Staro 02.01.2009., 22:49   #1
KAEL-NO
KAEL-NO's Avatar
Datum registracije: Mar 2008
Lokacija: NOVSKA
Postovi: 26
forcebook minor
Da li je na ovom laptopu moguće ugraditi grafičku ili je na bilo koji način pojačati!
TECHNICAL SPECIFICATIONS
CPU Intel Banias/Dothan processor Support 1.8GHz or above, FSB 400MHzChipset Intel 855GM+ICH4-MMemory 256MB DDR-SDRAM, 1 x SO-DIMM DDRDisplay 14.1” TFT, XGA 1024x768 PixelsGraphics Intel 855GMDisk drive 2.5² / 9.5mm Design, 30GB/ 40GB/ 60GB, Ultra DMA 66/100 SupportOptical Device Combo driveSound system Sound Blaster Pro compatible, Support AC97 2.1, 2X Speakers Network connection 56Kb V.90 modem, 10/100 based-T LAN Bulit-in antenna for Mini-PCI wireless communication, 802.11b module with Mini-PCI interface(Optional)PCMCIA Type II x 1, CardBus SupportI/O connections USB2.0 port x 4 IEEE1394 port x 1 (4 pin) Mic-In (Mono) Headphone Out (Stereo) x1 Line out RJ-45 LAN jack x 1 (with cap) RJ-11 port x 1 MiniPCI VGA Port x1 DC inDimensions Width: 310 mm
Depth: 259 mm
Height: 25 - 33 mmWeight 2.4 KgBattery: 6-cell Li-ion 2200mAhOptional-Operating system Windows XP Home
KAEL-NO je offline   Reply With Quote
Staro 02.01.2009., 22:52   #2
Demon Hunter
Postovi: 999
Ne na oba pitanja.
Demon Hunter je offline   Reply With Quote
