Staro 21.04.2009., 23:43   #1
rams
80286
rams's Avatar
Datum registracije: Jul 2004
Lokacija: Dingolfing, DE
Postovi: 1,724
Kubuntu 8.10 + HD4670
Stavio sam Kubuntu 8.10 u dual-boot sa XP-om. Prva stvar koju zelim srediti su driveri za grafu i rezolucija. Skinuo sam drivere sa AMD-ove stranice i slijedio sa ove stranice metodu 2, odnosno Manual install method. Sve prodje dobro no nakon restarta kompa se monitor blesira i kaze "Signal out of range".
Pokrenuo sam u recovery modu i odabrao "Try to fix X" nakon cega mi je vratio originalni xorg.conf, a evo prilozit cu xorg.conf kako izgleda nakon instalacije drivera za slucaj da u njemu nesto treba mjenjati.
Code:
# xorg.conf (X.Org X Window System server configuration file)
# This file was generated by dexconf, the Debian X Configuration tool, using
# values from the debconf database.
# Edit this file with caution, and see the xorg.conf manual page.
# (Type "man xorg.conf" at the shell prompt.)
# This file is automatically updated on xserver-xorg package upgrades *only*
# if it has not been modified since the last upgrade of the xserver-xorg
# package.
# Note that some configuration settings that could be done previously
# in this file, now are automatically configured by the server and settings
# here are ignored.
# If you have edited this file but would like it to be automatically updated
# again, run the following command:
#   sudo dpkg-reconfigure -phigh xserver-xorg
Section "ServerLayout"
	Identifier     "aticonfig Layout"
	Screen      0  "aticonfig-Screen[0]-0" 0 0
EndSection
Section "Files"
EndSection
Section "Module"
EndSection
Section "Monitor"
	Identifier   "aticonfig-Monitor[0]-0"
	Option	    "VendorName" "ATI Proprietary Driver"
	Option	    "ModelName" "Generic Autodetecting Monitor"
	Option	    "DPMS" "true"
EndSection
Section "Device"
	Identifier  "aticonfig-Device[0]-0"
	Driver      "fglrx"
	BusID       "PCI:4:0:0"
EndSection
Section "Screen"
	Identifier "aticonfig-Screen[0]-0"
	Device     "aticonfig-Device[0]-0"
	Monitor    "aticonfig-Monitor[0]-0"
	DefaultDepth     24
	SubSection "Display"
		Viewport   0 0
		Depth     24
	EndSubSection
EndSection
Sve sto zelim postici je rezolucija 1280x1024 na 60Hz i konacno Compiz da radi, ubijam se s time vec dva dana i nikako pa molim pomoc. Da li postoji neka druga ili bolja metoda instalacije drivera? Reinstalacija Kubuntua nije problem ako i to treba napraviti. Drugi izbor mi je Ubuntu 8.04.1 pa ko je mozda bolje s njim stavit cu njega, iako isti problem imam i snjim.
rams je offline   Reply With Quote
Staro 22.04.2009., 07:44   #2
Brutus
Postovi: 35
pogledaj ovdje !
Brutus je offline   Reply With Quote
Staro 22.04.2009., 07:44   #3
tomek@vz
tomek@vz's Avatar
Lokacija: München/Varaždin
Postovi: 4,704
Hm...badava sam radio tutorial kak mi se čini...
1) Synaptic > fglrx
2) ctrl-alt-backspace
3) (ako ne šljaka 1 i 2) dpkg-reconfigure xserver-xorg
Staro 22.04.2009., 20:14   #4
rams
80286
rams's Avatar
Postovi: 1,724
Nisi pisao badava toturial, ali cisto instaliranje fglrx-a preko Synaptica prodje bez ikakvog ucinka, ni nakon dpkg-reconfigure xserver-xorg ne bude ama bas nista.
Moram vidit ovo sto je Brutus stavio jos.
Staro 22.04.2009., 21:40   #5
tomek@vz
tomek@vz's Avatar
Postovi: 4,704
Hm...nisi jedini s tim problemom...
http://forums.opensuse.org/hardware/...870-fglrx.html
https://bugs.launchpad.net/ubuntu/+s...er/+bug/290704
A ati driver? Ako ništa drugo ne profunkcionira,probaj sa vesa driverom.
