Buzov
Postovi: 35
Dual Boot Xp - Ubuntu Help
Instalirao sam Xp ,zatim Ubuntu 8.10.Međutim kada upalim racunalo ne pojavi se ni boot loader ni Grub,direktno uđe u XP.Kako da namjestim Grub?(da i sto je bolje windows boot loader ili Grub ?) ------------------------------------------------------------------------------------------------------------------------- Disk /dev/sda: 9729 cylinders, 255 heads, 63 sectors/track Units = cylinders of 8225280 bytes, blocks of 1024 bytes, counting from 0 Device Boot Start End #cyls #blocks Id System /dev/sda1 * 0+ 2549 2550- 20482843+ 7 HPFS/NTFS /dev/sda2 2550 8453 5904 47423880 7 HPFS/NTFS /dev/sda3 8454 9728 1275 10241437+ 5 Extended /dev/sda4 0 - 0 0 0 Empty /dev/sda5 8454+ 9668 1215- 9759456 83 Linux /dev/sda6 9669+ 9728 60- 481918+ 82 Linux swap / Solaris Disk /dev/sdb: 38913 cylinders, 255 heads, 63 sectors/track Units = cylinders of 8225280 bytes, blocks of 1024 bytes, counting from 0 Device Boot Start End #cyls #blocks Id System /dev/sdb1 * 0+ 38912 38913- 312568641 7 HPFS/NTFS /dev/sdb2 0 - 0 0 0 Empty /dev/sdb3 0 - 0 0 0 Empty /dev/sdb4 0 - 0 0 0 Empty ----------------------------------------------------------------------------------------------------------------- |
White Rabbit
Postovi: 5,112
Baci oko na tutorial... |
Postovi: 23,567
Onda nisi savladao grub kako treba tj. opcije za namještanje boot menija. Stavio zadnju verziju Grub - a? |
Lokacija: Splity
Postovi: 3,003
Buzov
Postovi: 35
Problem rijesen! Zadnje izmijenjeno od: buzov007. 01.02.2009. u 15:49. |
