Staro 04.03.2009., 16:38   #1
Gilbert5
Agent 0
Gilbert5's Avatar
Lokacija: Kutina - ZG
Postovi: 4,312
Nvidia GeForce GTS 250
Staro 04.03.2009., 18:50   #2
×DaXxX×
oldschool plaYer
Postovi: 10
super, jacja je od 4850, vele da ce cijena bit manja od 9800gtx )
jer zna ko tocno kolka ce bit cijena i kad ce doc u ducane kod nas?
×DaXxX× je offline   Reply With Quote
Staro 04.03.2009., 19:25   #3
danc00
Why so serious
danc00's Avatar
Postovi: 3,415
Recimo 1300-1400kn ! Na BGF GTS250 nisu ni kuler promijenili, dam se kladit da ak se izgrebe naljepnica dole da ispod piše 8800GTS 512, koji su to frikovi u nvidiji !
danc00 je offline   Reply With Quote
Staro 04.03.2009., 19:33   #4
DraŽ
DraŽ's Avatar
Lokacija: Petrinja
Postovi: 904
Autor ×DaXxX× Pregled postova
Netko već puši marketing!
Znaci ovaj put su dodali cak i 512Mb pored vecih clockova, a na ono 2Gb memorije : NO COMMENT!
Zen5 PCIvy bridge Notebook
CPU: AMD Ryzen 7 9700x, CO per Core, CS -20 (Mid, High, Max)
COOLER: Arctic Cooling Liquid Freezer III 420 A-RGB
MBO: MSI Tomahawk X870
RAM: Corsair Vengeance DDR5 32GB, 6000MHz CL28
GPU: MSI SuprimX Nvidia GeForce RTX 3070
NVM1: Samsung Evo 970 2TB
HDD1: WD Red 4TB, WD40EFRX
HDD2: WD Blue 6TB, WD60EZRZ
HDD3: WD Blue 6TB, WD60EZRZ
PSU: Corsair RMx 850W, ATX3.1
CASE: Fractal Meshify 2 XL
VENTS: 4x Arctic Cooling P14 PWM PST A-RGB
OS: Win 11 Pro, 64-bit
MONITOR: AOC Q3279VWFD8 - 32", IPS, 2560x1440
TV: LG 7450
MOUSE: Logitech MX Master 3
KEYBOARD: Logitech MX Keys
GAMEPAD: XBOX One
HEADPHONES: Sennheiser HD560s
DELL Inspiron 15R, 5520
CPU: Intel Core i7 3632QM, 2.20Ghz, turbo 3.20GHz
RAM: DDR3, 6GB (4GB + 2GB), 1600Mhz CL11
GPU: AMD Radeon 7670, Intel HD4000
SSD: Samsung EVO 850, 250GB
SCREEN: 15,6 inch LCD, 1366x768
OS: Ubuntu 24.04, 64-bit
DraŽ je offline   Reply With Quote
Staro 04.03.2009., 19:53   #5
thedream
thedream's Avatar
Lokacija: Zagreb ( Šibenik )
Postovi: 5,458
Ne vidim nikog normalnog tko bi pored polovnih g92 core kartica za 700kn,išao dati duplo više,ili 70% više love za ovakvu novu,ali dobro. Ima nas svakakvih.
Možda da sam zabrijao na novo-novo,pa nikad u životu kupio polovno,ali onda bi prije za tih 1400kn od Celeta užicao Force3D 4870.
@gem - ne prihvaćam to trebala bi biti,bez dokaza , previše puta sam se narajcao. Ali vidit ćemo,samo mislim da je zamjena glupa,tj. neisplativa sa bilo koje g92 jezgre. A pogotovo kad će uvijek biti ljudi koji daju polovne za 650kn. To treba odma uzet.
Zadnje izmijenjeno od: thedream. 04.03.2009. u 20:15.
Staro 04.03.2009., 20:02   #6
Gemmy
smeghead
Gemmy's Avatar
Postovi: 3,183
ajde plus im je sta su manje, i vecina zahtjeva samo jedan 6-pinski prikljucak za napajanje..
minus je sta ce im cijena biti oko 150 usd sta bi trebala biti i cijena 4870 po novome..
