Staro 08.06.2009., 00:52   #1
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,758
Nec Curved angle LCD
Nec releases Curved angle LCD screen at 2880 x 900
Ovo bi moglo biti zanimljivo, stvarno je predobar...
'The unique NEC CRV43 curved display provides a much wider field of view and greater dynamic range with its double WGXA resolution (32:10 aspect ratio). The user's taskbar is extended natively and setup is made easy to configure with one input. These features make it an ideal solution for simulation, digital imaging and command & control. "The NEC CRV43 curved display provides an excitingly immersive viewing experience for any type of user," said Keith Yanke, Director of Product Marketing for NEC Display Solutions. "Its lightning-fast response time coupled with its seamless curved screen provides enhanced comfort, decreased frustration and increased productivity. The monitor eliminates the bezel and screen gap issues that have complicated users' work environments for years."
The NEC CRV43 curved display includes the following features:
  • Seamless curved screen, which eliminates bezel and screen gap issues for increased productivity and decreased frustration (according to Center for Human-Computer Interaction - Shupp et al, presented at Graphics Interface 2006)
  • 2880 x 900 double WXGA native resolution
  • 200 cd/m² brightness
  • 0.02ms Rapid Response
  • 10,000:1 contrast ratio
  • Wide color gamut with 100% coverage of sRGB and 99.3% coverage of Adobe RGB
  • Single link DVI-D and HDMI 1.3 input connectors
  • USB 2.0 connectivity for easy use of peripherals
  • Front panel controls
  • On Screen Display (OSD) and software-based GUI, which enables advanced display control options
  • The NEC CRV43 curved display is backed by a 3-year parts and labor warranty including the backlight and will be available for July 2009 shipment with estimated street price of $7,999.
Izvor:
guru3d
Staro 08.06.2009., 01:28   #2
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,543
Za te pare kupim 2x22" i jos mi ostane 6000 dolara...
Staro 08.06.2009., 02:49   #3
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,758
pa nisam rekao da je jeftin, nego da je dobar i da mi se sviđa koncept...
se moze ovdje nesto komentirati bez osvrta na pare? mislim, normalno da je skup, ali to sad uopce nije bitno
Staro 08.06.2009., 08:46   #4
Skorn
Skorn's Avatar
Postovi: 604
izgleda baš onako... cyberpunkish... hence very good
Skorn approves
~ Reductio ad Absurdum ~
igre za PS ONE / PS2 koje me zanimaju
Skorn je offline   Reply With Quote
Staro 08.06.2009., 08:48   #5
Ubleha
Ubleha's Avatar
Lokacija: BiH
Postovi: 1,485
Ali mu je mala rezolucija za tu velicinu i lovu.
Nisam pijan sve dok mogu da ležim na podu i da se nizašta nedržim.
Ubleha je offline   Reply With Quote
Staro 08.06.2009., 08:56   #6
TomRi
Can You Hear Me? 142.8 dB
TomRi's Avatar
Lokacija: Zagreb, Kvatrić
Postovi: 2,073
Fora stvar svakako,
cijena je visoka, ali nekome tko treba toliku radnu površinu bez prekida, sumnjam da je to prepreka.
(još dobije zaobljenost gratis)
Autor xulos Pregled postova
da, no opet imaš fini prekid točno po sredini? a tu to nije slučaj.
Danas je teško biti budala, prevelika je konkurencija...
Water cooled PC
Moj najveci MOD
Novi hobby: RC model + HD kamera
TomRi je offline   Reply With Quote
Staro 08.06.2009., 11:57   #7
Hei$$e
Hei$$e's Avatar
Lokacija: Našice
Postovi: 444
Hei$$e je offline   Reply With Quote
Staro 08.06.2009., 12:07   #8
^SuperUnknown^
Prečupavi mod
^SuperUnknown^'s Avatar
Postovi: 9,104
Jel mi se cini ili su to u biti 2 panela spojena u jedan monitor, odnosno da monitor ima 2 DVI prikljucka?
