06.02.2009., 16:29 | #1 |
Lokacija: Varazdin
Postovi: 30
Packet Tracer Frame Relay
Trebo bi iskonfigurirat frame relay izmedju dva routera u packet traceru. Cisto jednostavan spoj , znaci dva routera , serijska konekcija ... Jedan drugog mora pingat... Meni nikako da proradi , glavna greska je line protocol down (disabled)... Help me !?!?
\m/ (Oo) .!. Ownage |
06.02.2009., 16:50 | #2 |
lar~
Postovi: 1,540
no shut? I ne bi li ti trebao frame relay switch izmedju? |
06.02.2009., 17:13 | #3 |
Lokacija: Vz
Postovi: 16
I podesit clock rate na DCE. Ako neznas koji je DCE pisi u oba dva clock rate 64000 |
07.02.2009., 15:31 | #4 |
Lokacija: Varazdin
Postovi: 30
Slozil frend , zabil sam no keepalive ... DTE strana interface Serial2/0 ip address 192.168.1.2 255.255.255.0 encapsulation frame-relay frame-relay map ip 192.168.1.1 102 broadcast frame-relay map ip 192.68.1.2 201 frame-relay interface-dlci 201 no keepalive DCE strana interface Serial2/0 ip address 192.168.1.1 255.255.255.0 encapsulation frame-relay frame-relay map ip 192.168.1.2 102 broadcast frame-relay map ip 192.168.1.1 102 frame-relay interface-dlci 102 no keepalive clock rate 64000 Pa ako ce tko trebat ubuduce...
