Staro 01.02.2009., 11:28   #1
robee
robee's Avatar
Lokacija: VinkovcI
Postovi: 939
Dos naredba za otvaranje mreznog diska?
Jel zna netko kako napraviti da se nakon podizanja win xp-a otvori win explorer i to mrezno djeljene diskove.
Dakle, otvori explorer i pokaze mi sto se nalazi na hdd koji je u drugom kompu...
znam da ide u notpadu..start...pa slovo poarticije, ali otvori mi samo lokalu, a za mreznu mu ne znam odrediti putanju...ako napisem samo slovo particije i pokrenem narednu, on sve uredno otvori, no nakon ponovnog pokretanja win xp-a javi da ju ne moze pronaci..
robee je offline   Reply With Quote
Staro 01.02.2009., 12:22   #2
zmikic
zmikic's Avatar
Postovi: 206
pa ako je drugi komp izgasen?
walk the talk
zmikic je offline   Reply With Quote
Staro 01.02.2009., 12:35   #3
Bubba
E Pluribus UNIX
Bubba's Avatar
Datum registracije: Oct 2002
Lokacija: M82
Postovi: 6,731
Autor robee Pregled postova
Code:
pushd /?
Stores the current directory for use by the POPD command, then
changes to the specified directory.
PUSHD [path | ..]
  path        Specifies the directory to make the current directory.
If Command Extensions are enabled the PUSHD command accepts
network paths in addition to the normal drive letter and path.
If a network path is specified, PUSHD will create a temporary
drive letter that points to that specified network resource and
then change the current drive and directory, using the newly
defined drive letter.  Temporary drive letters are allocated from
Z: on down, using the first unused drive letter found.
popd /?
Changes to the directory stored by the PUSHD command.
POPD
If Command Extensions are enabled the POPD command will delete
any temporary drive letter created by PUSHD when you POPD that
drive off the pushed directory stack.
Ili baci oko na net use pa permanentno mapiraj diskove.
Programer
Staro 01.02.2009., 12:38   #4
Postovi: 23,484
Prvo definiraj permanentno (znači da zapamti) network drive (mrežno djeljeni disk ili folder) dobije "slovo" (npr. N), preporuka ostavi par slobodnih "slova" zbog USB sticka / diskova.
Ako iz nekog razloga ovo ti ne uspije alternativa je shorcut putanja: \\ime_kompjutera\folder. Možeš rješit i kroz CMD koristeći NET USE komandu (vidi help na netu). Na ovaj način možeš lakše unjet password za pristup share folderu ako je postavljen.
Za kraj pogledaj opcije command line za Explorer, tu možeš definirat šta će imati fokus nakon otvaranja (umjesto idiotskog MyDocuments može biti šta želiš pa i poviše definiran share folder/disk).
Staro 01.02.2009., 13:34   #5
robee
robee's Avatar
Lokacija: VinkovcI
Postovi: 939
diskovi su mapirani i na drugom komu vidljivi i sve radi ako mishom kliknem na neki od njih, ali kada pokrenem recimo XBMC on nema pristum mapiranim diskovima i zablesavi se, kao i GOM player, sve dok prije pokretanja jednog od tih programa rucno ne kliknem na mapirane diskove. Nakon toga sve radi odlicno...
Znaci fora je u tome da se mapirani diskovi otvore nakon dizanja win-a kako bi ovi programi normalno radili...
evo putanja...
znaci u notpadu napisem start...i sada treba odrediti putanju da otvori mapirane diskove...
ako napisem start X:
kaze da ga ne moze pronaci...
sorry na mozda blesavim pitanjima, ali ja i dos...hm
Staro 01.02.2009., 13:59   #6
thopok
Lokacija: Splity
Postovi: 3,003
Staro 01.02.2009., 14:27   #7
robee
robee's Avatar
Lokacija: VinkovcI
Postovi: 939
Autor thopok Pregled postova
ukljuceno...
Staro 02.02.2009., 12:17   #8
bilbdonraa
bilbdonraa's Avatar
Postovi: 9
baci shortcut od mapiranih diskova u startup
Death is nature's way of telling you to slow down.
bilbdonraa je offline   Reply With Quote