Primary macine:
Apple Mac Pro 5,1
64 GB ECC DDR3 800 MHz
Geforce GTX 980 4 GB
Kingston 120GB SSD
30 TB HDDs
Sharkoon QuickPort@USB
Optiarc DVD RW AD-7170A
Mac OS X 10.12.3
Secondary machine:
Apple Mac Pro 2,1
22 GB DDR2 FB-DIMM 667 MHz
Geforce GTX 970 4 GB
Seagate 500GB 7200.10
Hitachi 1000GB 7K1000.B
Seagate 1000GB 7200.11
Hitachi 7K3000 3000GB
Mac OS X 10.10.3
Work rig:
Apple Mac Pro 1,1@2,1
13 GB DDR2 FB-DIMM 667 MHz
Geforce GTX 660 2GB
Seagate 500GB 7200.12
2xWD Black 1000GB
2xSharkoon QuickPort@eSATA
Mac OS X 10.10.3
Sony KDL-26U2000 26"@HDMI
Apple Alu Keyboard
Logitech MX518
LAP:
Apple Macbook Pro 3,1
Intel Core 2 Duo 2.53 GHz
4 GB DDR2
Kingson 180 GB SSD
Seagate 320 GB HDD
* Looking in:
* Listening to:
Technics SA-EX320
iPhone 6S 64GB black
iPad 16GB WiFi 4.3.2
* Connected via:
90/90 Mbps Iskon Trio
* "Powered" by:
UPS APC Smart-UPS1500VA
* Playing:
Tama Arstar II
Yamaha DTXPRESS IV Special
Staro 08.06.2009., 12:19   #9
TomRi
TomRi's Avatar
Postovi: 2,073
možda jesu 2,
ali na ovome što je Hei$$e dao link, ispada da su čak 4 postavljena pod 90 stupnjeva ili se to samo meni pričinjava?
Pogle prijelaze
Ništa novo.
ako je tako, onda je ovo ipak 'napredak'
Water cooled PC
Moj najveci MOD
Staro 08.06.2009., 13:03   #10
hammer_of_thor
its slightly turbocharged
hammer_of_thor's Avatar
Postovi: 5,430
Izgleda predobro
Ali cijena je stvarno nerealna.
Ne da kupiš 2 komada i ostane 6000$
Kupiš 4 i ostane ti toliko
Koji su to 22" koji koštaju preko 5000 kn?
blaa
Staro 08.06.2009., 14:41   #11
antrax
antrax's Avatar
Lokacija: Vz - Zg
Postovi: 2,930
Autor hammer_of_thor Pregled postova
recimo EIZO S2231W, taman malo preko 5k
nego super fora, ali iskreno ne vidim korist kraj visestruko jeftinijih i iskoristivijih 30" ekrana. Osim mozda za gledanje filmova kino style, al i kod toga ce ostat crnih rubova (2.35:1 omjer).
Sve u svemu vrlo skupa igracka i odlican tech demo.
Msi x79a GD65
Intel i7 3930k @ 4.7 1.4V
4x 4GB Kingston 1866 9-11-9
Gigabyte gtx 460 1gb
Samsung 830 128GB
640GB WD AAKS
WD green 1.5TB
LG drzac za kavu
Seasonic S12 500W
Coolermaster Stacker 831
HP LP2065 / LG IPS231P
Windows 7 Enterprise
Trenutno nepostojeci
Staro 08.06.2009., 17:20   #12
dmr
dmr's Avatar
Lokacija: Tuzla
Postovi: 1,267
Ma ovo je prvenstveno za igre, kakvo gledanje filmova ili ozbiljan rad??? Ovo se ubilo za simulacija voznje ili avio simulacija!
dmr je offline   Reply With Quote
Staro 08.06.2009., 18:59   #13
De5tr0yer
Avocado
De5tr0yer's Avatar
Postovi: 7,852
Vertikalna rezolucija može i bolje
nekih 1080p
Ovako se čini da je sklepano od 2 laptopovska 1440x900
Spoiler alert!
