Staro 02.04.2009., 23:38   #1
borgy
kenova
borgy's Avatar
Lokacija: München / Dubrovnik
Postovi: 918
Managed Flash Technology (MFT)
Mislim da je pametnije otvoriti posebni topic za MFT jer je previse postova u topicu o SSD-ovima.
Sto se tice benchmarka MFT-a koje je objavio igor_ri: http://forum.pcekspert.com/showpost....&postcount=433
Potrebno je procitati ovaj dio MFT manuala ( dostupan na http://downloads.managedflash.com/do...owsinstall.pdf ):
You can run standard benchmarks against MFT and you will be astounded at some of the results you
get. That said, some may overstate MFT’s performance because MFT’s performance is, in principal,
dependent upon the degree of free space, and we increase free space by virtualizing sectors expressed
as all zeros. Thus, some tests may indicate that we are performing IO at gigabytes per second when
the same is physically impossible.
Poslao sam par mailova Easyco-u u vezi ovoga, odgovorili su da se prilikom testova kod kojih se na disk ispisuju same nule sve operacije preusmjeravaju u RAM. Dakle, kad zavrtite alat kao sto je CrystalDiskMark uglavnom radite bench svog rama i procesora. Kao sto dalje pise u manualu:
Our Benchmark avoids this problem by assuring that the data tested against is filled with mixed
data. Our Benchmark also simplifies testing in that it tests a broad range of IO sizes as part of a
single test providing a useful profile of the actual drive performance.
Ukratko, sigurno relevantni bench alat nakon instalacije MFT-a je spomenuti programcic koji ce vam nakon testova izbaciti tablicu u kojoj su realne brojke - sve unutar maksimalnog throughput-a vaseg flash kontrolera i SATA sucelja.
Drugi alat je dobro konfigurirani IOmeter.
To je potvrdjeno u mail-u iz Easyco-a:
When in doubt, perform your tests using the benchmark software we provide. This can be used to test both MFT volumes and non-MFT volumes. I also believe that IOmeter performs, or can be set to perform its testing with non-zero fill.
With MFT properly installed, write rates should be around 80% to 90% of the linear write rate of the drive, though cpu clock speed will affect results.
Dodatno sam pitao kada ce izaci verzija 1.0 i zasto su sve verzije 0.9x kada je sve "stabilno". Odgovor je da ce verzija 1.0 izaci za minimalno mjesec dana mozda dva. Trenutni problemi nastaju zbog windows update-a koji zna pregaziti mft-ove drivere, tada nastaje katastrofa ako nemate backup.
Dakle mft 0.9x je siguran ako prije svakog windows update-a napravite backup vaznih podataka. Navodno su problem i cesta nepredvidiva resetiranja sutava.
Sa linux verzijom je sigurno sve ok, te nju i preporucuju ako su podaci osjetljivi. Odgovorili su da je savrseno stabilna od 2007.
Toliko za sada
borgy je offline   Reply With Quote
