Zaključane teme
Staro 31.12.2008., 02:18   #1
matorZdenko
Postovi: 34
AMD Turion X2 ZM-80 (2.1GHz)
Posto kupujem laptop, zanima me kakvi je to cpu-AMD Turion X2 ZM-80 (2.1GHz)...ima tko kakve usporedbe sa intelom?
matorZdenko je offline
Staro 31.12.2008., 13:19   #2
m.a.t.e.j
h3@dhunt3r
m.a.t.e.j's Avatar
Postovi: 55
ajde ljudi to sigurno mnoge zanima...
m.a.t.e.j je offline
Staro 10.01.2009., 23:47   #3
bosanac
Lokacija: Đakovo
Postovi: 107
Mene zanima!
bosanac je offline
Staro 11.01.2009., 01:01   #4
Matth€w
Matth€w's Avatar
Lokacija: NaN
Postovi: 3,438
Našao nešto na netu, pa si pročitajte.
I've been looking into this myself, might be a little late for you post but I'll share what I've been able to find around the web concerning those same three processors, the same three I've been looking at.
AMD Turion X2 TL-60, AMD Turion X2 Ultra ZM-80, Core2Duo T5750
First off let's start right here on tom's. You can get a bench for the TL-60 under the mobile chip section. It's performance is well... less that impressive. It's near the bottom but the important thing to drawl from this is that it's generally on par or better then the Core2Duo T7300 with the lower FSB. Why is that important?
The T575 is an OEM chip that intel launched without any fan-far and slipped into a number of mobile computers. From what I gathered from Notebookreview.com the T5750 is a cheaper to produce T7250 that runs at a lower clock speed, very similar to the T7300 at the lower speed. It's safe to say the performance difference between a T7300 and a T5750 have near identical performance.
With that in mind we can say the T5750 is a slightly (read microscopically) slower mobile cpu then the T7300 running a slow clock speed. Therefore the TL-60 safely performs on par with both of these intels and marginally out performs them in some tasks. So the T's are all pretty much the same. If your going to buy a laptop with any of these 3 chip types I'd ignore the cpu and instead look at what the other options are (Hard drive, DVD, wifi, RAM, video) to make a choice on which is best.
However when it comes to the Ultra ZM-80 allot of things change. Think of the TL-XX AMD chips as the old-guard. AMD has released two other Turion chips to replace the TL line. One is the RM and the other is the ZM. What's the difference? Glad you asked.
According to the AMD forums the RM is identical in architecture as the TL chips. However the RM comes in higher clocked versions and higher HT (hyper transport) speeds* and shares one important mobile aspect with the ZM. They run at lower idle clock speeds. The TL will throttle down to 800mhz at idle while the RM and ZM will drop to 500-600mhz which means longer battery life.
*Hyper Transport will not affect laptop performance.
The ZM on the other hand has TWICE the cache of the TL and RM cpus. In this regard the ZM will out perform them in almost every process (as Tom's has shown with their report on the significant of cache). However the ZM like the RM is fundamentally very similar to the TLs and subject to similar performance as same clock speeds. Because if this the "Ultra" ZM-80 running at 2.1ghz and the ZM-82 at 2.2ghz will be out performed by a Core2Duo T7500 running at the same clock.
Conclusion, if your thinking of buying a low end Core2Duo like the T5750 I'd take a look at the AMD Turion Ultra ZM-80 and 82. The AMD cpus also come with the ATI HD 3200 video chip set more often then not offering you some serious graphical performance.
For your needs, Photoshop, Cad and 3ds Max or not gonna get anything that runs these cpu intesive apps in a mobile platform at a resonable price. I run Photoshop and 3ds Max on my desktop which has a Core2Duo 6700 in it, nothing in the mobile platform comes near this unless you bump the budget up to something like the Acer Travelmate 6593. If your budget is tight i'd advise looking for the cheapest Core2Duo Penryn chip (P8400, P8600, etc) system you can find. If it's still outside your budget then go with whatever sytem either a AMD Turion ZM or Intel C2D T5850, T8100 that best suits your ram and disk requirements within budget.
U globalu, koliko sam i kod ostalih još uspio pročitati po forumima, ZM je sporiji od T5xxx CPU u istom/sličnom clock rangu, a i slabije baterija drži, iako i to ovisi dosta o ostataku hardware-a na dotičnom laptopu.
Matth€w je offline
Staro 20.01.2009., 02:45   #5
xvx1
Postovi: 123
Autor matorZdenko Pregled postova
AMD-ovi su na istom taktu nekih 10-20 % sporiji od Intel Core 2 Duo, ali zato dolaze u paru s HD3200 grafikom (Puma platforma) koja nije brža nekih desetak % već nekoliko puta od Intelovih integruša.
xvx1 je offline
Staro 20.01.2009., 09:47   #6
Jerry
Jerry's Avatar
Postovi: 1,816
Evo baci pogled na ovo:
Puma vs Centrino 2
http://www.notebooks.com/2008/12/30/...-new-notebook/
Stupid is as stupid does
Jerry je offline
Staro 20.01.2009., 22:42   #7
matman
Lokacija: n/a
Postovi: 362
razlika procesora rm-70 i zm-82
Zanima me dal oba mogu iskoristit mobility radeon 3650?
Konkretno dvoumim se između ova dva lapa, bili bi za Autocad, možda bi i probao modat u FireGL.
Pa me zanima, kakva je razlika, jer naravno, Acer je značajno jeftiniji.
http://www.mikronis.hr/shop/item.asp...=8852&catid=28
http://www.links.hr/index.php?option...kl=013.100.177
matman je offline
Staro 20.01.2009., 22:48   #8
Crash009
Crash009's Avatar
Lokacija: Orahovica
Postovi: 7,363
Toshiba je kvalitetnije izrade i ima duplo vise garancije.
Naravno opcenito su bolji od Acera i kompanije i zato su skuplji.
Crash009 je offline
Zaključane teme
