Staro 02.03.2009., 10:08   #1
misko-00
Lokacija: ddddd
Postovi: 46
Podržani procesori na Asus P4B?
Imam plocu Asus P4B, evo informacija:
*-core
description: Motherboard
product:
vendor: ASUSTeK Computer INC.
physical id: 0
version: REV 1.xx
serial: xxxxxxxxxxx
*-firmware
description: BIOS
vendor: Award Software, Inc.
physical id: 0
version: ASUS P4B ACPI BIOS Revision 1012 (08/21/2002)
capacity: 192KB
capabilities: pci pnp apm upgrade shadowing escd cdbootbootselect socketedrom edd int13floppy360 int13floppy1200int13floppy720 int13floppy2880 int5printscreen int9keyboard int14serial int17printer int10video acpi usb agp
I na njoj mi se nalazi:
*-cpu
description: CPU
product: Intel(R) Pentium(R) 4 CPU 1.50GHz
vendor: Intel Corp.
physical id: 4
bus info: cpu@0
version: 15.1.2
slot: PGA 478
capacity: 2400MHz
width: 32 bits
clock: 100MHz
capabilities: fpu fpu_exception wp vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm up
Ono što mene zanima je d ali ja mogu na tu ploču staviti neki od sljedećih procesora: http://www.nabava.net/kategorija.php...nost_proizvoda
  • Intel Pentium 4 E - 3.0GHz, 1MB, Prescott, FSB 800MHz, S.478, HT, tray
  • Intel Pentium 3,0GHz 800MHz 1Mb S.478 tray
  • CPU Intel Celeron D315 2.26GHz (533MHz,256KB,S478) box
  • Intel Pentium 2,0GHz 400Hz 512Mb S.478 tray
  • Intel Pentium 2,4GHz 533MHz 512Mb S.478 tray
  • CPU INTEL S478 Celeron D 325 2.53 GHz (533 MHz, 256K), BOX
i koji ?
U upustvima za matičnu sam našao sljedeće:
A 478-pin surface mount, Zero Insertion Force (ZIF) socket called mPGA478. This socket accommodates the Intel Pentium 4 478/Northwood Processor with 400MHz system bus.
I ja sam sada malo zbunjen, ne kužim sljedeće.
Da li ja na ovu ploću mogu staviti bilo koji procesor koji ima 478 pinova ?
Ili mogu samo tip procesora Nortwood sa 400MHz system bus ?
http://spa3102.blog.hr/
misko-00 je offline   Reply With Quote
Staro 02.03.2009., 10:54   #2
Postovi: 8,245
http://www.cpu-upgrade.com/mb-ASUS/P4B.html
ineče, ne ispalti ti se kupnja novog s.478 procesora jer za tu paru možeš prijeći na drugu platformu. Zato potraži malo na tržnici procesor koji ti odgovara!
http://www.hexus.net/content/item.ph...2&redirect=yes
"Processor
Socket 478 for FC-PGA2 Pentium® 4 (Willamette/Northwood) 2GHz+"
Staro 02.03.2009., 11:57   #3
misko-00
Lokacija: ddddd
Postovi: 46
Znaci ako sam dobro shvatio procesor mora biti Northwood na 400MHz system bus
Hvala
Staro 02.03.2009., 13:27   #4
Postovi: 34,087
Možeš staviti bilo koji s478 procesor.
Staro 02.03.2009., 15:42   #5
misko-00
Lokacija: ddddd
Postovi: 46
Autor coconut Pregled postova
Po ovome http://www.cpu-upgrade.com/mb-ASUS/P4B.html mi izgleda drukčije, tko je sad upravu ?
Staro 02.03.2009., 16:21   #6
nino
nino's Avatar
Postovi: 12,613
Ako je ploca gola P4B, onda Asus kaze ovako:
http://support.asus.com/cpusupport/c...roduct=1&os=17
Staro 03.03.2009., 09:00   #7
misko-00
Lokacija: ddddd
Postovi: 46
Autor nino Pregled postova
Pa to je ono što sam ja prije rekao, ako se pogleda svi su procerosi na 400Mhz.