Staro 04.03.2009., 20:26   #7
Burko
Osobni opis - pitaj me
Burko's Avatar
Postovi: 2,317
trebao bi se pojaviti S3 sa grafickom naziva FullPro V12 XXX Limited Edition, garant bi naletilo na automatski odusevljenje "ekipe". btw, nocas ili ujutro sutra iscupam sva mjerenja u igrama (AVG fps), pa postam mozda u neku povecu temu sa usporedbama u postotcima (%). ovako sto sam dosao do pola, u svega par igara je GTS 250 osjetno jaca od 4850. a paz' ironije, u tim igrama je i od 4850 x2 jaca. onak, nemoguce, pogotovo na 1920x1200 i 2560x1600.
sve u svemu, isti shit kao sa pocetka 8800GTS, nazalost. sto sam znao, ali se nadam barem nekom poboljsanju u perfomansama. to se kod atija barem vidi, ne pakiraju isti k svaki put u ljepsi celofan.........
Staro 04.03.2009., 21:10   #8
Romano.Cule
Outer Space
Romano.Cule's Avatar
Lokacija: Vinkovci
Postovi: 836
Pa dokle ce vise valjati taj g80 cip.Ako je ijedna firma iscijedila neki cip do maksimuma,onda je to nVidia i gf8800.Kladim se da ce cim predju na 40nm izbaciti g80/92 cip pod nazivom gtx 320
Staro 04.03.2009., 21:17   #9
thedream
thedream's Avatar
Postovi: 5,458
Nešto "valja" dok se na tom nečemu da odigrati na nativnim rezolucijama na medium/high detaljima većina trenutno dostupnih igara,prema tome 8800 serija možda i je,po pitanju nasljednika,dala svoje. Ali po pitanju performansi, daleko je to još od EOL-a.
Još uvijek za 450kn nema bolje grafe od 8800GTS 320. Ili za 650kn 8800GT 512 ili 9800GT kao ona na newsima.
A vidiš kljaja ima Ultru,gile ima GTX i sve uredno vrte najnovije igre. Dakle valjaju.
Staro 04.03.2009., 21:37   #10
Burko
Burko's Avatar
Postovi: 2,317
hm . ok, stoji. ali paz' gluposti. ti sad imas E8400 koji radi na 3GHz, i ima 6MB cachea. i super cpu, bas je lijep. i prode recimo godina - godina i nesto, i intel "lansira" f9200, koji radi na 3,13GHz i ima istih 6MB cachea. i dalje je to lijep i sposoban procesor, ali zadnja cijena onog pocetnog e8400 je bila cca 1000 kuna, a pocetna novog f9200 je 1600 kuna. i intel kao proizvodac nije napravio nista nego malo tvornicki digao takt, ali zgrnuo poprilicno vecu paru u dzep za isti proizvod. i onda cijena najnize opadne na 200 kuna vise nego onaj pocetni e8400, kad evo novog intela - m10001 koji ima jos malo veci takt na 3,25GHz, ali mu cijena opet je visa nego krajnja najniza f9200. kuzis sta hocu reci, jebes takvu politiku......... sta je falilo 8800GTS? imenu, a i cijeloj kartici?
dok sa druge strane napredovanje kod atija se barem vidi u generacijama, pocevsi od 2900 pro/xt kao dragulja, pa 3000 serija, i sada 4000 serija koja je pri izmaku. ali barem ne prodaju isti proizvod u drugacijem celofanu svakih godinu dana, ups, sa razlikama od 5% u perfomansama .
Staro 04.03.2009., 21:47   #11
thedream
thedream's Avatar
Postovi: 5,458
Autor Burko Pregled postova
Vrag me odnio ako sam išta razumio.Sisčani,valjda.
Radi na 3.6,a na zraku sa 2x2gb meme na 900mhz ide na 450x9,dakle preko 4ghz. A to je već the frekva za jako dobro igranje,jer za rad u Visti i ostalim aplikacijama koje koristim za posao mi je i 2ghz single-core dovoljno.
Ružan je proc,pitaj Luxxa od njega sam uzeo.
Mislim da znam šta si htio reći,al vrag me odnio ako sam shvatio način na koji si to htio.
