Zaključane teme
Staro 03.06.2009., 01:16   #1
lateralus_eye
lateralus_eye's Avatar
Postovi: 603
Već problemi!
Napokon osposobio komp novi, stavio Windowse. sve šljaka. instalirao crysis... sve radi. bez tranja! i odjednom pafff! blue screen! i sad opet. zašto se to moglo desava? hvala!
lateralus_eye je offline
Staro 03.06.2009., 01:23   #2
greenfly
Od nonine sestre kunjado
greenfly's Avatar
Lokacija: (Vinjro)
Postovi: 1,130
Svaki put kad se desi BSOD , windouze stvore jedan file u Minidump folderu C:/Windows.
Taj se file može "debuggirati" i saznati što je uzrok BSOD-u.
http://forums.majorgeeks.com/showthread.php?t=35246
par minuta posla...
greenfly je offline
Staro 03.06.2009., 02:01   #3
lateralus_eye
Postovi: 603
Use !analyze -v to get detailed debugging information.
BugCheck C2, {7, cd4, 2060005, 89ed49d8}
Unable to load image vsdatant.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for vsdatant.sys
*** ERROR: Module load completed but symbols could not be loaded for vsdatant.sys
evo ga! jel to to?
Staro 03.06.2009., 02:06   #4
Rain Man
Lokacija: x
Postovi: 1,447
U debuger moras upisat taj path. To ti je pod file/symbol path file... Tu kopiras symbol search path: SRV*c:\symbols*http://msdl.microsoft.com/download/symbols
Rain Man je offline
Staro 03.06.2009., 02:07   #5
lateralus_eye
Postovi: 603
evo cijeli post:
Microsoft (R) Windows Debugger Version 6.11.0001.404 X86
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\WINDOWS\Minidump\Mini060309-03.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: SRV*c:\symbols*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows XP Kernel Version 2600 (Service Pack 3) MP (2 procs) Free x86 compatible
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 2600.xpsp_sp3_gdr.090206-1234
Machine Name:
Kernel base = 0x804d7000 PsLoadedModuleList = 0x8055d720
Debug session time: Wed Jun 3 00:46:17.390 2009 (GMT+2)
System Uptime: 0 days 0:14:50.000
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
Probably caused by : vsdatant.sys ( vsdatant+476c6 )
Followup: MachineOwner
0: kd> !analyze -v
BAD_POOL_CALLER (c2)
The current thread is making a bad pool request. Typically this is at a bad IRQL level or double freeing the same allocation, etc.
Arguments:
Arg1: 00000007, Attempt to free pool which was already freed
Arg2: 00000cd4, (reserved)
Arg3: 02060005, Memory contents of the pool block
Arg4: 89ed49d8, Address of the block of pool being deallocated
Debugging Details:
POOL_ADDRESS: 89ed49d8
FREED_POOL_TAG: TCPc
BUGCHECK_STR: 0xc2_7_TCPc
CUSTOMER_CRASH_COUNT: 3
DEFAULT_BUCKET_ID: DRIVER_FAULT
PROCESS_NAME: System
LAST_CONTROL_TRANSFER: from 8054b583 to 804f9f43
STACK_TEXT:
b84fb9e0 8054b583 000000c2 00000007 00000cd4 nt!KeBugCheckEx+0x1b
b84fba30 b45b3782 89ed49d8 00000000 b84fba78 nt!ExFreePoolWithTag+0x2a3
b84fba40 b45b3450 89f933e0 89f93474 89f933e0 tcpip!TCPClose+0x16
b84fba78 b45376c6 8a916030 89f933e0 b453cb73 tcpip!TCPDispatch+0x101
WARNING: Stack unwind information not available. Following frames may be wrong.
