Staro 22.12.2008., 19:00   #1
alfa115
Forewer Young
alfa115's Avatar
Lokacija: Rovinj
Postovi: 17
Question Fujitsu-Siemens LOOX N560,procjena i prodaja
Navigacija:IGO8 sa kartama 43 eu zemlja
Garmin XT 08 Adriarute - obe rade savrseno i precizno,
detaljne karte
Google Maps-rade internet i GPS vezom
memorijska kartica od 4 GB+512 mb,sony slusalice,uredaj daje savrseni zvuk,
pod garancijom,star godinu dana
podesen za gledanje filmova bez komprimiranja,prikaz titlova,gledanje tv-a preko neta,
slusanje radija i snimanje,audio recorder,gledanje i skidanje sa youtuba i slicno
na cd-u dajem jos hrpu dodatnih programa sa svim alatima
instalirani programi:
games,office,adobe reader,spb pocket plus,spb meni,spb time,spb backup,pocket hack i
pocket mechanic pro,diamond tv,lignosoft dictionari,moblue,nr deluxe,pocket music,resco
pocket audio recorder,resco radio,resco photo viewer,tcpmp,weather wather,windows
mobile download accelerator,opera mobile,full keyboard...
uredaj radi odlico,brzo i bez problema sa navigacijama,cijena novog golog uredaja bez opreme
3.299,00 kn
(sa PDV-om)
IGO8 1.099,00 kn
(sa PDV-om)
Garmin XT 899,00 kn
(sa PDV-om)
auto pujnac 349,00 kn
(sa PDV-om) HG spot
•Intel PXA270 624 MHz based on Intel XScale microarchitecture•System memory (RAM) 64 MB•Flash memory (ROM) 128 MB•Full integrated SiRF Star IIIChip•3.5-inch VGA 480 x 640 colour transflective TFT Touchscreen, •65.536 colours, LED backlight•Integrated, 802.11 b/g, Wi-Fi certified •Integrated Bluetooth 1.2•Interfaces
1 x built-in microphone
1 x speaker
1 x headphone (3.5 mm) 4 pin
1 x IrDA
USB 1.1 (slave) via sync cable
USB 1.1 (host) via sync cable
Serial (RS232) via sync cable
Stereo Audio Out on cradle connector
•Expansion slots: SD card/MM card (SD I/O)•Battery
Exchangeable Lithium-Ion battery, rechargeable Main battery 1200 mAh•Power supply
Rated voltage 110 – 240 V Power cord with EU plug, UK plug additionally available, standard in UK versions•Standby time
Fully charged 500 h Battery life may vary depending on product model, configuration, applications, power management settings and features utilized. Battery recharge time depends on usage.•Dimensions / weight
Dimensions (H x W x D) 116 x 71x 14 mm Weight app. 160g
ID:	9127   Click image for larger version
ID:	9128   Click image for larger version
alfa115 je offline   Reply With Quote
Staro 22.12.2008., 20:47   #2
Mortal
Rambus 3xtr1m
Mortal's Avatar
Postovi: 2,694
Šta imaš gore orginalni IGO i Garmin?
Bez softvera uređaj je oko 1500kn mislim. A sad softvare kome treba...
Ryzen 7 2700X
Sonic Tower rev.1 (polirani) + 12cm Chieftec
2x 8gb Crucial
B450 Aurus Elite
Segate 500GB Server edition
Silwerstone Strider 560W +12@11.97-11.94V
GTX 1060
Samsung p2770, Hanns G 22' landscape
Samsung pleomax& Microsoft Sidewinder
Kensington Duo Wawe Pad
1. 2xP3 933, Intel OR840 Server, PCI MX440, 4x128Mb Rambus, 80gb segate, SmartBox 400W
2. P4 2.0 wille, Intel i850, 4x128 Rambus, GF2 GTS PRO, 80gb segate, MS 480w
3. P4 1.6 willie@2.0 - Abit th7 II, 4x128Mb Rambus@ 1078mhz, 9000pro, 80gb segate, silwerstone 400w
3 x Prestigio 710, 3 x Microsoft Optical desktop v2.0
i5 530
640gb
1x4gb, 1x2gb ddr3
GT330M
16' wide - white body
Harman Kardon
MX revolution
Online with nokia E70
Battery grip
Beercan: 35-70, 28-85, 35-105, 70-210
Minolta: 28-80, 35-70, 28-100, 35-80, 28-105xi, 75-300
Sigma: 35-70, 28-135, 18-200, 70-300
Sony: 18-70, 55-200
m42: Zenit 135mm, Crestar 135mm, Helios 44m
Mortal je offline   Reply With Quote
Staro 22.12.2008., 21:40   #3
alfa115
Forewer Young
alfa115's Avatar
Lokacija: Rovinj
Postovi: 17
navigacije su skinute sa neta,rade ok.samo uredaj bez opreme vrijedi 1500?
Staro 22.12.2008., 22:18   #4
Mortal
Rambus 3xtr1m
Mortal's Avatar
Postovi: 2,694
Onda nemoj navodit da imaš karte za njega jer nemaš orginal.
Trebao bi vrijediti 1500kn, jako je cijenjen uređa
Ryzen 7 2700X
2x 8gb Crucial
B450 Aurus Elite
GTX 1060
i5 530
640gb
1x4gb, 1x2gb ddr3
GT330M
Harman Kardon
MX revolution
Battery grip
Sony: 18-70, 55-200
Staro 22.12.2008., 22:41   #5
alfa115
Forewer Young
alfa115's Avatar
Lokacija: Rovinj
Postovi: 17
IGO8 sa 43 karte zauzima oko 1,55 GB a koja je razlika od originala i ovoga neznam?prosao sam sa njime istru do rijeke,sloveniju prema trstu i okolicu.To je sta sam ga uspio testirati i nije stvarao problema i tocno pokazuje.Prva prihvatljiva prilika dajem sve kako je navedeno
Staro 01.05.2009., 20:49   #6
alfa115
Forewer Young
alfa115's Avatar
Lokacija: Rovinj
Postovi: 17
Prodano!
silver.hornet
