Lokacija: ZGB
Postovi: 90
Problemi sa przilicom
kiddara Your Organization/Home Here 1A23-0009-6030-1294-2086-1014 Windows XP 5.1 IA32 WinAspi: - ahead WinASPI: File 'C:\Program Files\Ahead\nero\Wnaspi32.dll': Ver=2.0.1.68, size=160016 bytes, created 22.7.2004 17:33:44 Nero version: 6.3.1.25 Recorder: Adapter driver: Drive buffer : 2048kB Bus Type : via Inquiry data (1) -> ATAPI, detected: ? Connected to MMC as unknown drive with class-nr : 1 Drive is autodetected - recorder class: Std. MMC recorder CD-ROM: Adapter driver: === Scsi-Device-Map === DiskPeripheral : Hitachi HDS721612PLA380 atapi Port 0 ID 0 DMA: On DiskPeripheral : Seagate ST3160021A 8.01 mv61xx Port 4 ID 0 DMA: Off CdRomPeripheral : ATAPI DVD A DH20A4P 9P53 mv61xx Port 4 ID 1 DMA: Off ArrayPeripheral : MARVELL Virtual Device 1.00 mv61xx Port 4 ID 20 DMA: Off === CDRom-Device-Map === ATAPI DVD A DH20A4P E: CDRom0 ======================= AutoRun : 1 Excluded drive IDs: WriteBufferSize: 83886080 (0) Byte ShowDrvBufStat : 0 BUFE : 0 Physical memory : 2047MB (2097151kB) Free physical memory: 1962MB (2009712kB) Memory in use : 22 % Uncached PFiles: 0x0 Use Static Write Speed Table: 0 Use Inquiry : 1 Global Bus Type: default (0) Check supported media : Disabled (0) 12.1.2009 ISO compilation 16:03:26 #1 Text 0 File Isodoc.cpp, Line 6083 Iso document burn settings ------------------------------------------ Determine maximum speed : FALSE Simulate : FALSE Write : TRUE Finalize CD : TRUE Multisession : FALSE Burning mode : DAO Mode : 1 ISO Level : 1 (Max. of 11 = 8 + 3 char) Character set : ISO 9660 Joliet : TRUE Allow pathdepth more than 8 directories : FALSE Allow more than 255 characters in path : FALSE Write ISO9660 ;1 file extensions : TRUE 16:03:26 #2 Text 0 File Reader.cpp, Line 126 Reader running 16:03:26 #3 Text 0 File Writer.cpp, Line 124 Writer ATAPI DVD A DH20A4P running 16:03:26 #4 ISO9660GEN -11 File geniso.cpp, Line 3899 First writeable address = 0 (0x00000000) 16:03:26 #5 Text 0 File Burncd.cpp, Line 3152 Turn on Disc-at-once, using DVD media 16:03:26 #6 Text 0 File DlgWaitCD.cpp, Line 247 Last possible write address on media: 2295103 (510:01.28, 4482MB) Last address to be written: 2249327 (499:51.02, 4393MB) 16:03:26 #7 Text 0 File DlgWaitCD.cpp, Line 259 Write in overburning mode: NO (enabled: CD) 16:03:26 #8 Text 0 File DlgWaitCD.cpp, Line 2162 Recorder: ATAPI DVD A DH20A4P, Media type: DVD+R Disc Manufacturer ID: MBIPG101, Media Type ID: R05, Product revision number: 1 Disc Application Code: 0, Extended Information Indicators: 7 16:03:26 #9 Text 0 File DlgWaitCD.cpp, Line 420 >>> Protocol of DlgWaitCD activities: <<< ========================================= 16:03:27 #10 Text 0 File ThreadedTransferInterface.cpp, Line 813 Setup items (after recorder preparation) 0: TRM_DATA_MODE1 (CTransferItem) 2 indices, index0 (150) not provided original disc pos #0 + 2249328 (2249328) = #2249328/499:51.3 relocatable, disc pos for caching/writing not required/required, no patch infos -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2249328 blocks [ATAPI DVD A DH20A4P ] -------------------------------------------------------------- 16:03:27 #11 Text 0 File ThreadedTransferInterface.cpp, Line 984 Prepare recorder [ATAPI DVD A DH20A4P ] for write in CUE-sheet-DAO DAO infos: ========== MCN: "" TOCType: 0x00; Session Closed, disc fixated Tracks 1 to 1: 1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4606623744, ISRC "" DAO layout: =========== __Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_ 0 | lead-in | 0 | 0x00 | 0x41 0 | 1 | 0 | 0x00 | 0x41 0 | 1 | 1 | 0x00 | 0x41 2249328 | lead-out | 1 | 0x00 | 0x41 16:03:27 #12 Phase 24 File dlgbrnst.cpp, Line 1855 Caching of files started 16:03:27 #13 Text 0 File Burncd.cpp, Line 4163 Cache writing successful. 