b84fbb04 80545946 b84fbb28 8ae12640 b381ecc4 vsdatant+0x476c6
b84fbb6c 804ef19f 8a916030 89f933e0 89f933e0 nt!KiUnlockDispatcherDatabase+0x9e
b84fbc40 804ef19f 8a916030 89f933e0 89f933e0 nt!IopfCallDriver+0x31
b84fbcac 804ef19f 8ab3a020 00000000 89f933e0 nt!IopfCallDriver+0x31
b84fbcbc 80583af8 89c55638 00000000 00000000 nt!IopfCallDriver+0x31
b84fbcf4 805bb472 00c55650 00000000 89c55638 nt!IopDeleteFile+0x132
b84fbd10 805266da 89c55650 00000000 8052668e nt!ObpRemoveObjectRoutine+0xe0
b84fbd28 b44d1c0f 89e7e8e8 89e7e870 b44cecb6 nt!ObfDereferenceObject+0x4c
b84fbd3c b44d1bbc 89e7e870 b44d07a8 b84fbd68 afd!AfdFreeConnectionResources+0x38
b84fbd4c b44ce86a 89e7e8e8 8a8db0e8 8a98c030 afd!AfdFreeConnection+0x5c
b84fbd68 80576ad5 8a98c030 00000000 8056485c afd!AfdDoWork+0x51
b84fbd7c 8053877d 8a8db0e8 00000000 8ae12640 nt!IopProcessWorkItem+0x13
b84fbdac 805cff70 8a8db0e8 00000000 00000000 nt!ExpWorkerThread+0xef
b84fbddc 805460ee 8053868e 00000001 00000000 nt!PspSystemThreadStartup+0x34
00000000 00000000 00000000 00000000 00000000 nt!KiThreadStartup+0x16
STACK_COMMAND: kb
FOLLOWUP_IP:
vsdatant+476c6
b45376c6 ?? ???
SYMBOL_STACK_INDEX: 4
SYMBOL_NAME: vsdatant+476c6
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: vsdatant
IMAGE_NAME: vsdatant.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 48ee7375
FAILURE_BUCKET_ID: 0xc2_7_TCPc_vsdatant+476c6
0: kd> lmvm vsdatant
start end module name
b44f0000 b455b000 vsdatant T (no symbols)
Loaded symbol image file: vsdatant.sys
Image path: vsdatant.sys
Image name: vsdatant.sys
Timestamp: Thu Oct 09 23:11:17 2008 (48EE7375)
CheckSum: 000657E1
ImageSize: 0006B000
Translations: 0000.04b0 0000.04e4 0409.04b0 0409.04e4
Staro 03.06.2009., 02:14   #6
Rain Man
Lokacija: x
Postovi: 1,447
Vidis i sam sto je problem. Pomotali su ti se IRQ-i, problem s driverima. Obrisi sve sto imas ustekano u PCI i probaj razmjestit kartice. Instaliraj za sve svjeze drivere. Obrisi i drivere od grafe i instaliraj novije (ili starije).
Rain Man je offline
Staro 03.06.2009., 02:20   #7
lateralus_eye
Postovi: 603
Autor Rain Man Pregled postova
Sve što imam uštekano u PCI utore je Wireless D-Link kartica i Gainward grafička. Danas sam instalirao nove drivere za grafičku, a jučer sam instalirao sa cd-ea za D-Link karticu.
Staro 03.06.2009., 02:33   #8
Rain Man
Lokacija: x
Postovi: 1,447
Probaj sa neta skinut zadnje drivere za chipset koji koristi taj d-link. Imas sto clockano? Probaj resetirat BIOS na default pa vidjet onda. Probaj i starije drivere od nvidie, ne mora znacit da su zadnji driveri stabilni.
Rain Man je offline
Staro 03.06.2009., 02:40   #9
lateralus_eye
Postovi: 603
Ma da u biti mislim da je zbog novih driver-a za grafičku. Jer jučer sam isto sve polako sređivao na kompu, kao i danas ujutro dok popodne nisam stavio nove drivere i onda se počelo to dešavati... tj točno dok se instalirao novi driver... baš ću vidjet kad maknem nove i stavim stare...
nisam još ništa OC-ao za sad...
Staro 03.06.2009., 03:05   #10
greenfly
greenfly's Avatar
Lokacija: (Vinjro)
Postovi: 1,130
Ima i ZoneAlarm ruke u tome...
vsdatant.sys je vezan za Zonealarm..
http://forums.zonealarm.com/zonelabs...message.id=103
greenfly je offline
Staro 03.06.2009., 03:47   #11
lateralus_eye
Postovi: 603
Autor greenfly Pregled postova
da skužih to! maknuo sam i zone alarm pro pa ćemo vidjet dal će šta javljat....
jel mi dosta Kaspersky Internet Security na kompu što se tiče zaštite?
Staro 03.06.2009., 05:23   #12
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,752
Da, KIS je dobar, iako ja preferiram NOD...
Sn4k3 je offline
Staro 03.06.2009., 10:37   #13
greenfly
greenfly's Avatar
Lokacija: (Vinjro)
Postovi: 1,130
Autor lateralus_eye Pregled postova
Da, dosta je.....
greenfly je offline
Staro 03.06.2009., 11:29   #14
lateralus_eye
Postovi: 603
Evo do sad niti jedan BSOD! Očito je bio problem ili u novim driverima od grafičke ili u zone alarm-u! Hvala vam na pomoći dečki!