Staro 08.06.2009., 19:47   #14
pimpinjon
pimpinjon's Avatar
Postovi: 306
nekih 1080p
baš to... bar da je od 2x 1680x1050
pimpinjon je offline   Reply With Quote
Staro 08.06.2009., 21:15   #15
gnomisa
gnomisa's Avatar
Datum registracije: Feb 2003
Postovi: 1,556
taj monitor ima manu....radi neujednačenosti pozadinskog svjetla na tako velikoj površini jasno se vide "bijele fleke" odn. područja jače i manje osvjetljenosti...puno više se kuži nego kod standardnog LCD-a...
gnomisa je offline   Reply With Quote
Staro 08.06.2009., 21:32   #16
Codiac
bycod
Codiac's Avatar
Lokacija: Zagreb / Dubrava
Postovi: 6,699
Autor bluefluid Pregled postova
naravno da se treba osvrnuti na cijenu.
Autor TomRi Pregled postova
a gle onda fino uzmes izvadis ih iz kucista i stavis panel do panela i imas crtu od milimetra sto bi prezivio sa 6k dolara u dzepu
.i.
Razer Blade 15
Staro 08.06.2009., 21:38   #17
pimpinjon
pimpinjon's Avatar
Postovi: 306
a cijena nije uopće čudna. ipak je to "novi" koncept. ko i sve takve stvari. pogledajte samo kolko dođe bluray čitač. jel se isplati? ne, al dok pređe u upotrebu cijena će mu višestruko past u kratkom vremenskom roku. isto tako i za ovo. ako koncept zaživi, takvi monitori neće bit tako bolesno skupi.
Staro 08.06.2009., 22:46   #18
Munjara
Beerman
Munjara's Avatar
Postovi: 1,527
zanimljiv kocept, ali namjena je vjerujem poslovna prije svega "korisnicima kojima zbog nekog razloga treba vrlo velik zaslon financijski analitičari, NASA-ini stručnjaci i slični"
Zadnje izmijenjeno od: Munjara. 08.06.2009. u 23:30.
Munjara je offline   Reply With Quote
Staro 08.06.2009., 23:08   #19
pimpinjon
pimpinjon's Avatar
Postovi: 306
moje mišljenje je da bi se takav monitor više korisitio za gejming nego poslovno.
dobro možda ne sad neki uber skupi profesionalni kao ovaj, ali neki sljedeći modeli takvog tipa, ako će ih bit. samo pogledaj ovu sliku alienwareovog gejmerskog monitora. vjerojatno je jako dobar osjećaj igrat na nečem takvom
Staro 08.06.2009., 23:19   #20
Munjara
Beerman
Munjara's Avatar
Postovi: 1,527
može gejming ali 2880 x 900?!
Staro 08.06.2009., 23:23   #21
Mac_F
Pauk mrežar
Mac_F's Avatar
Lokacija: Zagreb (Bjelovar)
Postovi: 275
Fora stvar svakako,
Uzmeš 3 monitora i nemaš crtu po sredini.
Nešto slično je ovo: http://www.matrox.com/graphics/surroundgaming/en/home/
Autor Munjara Pregled postova
zanimljiov kocept ali namjena je vjerujem poslovna prije svega "korisnicima kojima zbog nekog razloga treba vrlo velik zaslon financijski analitičari, NASA-ini stručnjaci i slični"
mislim da njima ne smeta ta "crta po sredini"
PCAP or it didn't happen
Mac_F je offline   Reply With Quote
Staro 09.06.2009., 15:47   #22
dmr
dmr's Avatar
Lokacija: Tuzla
Postovi: 1,267
nekih 1080p
Pa u igrama i neces osjetiti razliku izmedju vertikalnih 900 i 1080, a ovako je bolje jer graficka ima posla sa 2,6MP (slicno kao kod reze 1920x1200-2,3MP). Znaci dosta je jedna 4870 i deri
Staro 09.06.2009., 16:21   #23
De5tr0yer
Avocado
De5tr0yer's Avatar
Postovi: 7,852
Autor dmr Pregled postova
Ma sve mi jasno, samo uvijek moramo ono što nećemo nikad imati bar na neki način popljuvati da se ne prodamo za to...
Spoiler alert!
