Staro 27.10.2004., 22:31   #1
LOLA
LOLA's Avatar
Datum registracije: Jul 2004
Lokacija: Laduch
Postovi: 32
Linux
Instaliro sam debian ali...
imam problem kod dizanja x! javlja mi ovaj error:
warning: process set to nice value 0 instead of -10 as requested
This is a pre-release version of XFree86, and is not supported in any
way. Bugs may be reported to XFree86@XFree86.Org and patches submitted
to fixes@XFree86.Org. Before reporting bugs in pre-release versions,
please check the latest version in the XFree86 CVS repository
(http://www.XFree86.Org/cvs)
XFree86 Version 4.1.0.1 / X Window System
(protocol Version 11, revision 0, vendor release 6510)
Release Date: 21 December 2001
If the server is older than 6-12 months, or if your card is
newer than the above date, look for a newer version before
reporting problems. (See http://www.XFree86.Org/FAQ)
Build Operating System: Linux 2.6.9-rc1 i686 [ELF]
Module Loader present
(==) Log file: "/var/log/XFree86.0.log", Time: Wed Oct 27 21:19:24 2004
(==) Using config file: "/etc/X11/XF86Config-4"
Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) ServerLayout "Default Layout"
(**) |-->Screen "Default Screen" (0)
(**) | |-->Monitor "Generic Monitor"
(**) | |-->Device "Generic Video Card"
(**) |-->Input Device "Generic Keyboard"
(**) XKB: rules: "xfree86"
(**) XKB: model: "pc104"
(**) XKB: layout: "us"
(**) |-->Input Device "Configured Mouse"
(**) |-->Input Device "Generic Mouse"
(WW) The directory "/usr/lib/X11/fonts/cyrillic" does not exist.
Entry deleted from font path.
(WW) The directory "/usr/lib/X11/fonts/100dpi/" does not exist.
(WW) The directory "/usr/lib/X11/fonts/75dpi/" does not exist.
(WW) The directory "/usr/lib/X11/fonts/Type1" does not exist.
(WW) The directory "/usr/lib/X11/fonts/Speedo" does not exist.
(WW) The directory "/usr/lib/X11/fonts/100dpi" does not exist.
(WW) The directory "/usr/lib/X11/fonts/75dpi" does not exist.
(**) FontPath set to "unix/:7100,/usr/lib/X11/fonts/misc"
(==) RgbPath set to "/usr/X11R6/lib/X11/rgb"
(==) ModulePath set to "/usr/X11R6/lib/modules"
(--) using VT number 7
(II) Loading /usr/X11R6/lib/modules/fonts/libbitmap.a
(II) Module bitmap: vendor="The XFree86 Project"
compiled for 4.1.0.1, module version = 1.0.0
(II) Loading /usr/X11R6/lib/modules/libpcidata.a
(II) Module pcidata: vendor="The XFree86 Project"
compiled for 4.1.0.1, module version = 0.1.0
(II) Loading /usr/X11R6/lib/modules/libscanpci.a
(II) Module scanpci: vendor="The XFree86 Project"
(II) Unloading /usr/X11R6/lib/modules/libscanpci.a
(--) PCI:*(1:0:0) NVidia unknown chipset (0x0185) rev 193, Mem @ 0xe0000000/24, 0xd8000000/27
(II) Loading /usr/X11R6/lib/modules/extensions/libGLcore.a
(II) Module GLcore: vendor="The XFree86 Project"
(II) Loading /usr/X11R6/lib/modules/extensions/libdbe.a
(II) Module dbe: vendor="The XFree86 Project"
(II) Loading /usr/X11R6/lib/modules/libddc.a
(II) Module ddc: vendor="The XFree86 Project"
(II) Loading /usr/X11R6/lib/modules/extensions/libdri.a
(II) Module dri: vendor="The XFree86 Project"
(II) Loading /usr/X11R6/lib/modules/linux/libdrm.a
(II) Module drm: vendor="The XFree86 Project"
(II) Loading /usr/X11R6/lib/modules/extensions/libextmod.a
(II) Module extmod: vendor="The XFree86 Project"
(II) Loading /usr/X11R6/lib/modules/fonts/libfreetype.a
(II) Module freetype: vendor="The XFree86 Project"
compiled for 4.1.0.1, module version = 1.1.9
(II) Loading /usr/X11R6/lib/modules/extensions/libglx.a
(II) Module glx: vendor="The XFree86 Project"
(II) Loading /usr/X11R6/lib/modules/linux/libint10.a
(II) Module int10: vendor="The XFree86 Project"
