 |
pUtNiK
Lokacija: na forumu
Postovi: 342
hebemu ja to nemam,fakat čudno jer imam r360:confused: ,ovaj powercolor je u qurcu mislio sam da to ide s drajverima pa sam stavio nove 4,12 al ništa, |
