Staro 12.04.2009., 03:31   #1
MasaKrisT
MasaKrisT's Avatar
Lokacija: Požega
Postovi: 173
Problem sa BOLDANIM slovima u windowsima,desktopu,forumu...
http://img14.imageshack.us/my.php?im...lemboldano.jpg
Dakle,jucer sam cackao u regeditu rezoluciju za warcraft 3, da ju dignem na 1680*1050.To sam uspjesno i napravio no izgleda da nakon toga se dogodilo ovo.
Sva slova su boldana,postovi na forumu nakoseni i necitljivi itd...ako netko ima rjesenje molim pomoc.Hvala
Problem je sto neznam koji su brojevi pisali u hexadecimalnom sustavu...Ovo je stvarno necitljivo pa ako netko ima ideju molio bih pomoc.Usput isprike ako sam promasio topic ili nesto pola 4 ujutro jeHvala svima
MasaKrisT je offline   Reply With Quote
Staro 12.04.2009., 10:10   #2
Željac
sto da napisem ?!
Željac's Avatar
Postovi: 880
To fix this issue follow these steps:
1. Click Start -> Run. If you cannot locate the 'Run' item, then click 'Window Key' + 'R'.
2. In the run box, type: c:\windows\fonts (Replace c: with the drive letter where the OS is installed)
3. The fonts window will open. Click 'Alt' + 'F' to activate the menu. Click 'Install New Font' in the menu.
4. In the folders dialog, browse to c:\windows\fonts where c: is the OS drive letter.
5. All fonts would now appear under 'List all fonts'.
6. Click 'Select All' and then click 'Install'.
7. Confirm the windows permission dialog.
8. A replace file dialog would appear. Click on 'Yes' to each and every dialog that appears. This will ensure that fresh entries for fonts are written in the registry. To avoid clicking, press and hold 'Alt' key - then press 'Y' key for every dialog that appears.
Onda restart.
meni je to pomoglo. meni su takva slova bila nakon uninstalla Left4Dead-a
Staro 12.04.2009., 11:36   #3
MasaKrisT
MasaKrisT's Avatar
Lokacija: Požega
Postovi: 173
Hvala,radi!