(II) Loading /usr/X11R6/lib/modules/extensions/libpex5.a
(II) Module pex5: vendor="The XFree86 Project"
(II) Loading /usr/X11R6/lib/modules/extensions/librecord.a
(II) Module record: vendor="The XFree86 Project"
compiled for 4.1.0.1, module version = 1.13.0
(II) Loading /usr/X11R6/lib/modules/fonts/libspeedo.a
(II) Module speedo: vendor="The XFree86 Project"
(II) Loading /usr/X11R6/lib/modules/fonts/libtype1.a
(II) Module type1: vendor="The XFree86 Project"
(II) Loading /usr/X11R6/lib/modules/libvbe.a
(II) Module vbe: vendor="The XFree86 Project"
(II) Loading /usr/X11R6/lib/modules/extensions/libxie.a
(II) Module xie: vendor="The XFree86 Project"
(II) Loading /usr/X11R6/lib/modules/drivers/nv_drv.o
(II) Module nv: vendor="The XFree86 Project"
compiled for 4.1.0.1, module version = 1.0.1
(II) Loading /usr/X11R6/lib/modules/input/mouse_drv.o
(II) Module mouse: vendor="The XFree86 Project"
(II) NV: driver for NVIDIA chipsets: RIVA128, RIVATNT, RIVATNT2,
RIVATNT2 (A), RIVATNT2 (B), RIVATNT2 (Ultra), RIVATNT2 (Vanta),
RIVATNT2 M64, RIVATNT2 (Integrated), GeForce 256, GeForce DDR,
Quadro, GeForce2 GTS, GeForce2 GTS (rev 1), GeForce2 ultra,
Quadro 2 Pro, GeForce2 MX, GeForce2 MX DDR, Quadro 2 MXR,
GeForce 2 Go, GeForce3, GeForce3 (rev 1), GeForce3 (rev 2),
GeForce3 (rev 3)
(--) Assigning device section with no busID to primary device
(EE) No devices detected.
Fatal server error:
no screens found
When reporting a problem related to a server crash, please send
the full server output, not just the last messages.
This can be found in the log file "/var/log/XFree86.0.log".
Please report problems to submit@bugs.debian.org.
X connection to :0.0 broken (explicit kill or server shutdown
Jel neko zna sto mi je za ciniti!
LOLA je offline   Reply With Quote
Staro 27.10.2004., 23:26   #2
BrunoZG
Junior Member
BrunoZG's Avatar
Datum registracije: May 2003
Postovi: 3,205
kaj je to novi debian?Da nije prestar kernel za tvoju grafulju?
Ocito mu nesto nije leglo sa grafickom karticom.
Na zalost u linuxu nije tak jednostavno rec kaj je.
X server radi sa radeonom 9600 sa mandrake od 9.1na dalje.
AMD 3800+x2@2500, 1,375V
MB-ASROCK DUAL SATA(bios 2.2) 2+ENERMAX485W
2x512 Supertalent CL2
HDD-Hitachi 160GB, WD 800JB
ELSA 7600GT
Leadtek-2000XP expert
DVDROM-LITEON-167T ,DVDRW BENQ 1650,DVDRW NEC ND2500A@2510_fw205C
Monitor: Samsung 997MB (19')
Terratec Sky 5.1,EPSON-C42
BrunoZG je offline   Reply With Quote
Staro 27.10.2004., 23:59   #3
MasterX
do you speak it?
Lokacija: ::1
Postovi: 1,630
ako mislis raditi nesto na linuxu kreni od SuSe (friendly linux za pocetnike) a onda udri na slackware ili gentoo(preporuka)... debian ostavi za one dane kada guzicu neces micati po tjedan dana od kompjutera...
a mandrake je malo sje*an zato sto je jako "svojeglav", tako da neke stvari koje se na mandraku rade na jedan nacin, na svim ostalim unix-odima se rade na drugi...
Drinking Rum before 10am makes you a Pirate, not an Alcoholic.
MasterX je offline   Reply With Quote
Staro 28.10.2004., 12:28   #4
LOLA
LOLA's Avatar
Lokacija: Laduch
Postovi: 32
thx!Naso sam problem!Ocito je stvar u prastarom kernelu!
Staro 28.10.2004., 13:10   #5
LOLA
LOLA's Avatar
Lokacija: Laduch
Postovi: 32
E sad kad smo kod kernela!imam dvije opcije:
1.staviti novi kernel na postojecu distribuciju!
2.staviti novi debian sa novim kernelom
Ako se odlucim za prvu opciju imam problem jer za to treba poprilicno znanja kojim ja bas i ne obilujem!
A ako se odlucim za drugu imam problem jer nemogu na listi za drivere nemogu naci svoju mreznu karticu koja mi je potrebna za daljnju instalaciju!Ima neko neku ideju kako da rijesi svoj problem sa kernelom???
