Staro 21.04.2009., 14:51   #1
Female
Never Registered User
Female's Avatar
Postovi: 92
DDL problem
Kod instalacije pojedinih aplikacija ili programa ( ne većine, većina je ok i radi kako treba) imam ovaj prozor kad pokrenem instalaciju:
i ne ide dalje!
Jel mogu nekako rijesit a da nije format disc?
Hvala unaprijed!
Female je offline   Reply With Quote
Staro 21.04.2009., 15:24   #2
thopok
Lokacija: Splity
Postovi: 3,003
Staro 22.04.2009., 00:07   #3
Female
Female's Avatar
Postovi: 92
Hvala..ali nisam tako riješila.
Updejtiraja sam ali posto je kod mene SP3 nije bilo potrebno instalirati update. (inace je na automatic update wind)
Pa sam skinula shell32.ddl i iz drugog OS-a ga ubacila u folder windows/system32/ (koji je bio par megabajta a postojeci oko 23-30 mb) i replaceala, i pokrenem wind. xp i ne moze se dic. Vratim ponovo stavi file shell32 i ok je , pokrenuo se wind xp normalno opet..ali error iz pocetka price imam i dalje..
Staro 28.04.2009., 15:59   #4
blava
blava's Avatar
Lokacija: スラボニア
Postovi: 3,061
  • To resolve this problem, follow these steps:
    Step1:Install all important updates from the following Microsoft Web site:
    http://update.microsoft.com/microsoftupdate
    Step2:Try to run the program that did not start again. If the program starts and if you do not receive the error message in the "Symptoms of the problem" section, you are finished. If the error continues, follow steps 3 through 5.
    Step3:Visit the following Microsoft Web site:
    http://www.microsoft.com/downloads/d...displaylang=en
    Step4:Click Download, and then click Run. If the Download button is not available, you must first click Validate to validate your copy of Windows.
    Step5:Follow the instructions that appear on the screen to install update 935448.
    More other related dll files: untfs.dll, unzip32.dll, UPDDRV9X.DLL, updprov.dll
