Staro 04.06.2009., 11:38   #1
stripy
a-wAnnaBe
stripy's Avatar
Postovi: 419
crt servis
Tko sve vrshi servis crt monitora? Htio bi vidjeti da li mi se isplati odrzat na zivotu josh par mjeseci 19" diamond pro 930sb. Naime javio se takozvani "vertical twitch", ili ti svako malo mi ode u 16:9 mode
jedino shta sam uspio naci je na netu je ovo:
You would have to go through all the capacitors in the power supply and
vertical deflection circuits with an ESR meter. More than likely you will
find a number of capacitors that have become high in ESR with use. This was
very common on many of these monitors.
Since there are serious safety issues when working in monitors, if you are
not properly trained and equipped to do monitor service work, you should
give the monitor out to a service centre for an estimate.
vidim da Zel-cos (micronis) radi servis, josh netko? (120kn samo dijagnostika)
unaprijed hvala.
MBO: DFI LAN PARTY UT nF4 Ultra-D
MBO DFI Lan Party DK P35-T2RS S.775
Kingmax DDR2-800 KLDE88F 2 GB
Gigabyte VGA nVidia 8800GT 512MB
Antec super-midi kućište P182B crno
Arctic Cooling VGA cooler Accelero S1
Arctic Cooling turbo modul
Pioneer DVD ± RW DL DVR-215BK SATA
Cooler Master Hyper TX2 CPU hladnjak
Corsair 520HXEU ATX 2.2 modularno
CPU INTEL Core2Duo 8400
stripy je offline   Reply With Quote
Staro 04.06.2009., 12:06   #2
Cuky
jedan i jedini :D
Cuky's Avatar
Lokacija: novi zagreb
Postovi: 5,243
ja imam samo dobrih iskustava sa zelcosom. u bivsoj firmi sam radio sa njima svakodnevno i nikad problema, sto s racunalima sto s monitorima. mislim da ti nece naplatit dijagnostiku ukoliko se odlucis na popravak. nazovi ih pa ih pitaj za detalje