16:03:27 #14 Phase 25 File dlgbrnst.cpp, Line 1855 Caching of files completed 16:03:27 #15 Phase 36 File dlgbrnst.cpp, Line 1855 Burn process started at 16x (22.160 KB/s) 16:03:27 #16 Text 0 File ThreadedTransferInterface.cpp, Line 2344 Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0 16:03:27 #17 Text 0 File Cdrdrv.cpp, Line 8230 ---- DVD Structure: Physical Format Information (00h) ---- Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050 Book Type: DVD+R (10), Part Version: 1 Disc Size: 120 mm, Maximum Rate: Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable Linear Density: 0,267 um/bit, Track Density: 0,74 um/track Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW) End Physical Sector Number of Data Area: 26053F h End Sector Number in Layer 0: 0 h Data in Burst Cutting Area (BCA) does not exist Disc Application Code: 0 / 0 h Extended Information indicators: 7 h Disc Manufacturer ID: MBIPG101 Media type ID: R05 Product revision number: 1 Number of Physical format information bytes in use in ADIP up to byte 63: 56 Media Specific [16..63]: 00 00 07 4D 42 49 50 47 - 31 30 31 52 30 35 01 38 ...MBIPG101R05.8 23 54 37 13 02 50 6B 02 - 8C 63 15 15 0B 0B 08 08 #T7..Pk..c...... 01 19 1B 0C 0C 0C 0D 01 - 00 00 00 00 00 00 00 00 ................ 16:03:27 #18 Text 0 File dlgbrnst.cpp, Line 1713 Set remaining time: 3:34,846 (214846ms) -> OK 16:03:27 #19 Text 0 File DVDPlusRW.cpp, Line 628 Start write address at LBA 0 DVD high compatibility mode: Yes 16:06:01 #20 SCSI -1024 File Cdrdrv.cpp, Line 1445 SCSI Exec, HA 4, TA 1, LUN 0, buffer 0x04000000 Status: 0x04 (0x01, SCSI_ERR) HA-Status 0x00 (0x00, OK) TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND) Sense Key: 0x04 (KEY_HARDWARE_ERROR) Sense Code: 0x08 Sense Qual: 0x03 CDB Data: 0x2A 0x00 0x00 0x06 0x89 0x60 0x00 0x00 0x20 0x00 0x00 0x00 Sense Data: 0x08 0x00 0x04 0x00 0x00 0x00 0x00 0x0A 0x00 0x00 0x00 0x00 0x08 0x03 16:06:01 #21 CDR -1024 File Writer.cpp, Line 304 Communication failure 16:06:01 #22 Text 0 File ThreadedTransfer.cpp, Line 229 all writers idle, stopping conversion 16:06:02 #23 Text 0 File ThreadedTransfer.cpp, Line 223 conversion idle, stopping reader 16:06:08 #24 Phase 127 File dlgbrnst.cpp, Line 1855 Generating DVD high compatibility borders 16:06:27 #25 Text 0 File dlgbrnst.cpp, Line 1713 Set remaining time: 0:00,000 (0ms) -> OK 16:06:27 #26 Phase 129 File dlgbrnst.cpp, Line 1855 Generating DVD borders completed successfully 16:06:27 #27 Text 0 File dlgbrnst.cpp, Line 1713 Set remaining time: 0:00,000 (0ms) -> OK 16:06:27 #28 Phase 38 File dlgbrnst.cpp, Line 1855 Burn process failed at 16x (22.160 KB/s) Existing drivers: File 'Drivers\CDRALW2K.SYS': Ver=8.0.0.212 , size=9464 bytes, created 8.3.2007 0:51:00 File 'Drivers\PXHELP20.SYS': Ver=3.00.56a, size=43528 bytes, created 8.3.2007 0:51:00 (Prassi/Veritas driver for win 2K) File 'Drivers\mv61xx.sys': Ver= 1.2.0.51 built by: WinDDK, size=143360 bytes, created 18.10.2007 21:22:02 (Adapter driver for rec) Registry Keys: HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option) HKLM\System\CurrentControlSet\Services\mv61xx\Parameters\Device mv61xx - NumberOfRequests 32 (recommended: 0) Uglavnom nezeli mi przit DVD-R,DVD+R, CD-R izbacuje Communication corrupted errore, jedino kaj przi je DVD+RW. Ucemu bi mogoa bit problem*? |
Lokacija: Orahovica
Postovi: 7,363
Probaj drugi program za snimanje, ako ne zeli ni onda pogledaj dali ima koji noviji firmware za tu przilicu. Ako ne proradi onda je neispravna i kupuj novu. |
