23.03.2009., 18:36 | #2 |
Postovi: 22,664
Krivo si se odrazio, ima ikone ali prikazuje krivu tj. onu za ne definirane slućajeve. Potraži "restore original icons on xp". Jedna od procedura: Restore Default Icon For My Computer, Recycle Bin, Others SUMMARY: Revert your My Computer, My Documents, or Recycle Bin icon on your Windows XP desktop back to the default. Has the icon for one of the following desktop items changed and you want to revert it back to the default? * My Computer * My Documents * My Network Places * Recycle Bin (full) * Recycle Bin (empty) 1. Right-click an empty area of the desktop and choose "Properties". 2. When the "Display Properties" multi-tabbed dialog box appears, click the "Desktop" tab. 3. Click the "Customize Desktop" button. 4. A "Desktop Items" dialog box will appear. Make sure the "General" tab is selected. 5. Choose an icon to change back. 6. Click "Restore Default". 7. Click "OK" on the dialog boxes to close them. Slično s opcijom: Right Click anywhere on the desktop ...you will reach Display Properties.... now under the "Desktop Tab"....click "Customize Desktop..." Now Desktop Items will show up click the "Web Tab".... Under the web tab....uncheck all the check boxes....including "lock desktop items" and all the pages listed (including hompage).... This should do it..... From this on use bmp or jpg or png as you desktop background only...a gif will re-enable the web option and cause the same problem.... so after this change your desktop background... |
23.03.2009., 19:57 | #5 |
Postovi: 22,664
Pa upotrebi Google kao i ja sada. Probaj ovo: http://www.tomshardware.co.uk/forum/...3383_35_0.html |