Kakvih 5%?! Jel ti znaš razliku u brzini recimo punokrvnih primjeraka 2900pro,evo recimo,pa 3870 DDR4,pa sad 4850 i 4870 DDR3/5? Ako si naumio ATi-jem povući paralelu sa Nvidijom, pa nije baš 5% između 8800GTS 320 i 9800GTX+ kartice. Možda i je više na ATi-ju,gledano generacijski,ali to je kao da uspoređujemo sada 7900GT sa 8800,kojih ima i GS,i GT,i GTS 320,512 pa opet sa 9800GTX+. Nije baš to sad 5%.
Bolje im ide tečaj marketinga,šta drugo reći. Ali opet to netko kupuje.
Staro 05.03.2009., 02:22   #12
Burko
Burko's Avatar
Postovi: 2,317
recimo da je takva situacija sa intelom, da svako malo daje isti proizvod van, samo malo (prakticki zanemarivo) jaci, ali svaki put sa podebljanom cijenom usporedujuci staru cijenu? paralela - koliko je 9800GTX jaca od 8800GTS G92? i onda po drugi put, koliko je GTS 250 jaca od 9800GTX? to htjedoh reci, ati tu ne igra nikakvu ulogu, na to se odnosilo onih 5% razlike u perfomansama, na "nove" nvidije. samo sto nije cijena jednaka, taman kad jedna dosegne neku najnizu cijenu koju si je netko zacrtao kao najnizu do koje se ide, oni isti klinac upakiraju u drugo ime i malo dignu, i po drugi put prodaju po znatno visoj cijeni.
fer potez od nvidie? jer je ipak debela vecina korisnika malo ili nimalo upucena u it svijet, i vide novo ime - kupuj.
btw, nije ni cudo sto nvidia nema problema sa driverima, kad je u vec dvije i vise godine vrte u krug .
sto se tice cijene, eh kako bi bio sretan da bude kao sa 9800GTX kad je dosla kod nas. sjecate se cijene? evo je: klik.
da sumiram zasada moje misljenje, kartica koja je videna vec par puta. ali me najvise i jedino zanima cijena po kojoj ce se prodavati prvih mjesec-dva kod nas, cisto jer je sada jedna 9800GTX+ nekih 1350 kuna srednja cijena.
Staro 05.03.2009., 08:40   #13
thedream
thedream's Avatar
Postovi: 5,458
A čuj,rebranding nije zakonom kažnjiv. A dok je tome tako,ne znam ustvari zašto bi to bilo kažnjivo i drugačije,i dok ima ljudi koji će to kupiti,nvidia stoji ganc solidno,i više od toga. Ovo si dobro rekao za drivere,ironično,ali točno. Ustvari i je super da 6,7 kartica serije 8000 i 9000 praktički može raditi sa jednim driverom unutar 10% performansi. Ali kažem,nije baš 10% između 8800GTS 320 i 8800GTS 512/ 9800GTX+.
Možda da kupujem novo,ganc,kako sam napisao..pa ajd,cijena bude li-la, pa se čovjek odluči za ovo zato šta je ima seriju 2xx u nazivu. Uostalom ako Creative može X-fi Audio prodavati pod X-fi,umjesto SB Live! 24bit/AudigySE, ipak X-fi moćnije zvuči,a isti stari audioproc ima, ne vidim zašto Nvidia nebi rebrandala svako malo g92. Ali bliži se pomalo kraj tome,ovo se obično radi kad se uvodi novi proizvod,ili kad je stari pri kraju svog efektivnog vijeka,ili se loše prodaje - čitaj cijede zadnji $ iz g92.Vidjet ćemo.
Mislim da je i Intel odličan primjer toga,a koja je vražja razlika u brzini 5200 i 7200 proceva?! Osim šta će pola ekipe uzeti seriju 7.Neobjašnjivo. Da ne spominjem razliku u performansama E4xxx,5xxx,6xxx i 7xxx serije,pa i do osmice,koja se ajd,doduše clocka kao blesava,ali ima i slabijih primjeraka i jeftinijih iz 4,5,6,7 serije koji idu na 4ghz.
Prodaju MB kešom muda pod bubrege.