Staro 03.06.2009., 17:09   #15
lateralus_eye
Postovi: 603
evo mene opet!
Loading Dump File [C:\WINDOWS\Minidump\Mini060309-10.dmp]
Machine Name:
Debug session time: Wed Jun 3 16:00:15.625 2009 (GMT+2)
System Uptime: 0 days 0:08:16.359
*** WARNING: Unable to verify timestamp for nv4_mini.sys
*** ERROR: Module load completed but symbols could not be loaded for nv4_mini.sys
BugCheck 100000EA, {89af87c0, 8a84b348, ba4e3cbc, 1}
Probably caused by : nv4_mini.sys ( nv4_mini+505fb )
1: kd> !analyze -v
THREAD_STUCK_IN_DEVICE_DRIVER_M (100000ea)
The device driver is spinning in an infinite loop, most likely waiting for
hardware to become idle. This usually indicates problem with the hardware
itself or with the device driver programming the hardware incorrectly.
If the kernel debugger is connected and running when watchdog detects a
timeout condition then DbgBreakPoint() will be called instead of KeBugCheckEx()
and detailed message including bugcheck arguments will be printed to the
debugger. This way we can identify an offending thread, set breakpoints in it,
and hit go to return to the spinning code to debug it further. Because
KeBugCheckEx() is not called the .bugcheck directive will not return bugcheck
information in this case. The arguments are already printed out to the kernel
debugger. You can also retrieve them from a global variable via
"dd watchdog!g_WdBugCheckData l5" (use dq on NT64).
On MP machines it is possible to hit a timeout when the spinning thread is
interrupted by hardware interrupt and ISR or DPC routine is running at the time
of the bugcheck (this is because the timeout's work item can be delivered and
handled on the second CPU and the same time). If this is the case you will have
to look deeper at the offending thread's stack (e.g. using dds) to determine
spinning code which caused the timeout to occur.
Arguments:
Arg1: 89af87c0, Pointer to a stuck thread object. Do .thread then kb on it to find
the hung location.
Arg2: 8a84b348, Pointer to a DEFERRED_WATCHDOG object.
Arg3: ba4e3cbc, Pointer to offending driver name.
Arg4: 00000001, Number of times "intercepted" bugcheck 0xEA was hit (see notes).
Debugging Details:
FAULTING_THREAD: 89af87c0
DEFAULT_BUCKET_ID: GRAPHICS_DRIVER_FAULT
CUSTOMER_CRASH_COUNT: 10
BUGCHECK_STR: 0xEA
PROCESS_NAME: cnc3game.dat
LAST_CONTROL_TRANSFER: from b91925fb to 8052b8fa
STACK_TEXT:
b4aa0d14 b91925fb b7e84410 b93c2614 8a859260 nt!READ_REGISTER_ULONG+0x6
b4aa0d1c b93c2614 8a859260 8a821808 00009410 nv4_mini+0x505fb
b4aa0d20 8a859260 8a821808 00009410 8a967418 nv4_mini+0x280614
b4aa0d24 8a821808 00009410 8a967418 8a821808 0x8a859260
b4aa0d28 00000000 8a967418 8a821808 7029fc08 0x8a821808
STACK_COMMAND: .thread 0xffffffff89af87c0 ; kb
FOLLOWUP_IP:
nv4_mini+505fb
b91925fb ?? ???
SYMBOL_STACK_INDEX: 1
SYMBOL_NAME: nv4_mini+505fb
MODULE_NAME: nv4_mini
IMAGE_NAME: nv4_mini.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 4990a8d2
FAILURE_BUCKET_ID: 0xEA_IMAGE_nv4_mini.sys_DATE_2009_02_09
Maknuo sam drivere, stavio nove i opet ista greška... pomoć!
Staro 03.06.2009., 20:04   #16
Rain Man
Lokacija: x
Postovi: 1,447
Imas friski sistem gore? Nparavi format c! Izgleda da te driveri muce. Probaj ako ima kakvih driver cleanera pa obrisat i ocistit komp od drivera jer ovako ces izludit s BSOD-om svako malo.
Rain Man je offline
Staro 03.06.2009., 20:40   #17
greenfly
greenfly's Avatar
Lokacija: (Vinjro)
Postovi: 1,130
Probaj OVO
greenfly je offline
Zaključane teme
