Staro 27.04.2009., 23:12   #1
Ma$teR
Ma$teR's Avatar
Lokacija: BiH/Hrv
Postovi: 50
Razlika izmedju Acer Aspire 5530 i Acer Aspire 5530G?
Ovako,
znaci vidio sam na hgspot(BiH) ovaj laptop :
http://hgspot.ba/opis.aspx?ID=51438
Kome se neda otvarati evo njegove specifikacije ovdje:
AC AS5530-602G16Mi,LX.APV0C.002, Acer, AS5530, AMD, Athlon 64 X2, QL60, 1,90 GHz, 1x 2048 MB, 15,4", 1280x800 (WXGA), ATI Radeon HD3200, SATA 160 GB, Linux, DVD±RW DL, 802.11b/g, Bluetooth, Kamera 0.3M
E sada, on je dosta povoljan i izgleda privlacno.Sada mene zanima, na netu sam vidio da ova vrsta ima neke 3 graficke kartice u sebi.
Evo link : http://komku.blogspot.com/2008/09/ac...indows-xp.html
E sada, sve sam ja to skuzio, neki imaju 4 gige rama, neki 2, neki 160 diska neki 320 diska.E, sada mene ovo veoma zanima :
Graphics
* ATI Mobility Radeon™ HD 3650 with up to 2048 MB of HyperMemory™ (256 MB of dedicated GDDR3 VRAM, up to 1792 MB of shared system memory*), supporting Unified Video Decoder (UVD), OpenEXR High Dynamic-Range (HDR) technology, Shader Model 4.1, Microsoft® DirectX® 10.1 (* depending on size of system memory)
* ATI Mobility Radeon™ HD 3470 with up to 2048 MB of HyperMemory™ (256 MB of dedicated DDR2 VRAM, up to 1792 MB of shared system memory)*, supporting Unified Video Decoder (UVD), OpenEXR High Dynamic-Range (HDR) technology, Shader Model 4.1, Microsoft® DirectX® 10.1 (* depending on size of system memory)
* ATI Radeon™ HD 3200 Graphics with up to 2048 MB of HyperMemory™ (256 MB of dedicated system memory, up to 1792 MB of shared system memory*), supporting Unified Video Decoder (UVD), OpenEXR High Dynamic-Range (HDR) technology, Shader Model 4.0, Microsoft® DirectX® 10.0 (* depending on size of system memory)
Naime, ovaj laptop ima 2 dedicirane graficke kartice te jednu integriranu, i to daje velike performanse.Tako nesto...nisam bas skuzio.
Znaci mene zanima, jel sve verzije imaju te 2(ili 3) graficke kartice?
I uopceno koja je razlika izmedju 5530G i obicnog 5530 ?
Posto nigdje na netu nisam mogao naci nesto vise o ovome laptopu, a jako me zanima.
tnx!
Ma$teR je offline   Reply With Quote
Staro 27.04.2009., 23:19   #2
Problem
Pijem samo KAJ
Problem's Avatar
Lokacija: Vž
Postovi: 2,691
to ne znaci da ima te sve tri graficke, vec jednu od njih, ovisi o modelu
Staro 27.04.2009., 23:20   #3
Milentije
Adrenaline junkie
Milentije's Avatar
Lokacija: Doboj - Banja Luka
Postovi: 3,593
Nema sve tri odjednom u sebi nego samo jednu. Dakle mozes birati (odnosno, trebalo bi da mozes birati) jednu od te tri.
Staro 27.04.2009., 23:25   #4
the_ghost
lar~
the_ghost's Avatar
Postovi: 1,557
malo si se zbunio ima jednu od te tri, ovisno koji tocno model, kao sto si copy/pasteao, tvoj ima ATI Radeon HD3200
Staro 27.04.2009., 23:28   #5
Ma$teR
Ma$teR's Avatar
Lokacija: BiH/Hrv
Postovi: 50
Ne, ovaj laptop ima 2 grafe, tj valjda 1 ima 3650 + 3200 a drugi 3470+3200.
Evo to sam vidio ovdje :
http://www.youtube.com/watch?v=pOxZyGztNRE
Staro 28.04.2009., 00:14   #6
Milentije
Adrenaline junkie
Milentije's Avatar
Postovi: 3,593
Two graphic cards are put to use right away in the Aspire 5530G for graphic computing. Two Mobility Radeon HD3470 chips in a Hybrid Crossfire combination are applied.
Ni meni vise nije jasno. :S
LINK 1, LINK 2 (na jednom pise jedno, na drugom drugo)...
Staro 28.04.2009., 11:22   #7
Problem
Pijem samo KAJ
Problem's Avatar
Lokacija: Vž
Postovi: 2,691
hmm, pa kaj ne pise na tvoja oba linka da je hybrid?
Staro 28.04.2009., 11:50   #8
Ma$teR
Ma$teR's Avatar
Lokacija: BiH/Hrv
Postovi: 50
Koliko sam ja skontao da je razika u ta dva modela, da jedan ima jacu sekundarnu graficku, vise diska i vise rama, a ovaj drugi to slabije.
A uglavnom su odlicna oba 2 , za 900 KM (oko 460 Eura).
Staro 04.05.2009., 11:46   #9
serke
serke's Avatar
Postovi: 49
Na novim chipsetovima moguće je imati dvije grafičke (jednu integriranu i jednu dedicated). U BIOSu se mogu i switchati koja se koristi. OSovi poput Viste (ili nove sedmice) mogu i bez ulaska u BIOS switchati te grafičke. Recimo u High performance modu rade sa dedicated grafuljom, a kad se prebaci u Power save pali se integrirana. No, ljudi koji imaju takve sisteme kažu da to baš i ne funkcionira tako glatko kako se priča.
serke je offline   Reply With Quote