Staro 05.03.2009., 16:38   #14
Blue_Fatal1ty
Blue_Fatal1ty's Avatar
Lokacija: Čazma
Postovi: 1,728
Iskreno, kada sam prvi put vidio naziv grafe pomislio sam da je to neka lošija verzija GTX260 s manjim dimenzijama i manje shadera/memorije. Kado ono opet 8800 serija hahaha ajde dobro...
Staro 05.03.2009., 17:41   #15
Burko
Burko's Avatar
Postovi: 2,317
sto sam rekao i napisao jos prije nekih 5 mjeseci, kad su se pojavili e5200 i e7200 kod nas. i evo zakljucka.....
Staro 10.03.2009., 15:37   #16
Gilbert5
Agent 0
Gilbert5's Avatar
Postovi: 4,312
Staro 10.03.2009., 16:01   #17
DeadMan+
LateralusX
DeadMan+'s Avatar
Postovi: 1,788
Autor Gilbert5 Pregled postova
joj joj, najavljena cijena tih kartica je bila o 129-149$ ovisno o tome da li imaju 512 MB ili 1 GB, sto ovu cijenu cini gotovo dvostruko visom.....
DeadMan+ je offline   Reply With Quote
Staro 10.03.2009., 16:17   #18
Gilbert5
Agent 0
Gilbert5's Avatar
Postovi: 4,312
Da, tak i preporučena za 260GTX 216 jest 199$ pa je kod nas 2000kn. Jbg
Staro 10.03.2009., 17:42   #19
Bravo
Bravo's Avatar
Postovi: 1,450
Ova je država stvarno bananacijene ne samo da neče past nego idu gore, evo za primjer procesori, svaki tjedan dižu cijene..
Staro 10.03.2009., 17:53   #20
hammer_of_thor
its slightly turbocharged
hammer_of_thor's Avatar
Postovi: 5,430
Ajd pa cijena i nije tak prestrašna, 1400 kn, ja sam očekivao i više cijene.
A opet dobiješ GTS (xyx-dodaj broj) model, novi model, odmah ti je i draže jer više nije lame 9800 ili 8800.
A kak vidimo po prvim reviewima, kartica je pomalo i iznenadila - pozitivno.
blaa
Staro 11.03.2009., 15:27   #21
gnomisa
gnomisa's Avatar
Datum registracije: Feb 2003
Postovi: 1,556
ja baš gledam karticu do 1500 kn i mislim da je 4870 s DDR5 memom najbolji izbor...jer ovo od nvidije je još jedno uskrsnuće, odn. 9800GTX+ sa 3% većim performansama...a i Uskrs je blizu....
gnomisa je offline   Reply With Quote
Staro 14.03.2009., 20:54   #22
marko_1
marko_1's Avatar
Postovi: 750
Buduci da sam bio u guzvi sa vremenom i nisam imao vremena raditi nikakav software bench mogu napisati ugrubo o kartici... Veci dio price vec svi znate iz citanja ove teme... Nisam koristio previse strucnih i :geekovskih" izraza kako bi review bio svima donekle jasan... Imam manji monitor (17" CRT), prema tome me uopce ne zanima kako se ponasa na neznam kakvim rezolucijama, kada budem kupovao monitor nakon toga cu opet promijeniti graficku. Radije sacekam mjesec dva i kupim posteni monitor nego da stedim na drugim komponentama i onda kupim "neki" monitor... Krecem od pocetka... Grafa dolazi u solidnom pakiranju, nikakava velicinom napuhana kutija sa raznim modnim dodacima, sljokicama ili pitaj boga cime.
Upload slika i fotografija Upload slika i fotografija
U kutiji se nalazi (druga kutija lol ), bundle koji se sastoji od quickstarta, sturog manuala (ako to mozemo tako nazvati)/installation guidea, klasicno CD sa driverima i natpis koji se stavlja na kvaku od sobe na kojem pise "Do not disturb, I'm gaming", ujedno sluzi i za registraciju proizvoda na njihovoj stranici. Na kutiji pise da se dobiva kopija 3DMark-a Vantage, ali u biti je to papir na kojem pise S/N a program morate skinuti sa futuremarkove stranice. Kablovi/adapteri: DVI-VGA pretvornik, kabel za napajanje i za TVout i naravno sama graficka kartica koja zauzima 2 slota zbog hladenja.
Upload slika i fotografija Upload slika i fotografija Upload slika i fotografija Upload slika i fotografija Upload slika i fotografija
U konfi mi nista nije overclockano tako da nema potrebe za dodatnim hladenjem, jedini hladnjaci koje imam su u napajanju, na procesoru i jedan 80mm AC koji puse po hardu (+ sada vent na kartici), prije sam imao pasivno hladenu 3450, ponata ove recenice je da sam navikao na tisinu. Iznenadio sam se (negativno) bukom koji proizvodi ova kartica, no cim se driveri instaliraju stvar postaje drugacija, ukljucuje se automatska regulacija te se ventilator na kartici drasticno stisava, ne osjecam veliku razliku u glasnoci sa obzirom na prethodnu pasivno hladenu grafu, db nisam mjerio, nisam bio u hodu duze vrijeme sa "high end" karticama pa je nemam po tom pitanju sa cime usporediti. Sto je veci load grafe tako se i buka povecava no sve je u granicama izdrzljivosti i normale... Temperature nisam mjerio, problema sa driverima nikakvih (instalirao sam latest sa nvidie). Za probu sam odigrao UT3 cist da vidim jel sve oke radi tako da je u biti jedan najbitniji dio reviewa odrezan, no pored ovih 6 komada na pocetku teme, neznam da li je potrebno jos filozofirati s obzirom koliko toga vec ima nadrobljenog u ovoj temi...
Zakljucak: IMHO za 1200 kn graficka koja je rebrandan prethodnik sa "poboljsanjima" pa se manje zagrijava, trosi manje struje (1 pcie konektor), solidne tisine (ako se nesto necuje to je onda ugodna tisina, sve drugo je solidno ili bucno ), 2 godine garancija je oke kupovina ako se odlucujete na NOVU graficku karticu.
Pros:
- Nabrojanu u zakljucku...
- S/N za vantage mark, no meni to iskreno nista ne predstavlja :/
Cons:
- Update stare serije
- 3d mark ne dolazi na CDu (iako to ne uzimam kao neki nedostatak jer skidanje sa neta tih 450 mb danas traje 16 minuta)
- Mogla bi biti i tisa za moj ukus
- Nebi propali za bogatiji bundle
To bi bilo sve od mene, zadovoljan sam kupovinom, tak i tak ce se mijenjat za mjesec-dva pa necu puno love spusit na ovoj kupovini...
marko_1 je offline   Reply With Quote
Staro 16.03.2009., 23:46   #23
Munja00
Postovi: 131
oprostite na spamu ali ne mogu izdrzat.
Jeli vi vidite sta su napravili od nas sa igricama i raznim smecima kad svugdi citam da cijena od 1400kn nije strasna... kako nije strasna ajde ih zaradi. Za godinu dana izgubis 50% a za dvi godine vridi onoliko da ti se gadi prodat (radje neka kupi prasinu) kad znas koliko si je platija.
Munja00 je offline   Reply With Quote
Staro 16.03.2009., 23:56   #24
Crash009
Crash009's Avatar
Lokacija: Orahovica
Postovi: 7,363
Je.
Zato ja furam integrušu HD3200 dam joj malo rama da "glaba" i svi sretni. Ne igram se jer manje-vise nisam naletio na neku igru vrijednu igranja osim FM seriala. Takodjer treba netko i kruha zaraditi.
Kad se sjetim da sam prije par godina FX5700 platio 1500kn.ccc. Sad vrijedi isto kao i ovaj podmetac na kojem hladnu žuju držim
Staro 17.03.2009., 00:46   #25
Majo
Lokacija: Zagreb,Dubrava
Postovi: 2,281
Kartica previse kosta,pogledajte ovo,Nvidia je smanjila cijene GTX260(216SP) modela na 199$ znaci cca 1250kn s PDV-om,a kod nas se prodaje za 2.2K kn+.Pa mislim ko je tu lud,ova kartica po tome ne vrijedi ni 700kn a kamoli 1300.Jebemu nase trgovce,kako mogu nabijat tolku cijenu,fakat mi nije jasno.
Majo je offline   Reply With Quote
Staro 17.03.2009., 00:53   #26
Burko
Burko's Avatar
Postovi: 2,317
Autor Munja00 Pregled postova
jest, kad se treba imati grafika na full na nativnoj rezoluciji danasnjih prosjeka monitora, a to je 1440x900, ili 1680x1050, ili vise.
uostalom, tko koga prisiljava na kupovinu grafickih kartica (a odnosi se i na ostatak komponenti) koje kostaju preko 1000 kuna? nitko, osim samih ljudi. nisu tu nista imo krivi proizvodaci kartica niti proizvodaci igara, los kod je los kod barem sto se tice softverskog dijela.
a isto tako nikad nije high - top high segment bio jeftin da se moglo reci da je prisupacan bas svima. koliko je prije kostao jedan jaci procesor, koliko tek dvojezgras kad su izasli? rami tek? cijena grafickih je takoder opala zajedno sa cijenama svih komponenti kako su tehnoloski uznapredovale, samo je stvar koliko pojedinac ima apetite. tako da osobno ne podrzavam da je 1400 kuna malo dati za jednu karticu jer mi ne treba, ali opet kad se pogleda koliko se dobiva sa jednom takvom karticom - isplati se.
uostalom, prije se nije moglo zamisliti da za cca 3000 kuna uzmes kantu koja je u stanju vrtiti doslovce sve dostupne igre u prakticki bilo kojoj rezoluciji. danas to slozis bez pol muke. opet - druga stvar je kako tko guta marketing i zeli (mora) imati medium-high komponente..........
Staro 17.03.2009., 00:55   #27
Gemmy
smeghead
Gemmy's Avatar
Postovi: 3,183
Autor Majo Pregled postova
je da, kao sta je preporucenih 150 usd za hd4870 a cijena kod nas min 1450 kn
Staro 17.03.2009., 04:17   #28
Hunt.ONE
ЬГΛY.Z0ИЗ
Hunt.ONE's Avatar
Lokacija: Sisak
Postovi: 258
carina+pdv+marza
This post is copyrighted ©
Hunt.ONE je offline   Reply With Quote
Staro 17.03.2009., 08:21   #29
Majo
Postovi: 2,281
Autor Hunt.ONE Pregled postova
carina+pdv+marza
To jos uvijek ne opravdava 2.2X vecu cijenu.
Staro 17.03.2009., 08:43   #30
thedream
thedream's Avatar
Postovi: 5,458
To ovisi od države do države,evo dokaz da i u njemačkoj košta koliko i kod nas,čak i skuplje.
http://www.alternate.de/html/product...6/?tn=HARDWARE
Općepoznato je,da je u SAD-u tehnika i obuća/odjeća gotovo džabe u odnosu na Europu,čisto stvar ponude i potražnje, možda ondje i ne grabe kartice od 200$,pogotovo u odnosu na kupovnu moć prosječnog gamera koja je vjerujem barem dvostruka nego kod nas. Također bi bilo zanimljivo vidjeti tržište polovnog HW u SAD-u. Mislim da gotovo sigurno nije razvijeno kao naše.
Samo mala opaska/paralela, bio sam nedavno i u Sloveniji,u Mariboru,Big bang trgovina, Logitech Z2300 koštaju 239 eura ako sam dobro zapamtio,ili 219. Nisam siguran,preko 200 je 100%. 219/239 nebitno. Samo dokaz da nije baš sve kod nas najskuplje,nego da pratimo rame u rame trend cijene HW u Europi.
Ne bi uspoređivao preporučene cijene u SAD-u jer oni imaju drugačije poreze,prireze i marže na tehniku,automobile pa i obuću/odjeću ako hoćete.
Lako paralelama zalutamo na to da jedan Civic/Accord tamo dođe gotovo duplo manje nego kod nas,a sa istim motorom i opremom,što nas dovodi u zabludu jer ne poznamo porezni sustav,troškove uvoza tih automobila, ponudu/potražnju za istima,marže autokuća itd.
Tako je i sa HW,tržište je neusporedivo.
